  3. Landisgyr Meter
Landisgyr meter
By Zulu@eyabantup… , 16 February, 2026
hi Am trying to connect the Gurux GXDLMS Director to the landisgyr meter and it has a CU-XE communication module. There are no Obis codes in the software, and it says failed to receive reply from device. can you help? I can only connect with the MAP110 from landisgyr but with Gurux is giving me problems.
5 months 1 week ago
Hi, Select Landis+Gyr as a…
Select Landis+Gyr as a manufacturer. Then change the authentication level to None and try to connect. The OBIS codes are read from the meter after the connection is established.
