  3. Model: Apec3, Manufacturer DZG Metering GmbH
Model: Apec3, manufacturer DZG Metering GmbH
By zul8387 , 2 February, 2024
I want to read meter value from the Director but unable to obtain connection. I need your help to configure as I do not see my meter selection
I can read using below command,
python main.py -h 183.171.15.226 -p 4001 -c 20 -s 255 -t Verbose -P 33333333
And the result is below,
gurux_dlms version: 1.0.147
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
Authentication: 0
ClientAddress: 0x14
ServerAddress: 0xff
Standard: 0
TX: 11:47:08 7E A0 08 02 FF 29 93 D1 80 7E
RX: 11:47:09 7E A0 21 29 02 FF 73 CC 61 81 80 14 05 02 01 20 06 02 01 20 07 04 00 00 00 01 08 04 00 00 00 01 0B C9 7E
TX: 11:47:09 7E A0 2C 02 FF 29 10 C3 7B E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 11:47:09 7E A0 2E 29 02 FF 30 AF 7B E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00 CA 20 7E
TX: 11:47:09 7E A0 08 02 FF 29 53 DD 46 7E
RX: 11:47:09 7E A0 08 29 02 FF 73 39 50 7E
Connection is permanently rejected
No reason is given.
2 years 7 months ago
Hi, SOrry, to say, but you…
SOrry, to say, but you can read your meter. The meter returns an error.
You need to give the authentication level. That is missing. Replace Low with your authentication level.
python main.py -h 183.171.15.226 -p 4001 -a Low -c 20 -s 255 -t Verbose -P 33333333
If still fails check your client address.
zul8387
Thanks Mikko. Below are the…
Thanks Mikko. Below are the response from the meter, I will then need to use DLMS translator to translate the message and convert PDU to XML to obtain the meter reading? Any equivalent python program that I can use?
Authentication: 1
ClientAddress: 0x14
ServerAddress: 0xff
Standard: 0
TX: 08:32:02 7E A0 08 02 FF 29 93 D1 80 7E
RX: 08:32:03 7E A0 21 29 02 FF 73 CC 61 81 80 14 05 02 01 20 06 02 01 20 07 04 00 00 00 01 08 04 00 00 00 01 0B C9 7ETX: 08:32:03 7E A0 45 02 FF 29 10 14 8B E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 33 33 33 33 33 33 33 33 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF A3 A9 7E
RX: 08:32:04 7E A0 38 29 02 FF 30 77 F4 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 01 20 00 07 76 D3 7E
TX: 08:32:04 7E A0 1A 02 FF 29 32 9A 96 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 08:32:04 7E A1 39 29 02 FF 52 0C BB E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 01 20 01 82 0D E9 02 04 12 00 0F 11 01 09 06 00 00 28 00 01 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 02 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 03 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 04 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 49 90 7ETX: 08:32:04 7E A0 14 02 FF 29 54 12 F1 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
RX: 08:32:05 7E A1 39 29 02 FF 74 38 FF E6 E7 00 C4 02 C1 00 00 00 00 02 00 82 01 20 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 05 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 06 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 D6 C2 7ETX: 08:32:05 7E A0 14 02 FF 29 76 02 F3 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
RX: 08:32:06 7E A1 39 29 02 FF 96 24 3B E6 E7 00 C4 02 C1 00 00 00 00 03 00 82 01 20 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 07 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 A0 4F 7ETX: 08:32:06 7E A0 14 02 FF 29 98 72 FD E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E
RX: 08:32:07 7E A1 39 29 02 FF B8 58 F3 E6 E7 00 C4 02 C1 00 00 00 00 04 00 82 01 20 00 09 06 00 00 61 61 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 05 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 05 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 02 4A F2 7ETX: 08:32:07 7E A0 14 02 FF 29 BA 62 FF E6 E6 00 C0 02 C1 00 00 00 04 FC E9 7E
RX: 08:32:08 7E A1 39 29 02 FF DA 4C B3 E6 E7 00 C4 02 C1 00 00 00 00 05 00 82 01 20 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 05 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 05 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 32 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 01 FF 02 02 01 02 02 03 0F BF A3 7ETX: 08:32:08 7E A0 14 02 FF 29 DC 52 F9 E6 E6 00 C0 02 C1 00 00 00 05 75 F8 7E
RX: 08:32:09 7E A1 39 29 02 FF FC 78 F7 E6 E7 00 C4 02 C1 00 00 00 00 06 00 82 01 20 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 01 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 02 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 03 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 04 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 05 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 06 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 07 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 E8 3A 7ETX: 08:32:09 7E A0 14 02 FF 29 FE 42 FB E6 E6 00 C0 02 C1 00 00 00 06 EE CA 7E
RX: 08:32:09 7E A1 39 29 02 FF 1E 64 33 E6 E7 00 C4 02 C1 00 00 00 00 07 00 82 01 20 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 08 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 09 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 0A 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 0B 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 01 0C 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 35 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 36 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 36 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 17 F0 7ETX: 08:32:09 7E A0 14 02 FF 29 10 32 F5 E6 E6 00 C0 02 C1 00 00 00 07 67 DB 7E
Hi, You have just read the…
You have just read the association view that defines all available objects. You can add -o objects.xml to save it to the file. Then you don't need to read it multiple times.
You can see the results as a string after they are read.
zul8387
Hi, Thank you for your…
Thank you for your response. I have tried putting -o objects.xml at the end but no file is being created.
Hi, There seem to be 3561…
There seem to be 3561 objects. That is a huge amount. Reading the will take a long time. You just need to wait until the read is complete.
zul8387
Hi, Thank you for the…
Thank you for the clarification.
I just need to obtain meter reading. Is there any other way to shorten it? I tried to run it many times today but connection got cut off before i got all the 3651 objects to be completed.
Thank you in advance.
Hi, It's sad if there are…
It's sad if there are problems with the meter association view. It defines all the functionality that your meter can offer.
You can add only objects that you want to read by selecting "Edit" and "Add object".
Set the correct Logical name and object type. This is not the recommended way to go, but you can read the values that you want to read.
