  3. Error When Trying To Add OBIS Codes For Manufacturer With Spain Standard
Error when trying to add OBIS codes for manufacturer with Spain Standard
By Klimmie. , 5 April, 2024
Hello there.
I am currently in the process of implementing DLMS protocol on a data logger. Because there have been some issues with the end user mixing up some of the objects I have decided to create the manufacturer settings on the DLMSDirector ( version 9.0.2311.1001) for my company.
When trying to add OBIS codes I kept getting an error "Input string was not in a correct format". After a couple minutes of fooling around it turned out the error occurred because I set the manufacturer standard as "Spain", and setting it to "DLMS" fixed everything.
For now I am not going to use the "Spain" standard (It's probably not even the standard we will end up using), but I thought it might be useful to let you guys know.
Have a nice day,
Klimmie
