  2. Bluetooth Option In Gurux.DLMS.Android.Net
Bluetooth option in Gurux.DLMS.Android.Net
By saraf_kshitiz , 7 October, 2025
Gurux DLMS for Android
Hi Mikko Sir,
As I saw the YouTube channel of Gurux, I came across this video: https://www.youtube.com/watch?v=hIh_iQ9LDx4
In this, a tutorial is shown for connecting to a meter using Bluetooth as Media. But, I am not able to find any such gurux android component on github which allows Bluetooth Media option.
Please guide.
Kshitiz
10 months 3 weeks ago
Hi Kshitiz, Bluetooth is…
Hi Kshitiz,
Bluetooth is implemented for Xamarin. Our customers haven't requested it for the Android Java, so it's not currently implemented in Android Studio.
saraf_kshitiz
10 months 2 weeks ago
Hi Mikko Sir, I understood…
Hi Mikko Sir,
I understood that Bluetooth Media is not currently implemented in Android Java.
I also tried to build and run the Xamarin component - https://github.com/Gurux/Gurux.Bluetooth.Android
But, there is no option for setting Device settings as said in the readme file.
Also, I manually added my device BLE Meter along with its UUIDs in devices.csv and then rebuilt the app. It shows the connection is opened but actually the connection is not opened and the "Send" button does not work when sending any data to the meter.
Please provide support.
Kshitiz
Hi Kshitiz, The device UUIDs…
Hi Kshitiz,
The device UUIDs must be added to the devices.csv, or the Bluetooth component doesn't know what services to use. If you can't send or receive data to the meter, your service UUID is wrong. Check that you are using the correct UUID.
saraf_kshitiz
Hi Mikko Sir, As we are not…
Hi Mikko Sir,
As we are not able to implement Bluetooth media successfully with Gurux Android, can we have a discussion over call for the required support & guidance?
Please mention any method you would like to communicate.
Kshitiz
Hi Kshitiz, Can you send the…
Hi Kshitiz,
Can you send the email to me? My email address is mikko kurunsaari
https://gurux.fi/AboutUs
saraf_kshitiz
Hi Mikko Sir, Sure. I've…
Hi Mikko Sir,
Sure. I've sent an email.
Kshitiz
  • DLMS Image Transfer: “byte must be in range(0, 256)” with 512-byte block size in Python
  • Connecting to meter using Wrapper
  • DLMS Server / Meter emulation in Golang library
  • Unknown Baudrate
  • negative indexing for custom method/attribute
