  2. Disconnect Control
gxdn
By Administrator , 23 January, 2018
Disconnect control
Disconnect control represents a supply switch and the rules governing disconnection and reconnection. It distinguishes the physical output from the control state.
When to use it
Use it to check whether supply is disconnected and whether reconnection requires a local action.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Output state
Shows whether the physical output is connected or disconnected.
3. Control state
Shows the control state, such as disconnected, connected or ready for reconnection.
4. Control mode (version 0)
Selects modes 0-6, defining the allowed disconnection and reconnection transitions and the roles of remote, manual and local control.
4. Control mode (version 1)
Selects modes 0-7, defining the allowed disconnection and reconnection transitions. Mode 7 permits local or remote reconnection from ready for reconnection to connected, as well as manual reconnection.
Versions
Versions 0 and 1 have the same attribute indexes. Version 1 extends the available control modes; interpret the mode value according to the object version.
Actions
1. Remote disconnect
Remote disconnect.
2. Remote reconnect
Remote reconnect.
Frank G
4 years 10 months ago
Disconnect Control /Control Mode in Python
is there an example how to read and write the control mode using python?
Many Thanks
Frank
4 years 9 months ago
You can read it in the normal way. Create Disconnect Control object and read attribute index #4.
Frank G
reading is working, thank you!.
I am having problems with writing. I dont know where to put the value to be written.
My code:
rele = GXDLMSDisconnectControl ("0.0.96.3.10.255");
#####Read#####
lector.read(rele, 4)
print(rele.controlMode)
#####Write######
lector.write(rele, 4)
Many Thnaks
Frank
You need to update value for the Disconnect control object.
rele.controlMode = YOUR_VALUE
Make sure that you have enough access rights to write the objects.
alnardn
3 years 1 month ago
Hello! I also need to change…
Hello! I also need to change disconnect control mode, but i don't understand what is lector? What is this?
Frank G
it is working now
it is working now
Many Thanks
Frank
Kumaresh
1 year 3 months ago
Change Control Mode
Hi Kurmi ji,
below is my code and i want to update the Control Mode to Mode6 how can I. pls guide me!!!
def Re_Connect(self):
dc=GXDLMSDisconnectControl("0.0.96.3.10.255")
data=dc.remoteDisconnect(self.client)
print("Load Relay Reconnect")
reply = GXReplyData()
time.sleep(10)
dc.getValues()
time.sleep(10)
dc.setValue()
time.sleep(10)
time.sleep(10)
dc.getValues()
time.sleep(10)
data=dc.remoteReconnect(self.client)
dc.getValues()
self.writeTrace(dc)
print(dc)
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
