  3. Gurux GXDLMSDirection Version 8.1.1807 Insufficient Memory Problem
Gurux GXDLMSDirection version 8.1.1807 Insufficient Memory problem
By Buddy , 14 September, 2018
I have used Gurux GXDLMSDirection version 8.1.1807. My meter used Texas Instrument DLMS library. When I connected to my meter with gurux director in lowest authentication (no authentication), we got 4 objects. We can read 3 other objects, but when I read clock object, I got error message Insufficient Memory
Why this problem can happen ? Can you guide us how to solve this problem?
Thank you.
8 years 1 month ago
Can you send a log to the forum. Just reading the clock messages is enough.
Buddy
8 years 1 month ago
The clock messages of Gurux GXDLMSDirection version 8.1.1807
Dear Mikko,
Thanks a lot for your reply.
Here is the clock messages as you requested :
18/09/2018 11:02:04Read object type Clock index: 2
<- 11:02:04 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 60 1A 7E
18/09/2018 11:02:04-> 11:02:04 7E A0 1D 21 03 52 85 6F E6 E7 00 C4 01 C1 00 09 07 D0 01 01 06 00 14 13 FF 01 A4 00 70 93 7E
Regards
Buddy
8 years 1 month ago
Dear Buddy,
Thanks to this. Date time value is D0010106001413. There are 9 bytes and there should be 12.
So date and time are not correct. First two bytes should be the year and this is not correct.
Your lib or meter is returning wrong data for some reason.
Buddy
8 years 1 month ago
In reply to Gurux GXDLMSDirection version 8.1.1807 Insufficient Memory by Kurumi
Dear Mikko,
Dear Mikko,
Thanks a lot for your analysis.
We have corrected the data from the meter, and we have no more Insufficient Memory issue now.
Best Regards
