  3. Reading ITRON SL7000
By mad974 , 2 February, 2016
I'm trying to read values of a SL7000 with Sync2000 but I failed.
My settings for Actaris(ITRON) SL7000:
- Start Protocol : DLMS
- Media : Serial RS485 Full duplex with 9600
- Authentication : Low
- Password : ABCDEFGH
- Client Address : 1
- Physical Server : 17
- Logical Server : 1
- Context application: LN
- HDLC addressing scheme : 4
- SL761xxxx
Code OBIS I'm trying to read 1.1.3.8.0.255 & 1.1.1.8.0.255. I know those values are not null
The qualities of them are good but the values still "0"
I don't understand....
thanks
mad974
10 years 4 months ago
The frame received by the
The frame received by the gateway sync2000:
14:09:53.779
Channel-2 =Tx=> 7E A0 0A 00 22 00 23 03 93 0A 01 7E
14:09:53.820
Channel-2 <=Rx= 7E A0 23 03 00 22 00 23 73 93 C7 81 80
Channel-2 <=Rx= 14 05 02 00 80 06 02 00 80 07
Channel-2 <=Rx= 04 00 00 00 01 08 04 00 00
Channel-2 <=Rx= 00 01 CE 6A 7E
Channel-2 -- SNRM Success
14:09:53.870
Channel-2 =Tx=> 7E A0 47 00 22 00 23 03 10 D0 5E E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 FF FF FF FF FF 6B E3 7E
14:09:53.969
Channel-2 <=Rx= 7E A0 53
Channel-2 <=Rx= 03 00 22 00 23 30 40 A6 E6 E7
Channel-2 <=Rx= 00 61 42 A1 09 06 07 60 85 74
Channel-2 <=Rx= 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07
Channel-2 <=Rx= 80 89 07 60 85 74 05 08 02 01 AA 0A 80 08 41 42 43 44 45
Channel-2 <=Rx= 46 47 48 BE 10 04 0E 08 00 06 5F 1F 04 00 00 30 1D 21 34 00 07 FA 42 7E
Channel-2 -- AARQ Success
Channel-2 Node 3 Getting OBIS 1.1.1.8.0.255
14:09:54.136
Channel-2 =Tx=> 7E A0 1C 00 22 00 23 03 32 8D 58 E6 E6 00 C0 01 81 00 03 01 01 01 08 00 FF 02 00 E2 3A 7E
14:09:54.199
Channel-2 <=Rx= 7E A0 18
Channel-2 <=Rx= 03 00 22 00 23 52 D0 57 E6 E7
Channel-2 <=Rx= 00 C4 01 81 00 06 00 2A 5B 1A
Channel-2 <=Rx= BE 27 7E
Channel-2 -- Get Success
Channel-2 Node 3 Getting OBIS 1.1.3.8.0.255
14:09:54.250
Channel-2 =Tx=> 7E A0 1C 00 22 00 23 03 54 BD 5E E6 E6 00 C0 01 81 00 03 01 01 03 08 00 FF 02 00 B4 32 7E
14:09:54.330
Channel-2 <=Rx= 7E A0 18 03 00 22 00 23 74 E4 13 E6 E7
Channel-2 <=Rx= 00 C4 01 81 00 06 00 02 56 F4
Channel-2 <=Rx= 4F 5C 7E
14:09:54.360
Channel-2 =Tx=> 7E A0 0A 00 22 00 23 03 53 06 C7 7E
14:09:54.400
Channel-2 <=Rx= 7E A0 0A 03 00 22 00 23 73 29 E5 7E
Channel-2 -- sendDisc Success
You should ask this from manufacturer of Sync2000 (Kalkitech), but I can see that you are reading Register "1.1.3.8.0.255" attribute 2. Meter returns value unsigned long 153332 (0x256F4).
This is value that you should see. We are making some changes for GXDLMSDirector for SL7000. You can try to read with it if you like to. New version is available latest tomorrow.
mad974
Thank you for your help but
Thank you for your help but where do you see the return of the value in the frame ?
how can I read the frame ?
edit: I will try with tre lastest version, no problem
Reply for read message is here. Value is last four bytes. Value type is Unsigned long (6).
mad974
OK, I will try tomorrow,
OK, I will try tomorrow, thank you
mad974
For you, the SL7000 and the
For you, the SL7000 and the sync2000 are communicating correctly ?
The association is good ?
We are not using sync2000. We have own software GXDLMSDirector that you can use to read your meter. Source codes are also available so you can make app like you want to.
New version (Version 8.0.0.5) from GXDLMSDirector is released just a minute ago.
We have fixed few Actaris issues. Actaris is a little bit problematic meter, because it supports DLMS,
but not compleate COSEM.
mauropiatti
I download new release of GXDLMSDirector. Very good job!
Now I can connect to SL7000 by serial com port.
I can read registers.
I need to read load profile by meter from DATE_START to DATE_END
With GXDLMSDirector I can read 0.0.99.1.0.255 Load profile with recording period 1
Where I can find information about read Load profile to understand data I receive?
Is there in your forum?
Profile Generics of SL7000 is causing us a lots of problems.
Load profile is imlemented custom way in SL6000 and ACE6000.
Data that you are receiving is collection of arrays.
You have to parse data by your self. We will try to find general solution for this because we are receiging so many inqueries from Actaris, but it will take some time.
You can read Actaris class from GXDLMSDirector and see it that helps.
There is a document of structure of profile generic data, but I can't remember it's name right now. :-)
mad974
From my part, the communication doesn't work between my laptop and the meter.
What did you do ? which paramaters did you fill in ?
thanks
SL7000
You should be able to connect if you select default settings as described here:
mad974
SL7000
Yes, I know this but no response...
SL7000
Are you using Sync2000 or GXDLMSDirector?
Are you using optical strobe or serial port connection?
mauropiatti
I've connect my RS232 PC to
I've connect my RS232 PC to RS232 on Itron SL7000 using a cable with RS232 and RJ45 connector
Connected pin 2,3,5
mad974
SL7000
hello,
I'm trying between my laptop (GXDLMSDirector) and the meter with the serial port.
Is it possible to try with the optical strobe ?
thanks
mad974
SL7000
Ok, thank you
log file reveived:
Log created 16:36:27
16:36:29 Initializing serial connection.
16:36:29 Send SNRM request.
7E A0 08 22 23 03 93 6D FB 7E
16:36:49 Failed to receive reply from the device in given time.
à GXDLMSDirector.GXDLMSDevice.InitializeConnection() dans C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:ligne 374
à GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) dans C:\Projects\GXDLMSDirector\Development\MainForm.cs:ligne 929
In reply to SL7000 by mad974
I believe that this is conficuration issue.
Try to change starting protocol to IEC. Is meter answering anything?
