  2. Register
gxdn
By Administrator , 23 January, 2018
Register object is used to save value with its associated scaler and unit.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Value
    Value of data object. Value type can be any kind of value type described on DLMS standard.
    Read attribute #3 before reading that value if you want to use the scaler to multiple read value.
  • 3. Scaler and unit.
    Used unit and the scaler of the value.
    Note! There is no default value and for this reason meter must handle this in preAction or postAction. This value is clear by default.
Actions
  • 1. Reset
    This action is used to reset value to default value.
Muhammad_23
8 months ago
48485i5
Rirkfmg GMC g
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
