By Samruddhi , 16 November, 2022 Forums DLMSDirector How to read DLMS meter data by using Secure Make Skyline E90 modem. both end static IP used. both end static IP used. Hi, Hi, The easiest way to get started is if you download GXDLMSDirector and try first to connect with it. Select "Indian standard" as the manufacturer and try to connect. BR, Mikko
