  3. Landis&Gyr E450 - Python
Landis&Gyr E450 - python
By maestrone , 17 June, 2021
I try to read a landis&gyr e450 via RJ12 connection and i've got the following error-message. Any idea how i can fix this?
Regards
Steven
sudo python3 main.py -S /dev/ttyUSB1 -t Verbose
gurux_dlms version: 1.0.104
gurux_net version: 1.0.17
gurux_serial version: 1.0.15
ClientAddress: 0x10
Standard: Standard.DLMS
TX: 12:51:07 7E A0 07 03 21 93 0F 01 7E
RX: 12:51:22 80 7E A0 07............ cut off ........93 0F 01 7E
File "main.py", line 108, in main
File "/opt/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 529, in readAll
self.initializeConnection()
File "/opt/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 307, in initializeConnection
File "/opt/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 119, in readDLMSPacket
File "/opt/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 169, in readDLMSPacket2
raise e
File "/opt/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 162, in readDLMSPacket2
raise TimeoutException("Failed to receive reply from the device in given time.")
gurux_common.TimeoutException.TimeoutException: Failed to receive reply from the device in given time.
5 years 4 months ago
Meter has replied something, but you have cut it off, so I can't tell is that an echo.
Generated bytes look correct. You need to check your serial port settings.
Default values are 9600 8 None 1, but your meter might use something else.
Check also your cable connections. Wrong cable connections are causing a lot of work.
maestrone
Hi Mikko
Hi Mikko
Thank your for your fast answer, following the complete request:
ClientAddress: 0x10
TX: 14:38:46 7E A0 07 03 21 93 0F 01 7E
RX: 14:39:01 80 7E A0 07 03 21 93 0F 01 7E 80 80 00 78 FC 00 00 F8 80 80 F8 F8 F8 00 F8 80 00 80 80 00 F8 78 00 87 80 80 F8 80 F8 00 00 00 F8 00 78 00 00 00 00 F8 F8 00 00 F8 78 00 00 00 78 FC 80 00 00 F8 00 78 3C F0 80 00 78 00 07 00 7F 00 07 00 80 00 80 80 80 80 00 F8 F8 00 00 00 80 00 80 00 78 00 80 00 80 00 00 00 80 80 00 00 00 78 00 7F 3C F0 00 80 00 00 F8 78 00 78 C0 00 78 C0 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 78 00 7F 3C F0 00 80 00 00 F8 78 00 78 C0 00 78 C0 00 00 F8 F8 F8 00 78 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 C0 00 80 00 00 78 00 00 00 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 C0 00 80 00 00 80 00 00 00 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 C0 00 80 00 00 F8 00 00 00 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 00 00 78 FC 78 FC 80 80 80 80 00 78 FC 78 FC 80 80 80 F8 F8 F8 00 F8 80 00 00 F8 78 3C 00 F8 00 00 F8 00 80 00 00 00 00 F8 80 80 00 00 00 80 80 00 00 00 00 78 C0 00 80 00 00 78 00 00 00 80 00 78 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 C0 00 80 00 00 80 00 00 00 80 00 78 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 C0 00 80 00 00 F8 00 00 00 80 00 78 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 C0 00 80 00 00 78 00 00 00 78 00 00 F8 F8 F8 00 78 C0 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 C0 00 80 00 00 80 00 00 00 78 00 00 F8 F8 F8 00 78 C0 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 C0 00 80 00 00 F8 00 00 00 78 00 00 F8 F8 F8 00 78 C0 00 80 80 00 00 00 00 F8 F8 F8 00 F8 80 80 80 80 00 78 FC 78 3C 00 80 80 F8 F8 F8 00 F8 80 00 80 78 3C F0 00 00 00 F8 00 F8 00 00 00 00 F8 80 80 00 00 00 80 80 00 00 00 00 78 C0 00 80 00 00 78 00 00 00 80 00 78 00 F8 F8 F8 00 F8 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 C0 00 80 00 00 80 00 00 00 80 00 78 00 F8 F8 F8 00 F8 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 C0 00 80 00 00 F8 00 00 00 80 00 78 00 F8 F8 F8 00 F8 00 80 80 00 00 00 78 E0 00 80 00 00 F8 78 00 78 C0 00 78 C0 00 00 F8 F8 80 00 00 00 00 00 80 00 00 00 00 00 80 00 00 00 00 00 78 3C 00 00 00 00 00 78 3C 00 00 00 00 00 78 3E 00 00 00 00 00 78 00 07 00 7F 00 78 00 07 00 7F 00 78 00 07 00 7F 00 80 00 80 00 F8 00 78 FE 80 78 00 FF 80 00 80 00 80 00 F8 00 78 FC 80 78 00 FF 80 00 80 00 80 00 F8 00 00 80 78 00 FF F8 F8 80 80 00 F8 80 80 7E A0 07 03 21 93 0F 01 7E 80 80 00 78 FC 00 00 F8 80 80 F8 F8 F8 00 F8 80 00 80 80 00 F8 78 00 87 80 80 F8 80 F8 00 00 00 F8 00 78 00 00 00 00 F8 F8 00 00 F8 78 00 00 00 80 80 00 00 F8 00 78 3C F0 80 00 78 00 07 00 7F 00 07 00 80 00 80 80 80 F8 00 80 F8 F8 00 00 00 80 00 F8 78 00 78 00 F8 78 00 80 00 00 00 80 80 00 00 00 78 00 7F 3C F0 00 80 00 00 00 00 78 C0 00 78 C0 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 78 00 7F 3C F0 00 80 00 00 00 00 78 C0 00 78 C0 00 00 F8 F8 F8 00 78 00 80 80 00 00 00 80 00 00 00 80 80 00 00 78 00 78 C0 00 80 00 00 00 00 80 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 00 78 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 00 80 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 F8 F8 80 78 00 7F C0 80 80 80 00 78 FC F8 78 00 87 80 80 F8 F8 F8 00 F8 80 00 80 F8 F8 78 00 F8 00 00 F8 00 80 00 00 00 80 F8 F8 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 78 00 78 00 00 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 78 00 80 00 00 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 78 00 78 3C 00 00 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 00 F8 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 00 F8 80 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 C0 00 80 00 78 00 00 F8 00 80 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 78 C0 00 80 00 00 00 00 78 C0 00 78 C0 00 00 F8 F8 78 C0 00 00 00 78 3C FF 00 78 3C FF 00 00 80 78 C0 00 F8 00 80 F8 F8 80 80 80 80 00 78 FC F8 F8 80 80 80 F8 F8 F8 00 F8 80 00 80 F8 78 C0 00 80 00 00 F8 00 F8 00 00 00 80 80 80 F8 80 00 80 80 80 80 80 80 F8 F8 80 80 00 00 00 00 80 78 3C 0F 80 00 00 00 00 80 80 80 80 00 00 78 FC 78 FC 00 80 80 80 80 00 00 00 00 F8 F8 00 00 80 00 00 78 00 00 80 78 C0 00 80 80 00 00 F8 78 3C FF 80 80 00 00 00 80 80 80 00 00 80 00 00 80 F8 00 80 80 7E A0 07 03 21 93 0F 01 7E
raise e
maestrone
I ve got the following wiring
I ve got the following wiring schema:
Meter RJ12 > Cable > TSS721 Module Board M-BUS To TTL with RX TX Indicator STM32 Development Board > Cable > FTDI FT232RL > USB Port on tinkerboard
Any idea?
Regards
Stefan
This looks strange. There is a lot of echo messages. What USB to serial port converter are you using?
If you can connect from Windows can you try to connect with GXDLMSDirector?
Just select Landis+Gyr as a manufacturer and set correct serial port settings.
Hi Stefan,
Hi Stefan,
Have you connected to the M-BUS? M-Bus frames are totally different than HDLC frames.
maestrone
Next try, changing the serial
Next try, changing the serial speed to 2400,8,e,1.
My informations about the e450, the signal level is m-Bus (25 volt), the transport is HDLC - is that true or have to change my setup?
Regards
Stefan
ClientAddress: 0x10
TX: 08:23:42 7E A0 07 03 21 93 0F 01 7E
RX: 08:23:57 80 7E A0 07 03 21 93 0F 01 7E 80 80 00 78 FE 00 07 00 F8 80 80 F8 F8 F8 00 F8 80 00 80 80 00 F8 78 00 F8 80 80 F8 80 F8 00 00 00 F8 00 78 00 00 00 00 F8 F8 00 00 F8 78 00 80 78 E0 FC 00 F8 80 00 00 F8 00 78 1E FC 80 00 80 80 00 78 1E 00 00 00 F8 78 00 78 E0 00 F8 F8 00 00 00 80 00 F8 78 00 78 00 F8 78 00 80 00 00 00 80 80 00 00 00 78 00 78 E0 00 80 00 00 00 00 78 E0 00 78 E0 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 78 00 78 E0 00 80 00 00 00 00 78 E0 00 78 E0 00 00 F8 F8 F8 00 78 00 80 80 00 00 00 80 00 00 00 80 80 00 00 78 00 78 E0 00 80 00 00 00 00 80 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 00 78 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 00 80 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 00 F8 78 FE FC 80 00 80 80 80 80 00 78 FE FC 78 00 F8 80 80 F8 F8 F8 00 F8 80 00 80 F8 F8 78 00 F8 00 00 F8 00 80 00 00 00 80 F8 F8 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 78 00 78 00 00 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 78 00 80 00 00 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 78 00 78 1E 00 00 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 00 F8 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 00 F8 80 00 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 F8 00 78 E0 00 80 00 78 00 00 F8 00 80 F8 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 78 F0 00 80 00 00 00 00 78 E0 00 78 E0 00 00 F8 F8 78 E0 00 00 00 78 1E 00 78 1E 00 00 80 78 E0 00 F8 00 80 F8 F8 80 80 80 80 00 78 FE FC F8 80 80 80 F8 F8 F8 00 F8 80 00 80 F8 78 E0 00 80 00 00 F8 00 F8 00 00 00 80 80 80 F8 80 00 80 80 80 80 80 80 F8 F8 80 80 00 00 00 78 00 00 00 80 00 00 00 00 F8 F8 80 00 00 78 FE 78 FE 80 F8 F8 00 00 80 00 00 00 00 F8 F8 80 00 F8 80 00 00 78 00 F8 F8 80 78 FE C0 80 80 80 00 00 78 E0 FC 80 80 80 00 00 80 00 F8 80 80 00 00 F8 00 78 1E FC 80 78 E0 F8 80 80 7E A0 07 03 21 93 0F 01 7E 80 80 00 78 FE 00 07 00 F8 80 80 F8 F8 F8 00 F8 80 00 80 80 00 F8 78 00 F8 80 80 F8 80 F8 00 00 00 F8 00 78 00 00 00 00 F8 F8 00 00 F8 78 00 80 78 E0 FC 78 FE FC F8 00 00 F8 00 78 1E FC 80 00 80 80 00 78 1E 00 00 00 F8 78 00 80 00 F8 F8 00 00 00 80 00 80 00 78 00 80 00 80 00 00 00 80 80 00 00 00 78 00 78 E0 00 80 00 00 F8 78 00 78 E0 00 78 E0 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 78 00 78 E0 00 80 00 00 F8 78 00 78 E0 00 78 E0 00 00 F8 F8 F8 00 78 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 E0 00 80 00 00 78 00 00 00 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 E0 00 80 00 00 80 00 00 00 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 E0 00 80 00 00 F8 00 00 00 78 00 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 78 FE 00 F8 80 80 80 80 80 00 78 FE 3C FF 80 80 80 F8 F8 F8 00 F8 80 00 00 F8 78 1E C0 F8 00 00 F8 00 80 00 00 00 00 F8 80 80 00 00 00 80 80 00 00 00 00 78 E0 00 80 00 00 78 00 00 00 80 00 78 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 E0 00 80 00 00 80 00 00 00 80 00 78 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 E0 00 80 00 00 F8 00 00 00 80 00 78 00 F8 F8 F8 00 80 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 E0 00 80 00 00 78 00 00 00 78 00 00 F8 F8 F8 00 78 E0 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 E0 00 80 00 00 80 00 00 00 78 00 00 F8 F8 F8 00 78 E0 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 80 80 78 E0 00 80 00 00 F8 00 00 00 78 00 00 F8 F8 F8 00 78 E0 00 80 80 00 00 00 00 F8 F8 F8 00 F8 80 80 80 80 00 78 FE 3C 0F 00 80 80 F8 F8 F8 00 F8 80 00 80 78 1E FC 00 00 00 F8 00 F8 00 00 00 00 F8 80 80 00 00 00 80 80 00 00 00 00 78 E0 00 80 00 00 78 00 00 00 80 00 78 00 F8 F8 F8 00 F8 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 E0 00 80 00 00 80 00 00 00 80 00 78 00 F8 F8 F8 00 F8 00 80 80 00 00 00 80 00 00 00 80 80 00 00 00 00 78 E0 00 80 00 00 F8 00 00 00 80 00 78 00 F8 F8 F8 00 F8 00 80 80 00 00 00 78 E0 00 80 00 00 F8 78 00 78 E0 00 78 E0 00 00 F8 F8 80 00 00 00 00 00 80 00 00 00 00 00 80 00 00 00 00 00 78 1E 00 00 00 00 00 78 1F 00 00 00 00 00 78 1F 00 00 00 00 00 78 00 00 00 78 00 00 00 78 00 00 00 80 00 80 00 F8 00 78 FF 80 78 00 80 00 80 00 80 00 F8 00 78 FF 80 78 00 80 00 80 00 80 00 F8 00 00 80 78 00 F8 F8 80 80 00 F8 80 80 7E A0 07 03 21 93 0F 01 7E
Hi Stefan,
Hi Stefan,
You need to verify this from the meter vendor.
You are receiving sent data back and then there are extra bytes. I don't know what those extra bytes are.
maestrone
Thx for your replay, from the
Thx for your replay, from the electricity supplier i've got the following information:
OK, now I get this. You don't establish the connection with the meter. Meter is sending push messages. All you need to do is listen serial port with the correct serial port settings.
Check this. It will do what you want to do.
https://github.com/Gurux/Gurux.DLMS.Python/tree/master/Gurux.DLMS.Push…
There is an interval when push messages are sent. Start app with -t Verbose, so you can see the incoming bytes as a hex string. When the message starts with 7E, your serial port settings are correct.
maestrone
Hi Mikko
Hi Mikko
Thanks for your patient and your support.
I try every combination of speed/parity etc. > no success, i never got a 7E at the beginn
Regards
Stefan
/opt/Gurux.DLMS.Python/Gurux.DLMS.Push.Listener.Example.python# sudo python3 main.py -S /dev/ttyUSB1:2400:8EVEN1 -t Verbose
/dev/ttyUSB1:2400 8EVEN1
Press any key to close the application.
Media state changed. MediaState.OPENING
trace:13:27:27 TraceTypes.RECEIVED 00 FF
New data is received. /dev/ttyUSB1:00 FF
trace:13:27:28 TraceTypes.RECEIVED 7C
New data is received. /dev/ttyUSB1:7C
trace:13:27:28 TraceTypes.RECEIVED 00 00 8C FE 02 02 00 02 C4 C6 00 C0 00 00 00 00 00 60 0E 00
New data is received. /dev/ttyUSB1:00 00 8C FE 02 02 00 02 C4 C6 00 C0 00 00 00 00 00 60 0E 00
trace:13:27:28 TraceTypes.RECEIVED 02 06 C8 08 06 C0 04 00 00 08 12 00 FE 00 00 00 00 00
New data is received. /dev/ttyUSB1:02 06 C8 08 06 C0 04 00 00 08 12 00 FE 00 00 00 00 00
trace:13:27:28 TraceTypes.RECEIVED 00 00 00 00 00 00 00 00 04 00 00 10 00 00 FE 0E 00 00 00 00 00 00
New data is received. /dev/ttyUSB1:00 00 00 00 00 00 00 00 04 00 00 10 00 00 FE 0E 00 00 00 00 00 00
trace:13:27:28 TraceTypes.RECEIVED 00 00 00 00 04 00 00 10 00 00 FE 0E 00 00 00 00 00 00 00 00 02
New data is received. /dev/ttyUSB1:00 00 00 00 04 00 00 10 00 00 FE 0E 00 00 00 00 00 00 00 00 02
trace:13:27:29 TraceTypes.RECEIVED 00 04 00 00 00 00 00 FE 0E 00 00 00 00 00 00 00 00 02
New data is received. /dev/ttyUSB1:00 04 00 00 00 00 00 FE 0E 00 00 00 00 00 00 00 00 02
trace:13:27:29 TraceTypes.RECEIVED 00 04 00 00 00 00 00 FE 0E 00 00 00 00 00 00 00 00 02 00 04 00
New data is received. /dev/ttyUSB1:00 04 00 00 00 00 00 FE 0E 00 00 00 00 00 00 00 00 02 00 04 00
trace:13:27:29 TraceTypes.RECEIVED 00 00 00 00 FE 0E 00 00 00 00 00 0E 7C 7C 00 48 8C FE
New data is received. /dev/ttyUSB1:00 00 00 00 FE 0E 00 00 00 00 00 0E 7C 7C 00 48 8C FE
trace:13:27:29 TraceTypes.RECEIVED 02 02 00 E0 C0 80 00 00 00 00 18 00 00 00 00 02 00 04 00
New data is received. /dev/ttyUSB1:02 02 00 E0 C0 80 00 00 00 00 18 00 00 00 00 02 00 04 00
trace:13:27:29 TraceTypes.RECEIVED 00 00 00 00 FE 0E 00 00 00 00 00 00 00 00 02 00 04 00 00 00 00 00 FE
New data is received. /dev/ttyUSB1:00 00 00 00 FE 0E 00 00 00 00 00 00 00 00 02 00 04 00 00 00 00 00 FE
trace:13:27:29 TraceTypes.RECEIVED 0E 00 00 00 00 00 00 00 00 02 00 04 00 00 00 00 00 FE
New data is received. /dev/ttyUSB1:0E 00 00 00 00 00 00 00 00 02 00 04 00 00 00 00 00 FE
trace:13:27:29 TraceTypes.RECEIVED 0E 00 00 00 00 00 04 00 00 10 00 00 FE 04 00 1C 00 04 04 00 3E
New data is received. /dev/ttyUSB1:0E 00 00 00 00 00 04 00 00 10 00 00 FE 04 00 1C 00 04 04 00 3E
trace:13:27:29 TraceTypes.RECEIVED 62 80 04 00 00 3E 82 04 00 00 12 02 04 00 00 40 00 04 00 00 80
New data is received. /dev/ttyUSB1:62 80 04 00 00 3E 82 04 00 00 12 02 04 00 00 40 00 04 00 00 80
trace:13:27:29 TraceTypes.RECEIVED 10 46 82 7C
New data is received. /dev/ttyUSB1:10 46 82 7C
trace:13:27:33 TraceTypes.RECEIVED 7C
trace:13:27:33 TraceTypes.RECEIVED 00 00 8C FE 02 02 00 02 C4 C6 00 C0 00 00 00 00 00 60 0E 00
trace:13:27:33 TraceTypes.RECEIVED 02 06 C8 08 06 C0 04 00 00 08 12 0E FE 00 00 00 00 0C
New data is received. /dev/ttyUSB1:02 06 C8 08 06 C0 04 00 00 08 12 0E FE 00 00 00 00 0C
trace:13:27:34 TraceTypes.RECEIVED 00 0C 00 00 00 00 00 00 04 00 02 10 00 00 FE 0E 00 00 00 00 00 00
New data is received. /dev/ttyUSB1:00 0C 00 00 00 00 00 00 04 00 02 10 00 00 FE 0E 00 00 00 00 00 00
trace:13:27:34 TraceTypes.RECEIVED 00 00 00 00 04 00 02 10 00 00 FE 0E 00 00 00 00 00 00 00 00
New data is received. /dev/ttyUSB1:00 00 00 00 04 00 02 10 00 00 FE 0E 00 00 00 00 00 00 00 00
trace:13:27:34 TraceTypes.RECEIVED 00 00 04 00 00 10 00 00 FE 0E 04 00 00 00 00 00 00 00 00
New data is received. /dev/ttyUSB1:00 00 04 00 00 10 00 00 FE 0E 04 00 00 00 00 00 00 00 00
trace:13:27:34 TraceTypes.RECEIVED 00 04 00 00 10 00 00 FE 0E 04 00 00 00 00 00 00 00 00 00 04 00
Can you try to find the correct settings with GXDLMSDirector. Start it and select "Tools" and "Serial Monitor". Try different parameters until you can see messages starting with 7E.
Finding correct parameters is always the hardest part.
maestrone
Thx for your replay, i have
Thx for your replay, i have to organize a windows system
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
