  3. Broken Gurux.DLMS.Client.Example.python
By Gabriel Lira , 12 September, 2025
Some hours ago 1.0.190 version of Python lib was released. In coincidence, I tried to execute the example on it for the first time (following this post: https://www.gurux.fi/node/13678), but the example is returning errors and not executing.
As I check, the errors are in code places that was added or changed from 1.0.189 to 1.0.190. So, how this appears to be a bug in v1.0.190 I'm creating this post to notify.
Below the traceback:
File "C:\censored\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\main.py", line 37, in <module>
import gurux_dlms
File "C:\censored\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\__init__.py", line 41, in <module>
from ._GXAPDU import _GXAPDU
File "C:\censored\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 43, in <module>
from .TranslatorSimpleTags import TranslatorSimpleTags
File "C:\censored\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\TranslatorSimpleTags.py", line 3, in <module>
from .TranslatorGeneralTags import TranslatorGeneralTags
File "C:\censored\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\TranslatorGeneralTags.py", line 37, in <module>
class TranslatorGeneralTags(GXIntEnum):
File "C:\censored\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\TranslatorGeneralTags.py", line 66, in TranslatorGeneralTags
RESPONDING_AE_INVOCATION_ID = 0xAD
File "C:\censored\AppData\Local\Programs\Python\Python311\Lib\enum.py", line 405, in __setitem__
raise TypeError('%r already defined as %r' % (key, self[key]))
TypeError: 'RESPONDING_AE_INVOCATION_ID' already defined as 167
1 year ago
Hi Gabriel Lira, Thank you…
Hi Gabriel Lira,
Thank you for pointing this out. This is now fixed to version 1.0.191, and your name is added to the credits.
