  2. Unable To Cast Object of Type Gurux.DLMS.GXStructure To Type Gurux.DLMS.GXArray
Unable to cast object of type Gurux.DLMS.GXStructure to type Gurux.DLMS.GXArray
By Karl, 1 April, 2026
After upgrading the Gurux.DLMS Nuget package from version 9.0.2508.2201 to 9.0.2603.3001, we get the error in the subject, when trying to read association view. I have tested this on EMH and LG E850 meters, but it might be an error that affects all metertypes.
ReadDataBlock(Client!.GetObjectsRequest(), reply);
Client.ParseObjects(reply.Data, false); <--- This throws the error.
Client is a GXDLMSSecureClient object.
The Exception I am getting:
Unable to cast object of type 'Gurux.DLMS.GXStructure' to type 'Gurux.DLMS.GXArray'.
System.InvalidCastException: Unable to cast object of type 'Gurux.DLMS.GXStructure' to type 'Gurux.DLMS.GXArray'.
at Gurux.DLMS.GXDLMSClient.ParseSNObjects(GXByteBuffer buff, Boolean onlyKnownObjects, Boolean ignoreInactiveObjects)
at Gurux.DLMS.GXDLMSClient.ParseObjects(GXByteBuffer data, Boolean onlyKnownObjects, Boolean ignoreInactiveObjects)
at Gurux.DLMS.GXDLMSClient.ParseObjects(GXByteBuffer data, Boolean onlyKnownObjects)
Karl
1 week 4 days ago
I have now tested some more…
I have now tested some more meter types, and it failes on these metertypes:
EMH LZQJ
LG E850
And it works on these metertypes:
CEWE Prometer 100
CEWE Premier 550
EMH SGM
MetCom
LG E360
I have not been able to test CEWE ProQ 100, as I currently do not have access to one of these meters.
1 week 4 days ago
Hi, There was an issue with…
There was an issue with short name referencing. This is now fixed to version 9.0.2604.0701.
Karl
1 week 4 days ago
Thanks Mikko! I just found…
Thanks Mikko!
I just found the problem 20 seconds before I was notified about your answer.
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
