  3. Command Line Argument Example
Command line argument example
By lara.wakim , 1 September, 2020
Can you please give us an example of the command line arguments that we need to set in the project properties in order to select a proper serial com port?
Best Regards,
Lara Wakim
6 years 2 months ago
You can run it using arguments like:
-S SERIAL_PORT_NUMBER -t Verbose
SERIAL_PORT_NUMBER depends on the serial port that you want to use.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
