  2. Setting Up Agent
Setting up agent
By Note5 , 22 September, 2025
Gurux.DLMS.AMI
I have downloaded the agent zip folder and tried following to instructions to setup the agent as from the terminal output below
PS F:\PROJECTS\HARDWARE\POWER\agent_4.0.2409.1101> dotnet Gurux.DLMS.AMI.Agent.dll
starting Gurux.DLMS.Agent version 4.0.2409.1101
Welcome to use Gurux.DLMS.AMI.
Gurux.DLMS.AMI address: [https://localhost:8001]
https://185.239.208.202:8001
Enter agent name: [I-32]
Enter Personal Access Token:
D13B69E1D9C0A9FC3EB7956E7993416FFFC35A48E414330904170275BB3FCB4D
fail: Gurux.DLMS.AMI.Agent.Program[0]
The SSL connection could not be established, see inner exception.
I get that exception yet I can access the AMI I have installed online. Also is the Personal Access token same as the generated token in the agent add page?
11 months ago
Hi, Yes, PET is the token…
Yes, PET is the token you generated when you add the agent.
Check your URL. Read also this:
https://www.gurux.fi/Gurux.DLMS.AMI4/QuickStart
  • Connecting to meter using Wrapper
  • DLMS Server / Meter emulation in Golang library
  • Unknown Baudrate
  • negative indexing for custom method/attribute
  • System title
