By jpaa07 , 9 February, 2016 Forums DLMSDirector Hi, I have a question, Can I set some meter date with DLMS Director? Thank you. Set date with Gurux DLMSDirector Hi, Yes you can. Give new date and Press enter. Write button comes active after this. BR, Mikko Set date with Gurux DLMSDirector Hi, I give a new date on clock tab, and a warning yellow icon appears on the right and nothing change. Am I doing right? Thank you Mikko. Set date with Gurux DLMSDirector Hi, You should press write button. It's right from read button on toolbar. BR, Mikko Yes, it works ! Thank you Yes, it works ! Thank you
