  3. Index Was Outside The Bound of The Array
Index was outside the bound of the array
By sheryl.mahamood , 30 October, 2023
while try to access the meter using wrapper it shows an error
" Index was outside the bound of the array "
18:35:25 Send AARQ request.
TX: 00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF
18:35:26
RX: 00 01 00 01 00 01 00 12 61 10 A1 02 06 00 A2 03 02 01 01 A3 05 A1 03 02 01 02
2 years 10 months ago
Hi, There is an issue with…
There is an issue with the meter. The meter doesn't return the Application context name and that is mandatory. Without this information, client doesn't know if the data is ciphered or if logical or short name is used.
Ask the meter vendor if there is a firmware where this is fixed.
sheryl.mahamood
Thank you so much for your…
Thank you so much for your response. When I use a different meter is works well (the meter model is E570 Landis Gyr.) It's evident that the meter I used earlier is faulty.
