  3. Hexing HXF300 RS485
Hexing HXF300 RS485
Profile picture for user Cody_M
By Cody_M , 13 December, 2022
Please help me, I can't connect to the meter via rs 485 gives an error bar code of the meter 311102329 tell me what I missed? what am I doing wrong ?
Cody_M
3 years 10 months ago
The picture is compressed and I can't read the error message.
Cody_M
In reply to . by Cody_M
sorry for the quality of the
sorry for the quality of the picture here is an error message and rs485 pinout and optical port help me how to connect correctly to read the meter readings
Cody_M
Rs485
Rs485
Cody_M
Optical port
Optical port
Cody_M
Settings
Settings
Can you read the meter with an optical probe? The optical sensor cable should point straight down.
Try to change the address type from serial number to Default when connecting with an optical probe.
Cody_M
Thanks for the answer, I
Thanks for the answer, I managed to connect to the meter via usb rs485, I used those parameters in the pictures, but I could only read the serial number of the meter, but I need to read the active energy, but the obis code is not in the list of obis codes, I need to read this obis code 16.8.0 active energy help me how can i add obis code so i can read active energy meter model hxf 300
Cody_M
In reply to Thanks for the answer, I by Cody_M
Serial number Smart Meter
Serial number Smart Meter HXF300
Cody_M
1
1
Cody_M
2
2
Active energy should be found under register objects, not data objects. Try to find it there.
All the objects that you can access with current access rights are shown on the left side of the application.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
