  3. Command Line Argument Example
Command line argument example
By lara.wakim , 1 September, 2020
Can you please give us an example of the command line arguments that we need to set in the project properties in order to select a proper serial com port?
Best Regards,
Lara Wakim
6 years ago
You can run it using arguments like:
-S SERIAL_PORT_NUMBER -t Verbose
SERIAL_PORT_NUMBER depends on the serial port that you want to use.
