  3. Itron SL700 Optical Port
Itron SL700 Optical port
By m2m , 28 January, 2016
Hello I can not login on Itron SL7000 through local optical port.
I use IEC protocol, I realized that even if I set the connection to 300 Baud, and subject to the speed profile is automatically updated to 9600 baud.
You have any suggestions.
I am attaching the log of communication.
Thank you
09:09:42 Initializing serial connection.
09:09:42 09:09:42.158 Info Opening
09:09:42 09:09:42.158 Info Serial Port Settings: Port Name: COM6 Baud Rate: 300 Data Bits: 7 Parity: Even Stop Bits: One Eop: None
09:09:42 09:09:42.643 Info Open
09:09:42 HDLC sending:/?!<CR><LF>
09:09:42 09:09:42.643 Sent 2F 3F 21 0D 0A
09:09:43 09:09:43.112 Received 2F
09:09:43 09:09:43.143 Received 2F
09:09:43 09:09:43.174 Received 41
09:09:43 09:09:43.221 Received 43
09:09:43 09:09:43.252 Received 45
09:09:43 09:09:43.284 Received 35
09:09:43 09:09:43.315 Received 5C
09:09:43 09:09:43.346 Received 32
09:09:43 09:09:43.377 Received 53
09:09:43 09:09:43.409 Received 4C
09:09:43 09:09:43.440 Received 37
09:09:43 09:09:43.487 Received 30
09:09:43 09:09:43.518 Received 30
09:09:43 09:09:43.549 Received 30
09:09:43 09:09:43.580 Received 2D
09:09:43 09:09:43.612 Received 49
09:09:43 09:09:43.643 Received 45
09:09:43 09:09:43.674 Received 43
09:09:43 09:09:43.705 Received 35
09:09:43 09:09:43.752 Received 0D
09:09:43 HDLC received: /ACE5\2SL7000-IEC5<CR><LF>
09:09:43 BaudRate is : 9600
09:09:43 Moving to mode E.
06 32 35 32 0D 0A
09:09:43 09:09:43.752 Sent 06 32 35 32 0D 0A
09:09:44 09:09:44.377 Received 06
09:09:44 09:09:44.377 Received 06 32
09:09:44 09:09:44.440 Info Closing
09:09:44 09:09:44.440 Received 35
09:09:44 09:09:44.580 Info Closed
09:09:44 09:09:44.580 Info Opening
09:09:44 09:09:44.580 Info Serial Port Settings: Port Name: COM6 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Eop: None
09:09:45 09:09:45.002 Info Open
09:09:45 Send SNRM request.
7E A0 08 06 07 07 93 E8 01 7E
09:09:45 09:09:45.018 Sent 7E A0 08 06 07 07 93 E8 01 7E
09:10:00 Failed to receive reply from the device in given time.
09:10:00 09:10:00.030 Sent 01 42 30 03 0D 0A
09:10:00 09:10:00.030 Info Closing
09:10:00 09:10:00.124 Info Closed
in GXDLMSDirector.GXDLMSDevice.InitializeConnection() in c:\Users\Administrator\Documents\Visual Studio 2013\Projects\GXDLMSDirector-master\GXDLMSDirector-master\Development\GXDLMSDevice.cs:riga 376
in GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) in c:\Users\Administrator\Documents\Visual Studio 2013\Projects\GXDLMSDirector-master\GXDLMSDirector-master\Development\MainForm.cs:riga 929
10 years 5 months ago
I hope that we have fixed this. We will release new version tomorrow.
m2m
Thank you for your support
Gurux.DLMS.GXDLMSException: Source addresses do not match. It is 16401. It should be 145.
in GXDLMSDirector.GXDLMSDevice.InitializeConnection() in C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:riga 374
in GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:riga 929
We are little bit late. We are just ending tests. New version is released today.
You do not receive that error anymore with new version.
m2m
Hello great job !
Hello great job !
Now I login on SL7000
Thank you
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
