Hi Kurumi,
I’m using Gurux DLMS with HDLC and based part of my receive logic on the examples in the Gurux repository. In particular, I copied the pattern here (https://github.com/Gurux/Gurux.DLMS.Net/blob/751914f4a9a6fd504e5b8c6430…) where a reply is treated as “no data yet” when:
reply.Error == 0 && reply.Data.Size == 0
This generally works, but I ran into a subtle issue during disconnect handling, specifically with Kamstrup meters.
What I’m seeing:
When I send an HDLC Disconnect (DISC), the meter correctly replies with UA.
UA is a valid HDLC control frame and has no DLMS payload, so reply.Data.Size == 0.
Because reply.Error == 0 && reply.Data.Size == 0 matches, my code enters the loop that sends Receiver Ready (RR) / continuation frames.
This causes Gurux to think more data is expected, even though the link was cleanly disconnected.
The request and response is:
TX: 7E A0 07 21 25 53 E0 16 7E // DISC
RX: 7E A0 07 25 21 73 E3 33 7E // UA
GXDLMSDirector decodes this correctly as DISC / UA.
My question:
Is the (reply.Error == 0 && reply.Data.Size == 0) condition intended to be used only for I-frames / DLMS-level continuation, and not for HDLC control frames like UA?
Should user code explicitly check the HDLC frame type (UA/DISC/SNRM/etc.) and avoid sending RR / GetMoreData in those cases?
Or is this a limitation/bug in the example that should be guarded with additional checks?
My workaround is to add a bool parameter which I set to true when sending disconnect. I add it to the clause checking for empty data above so I don't enter the while loop if it is true and I received a valid frame with no data. This fixes the issue. I just want to confirm the intended pattern so I can use it if there is something more explicit.
Thanks — and thanks for the excellent library.
Any comments/updates on this?
Hi, I'm sorry for this. This…
I'm sorry for this. This was a specific version for one of the customers and was not planned to be added to GitHub.
Get the latest version. That will fix this.
Hi, this is in the latest…
Hi, this is in the latest version of the example in the Gurux.DLMS C# library still. No recent changes happened in that part of the code. Am I misunderstanding you? Which latest version do you refer to?
Hi, I was too fast. This is…
I was too fast. This is now available on GitHub.
