  3. Apator OTUS1 Reading Via WRAPPER
Apator OTUS1 reading via WRAPPER
By hasimalpkaya , 9 September, 2025
Iam trying to read Apator OTUS meter via Wrapper.
I have security packages and manufacturer tool, but I can not read the meter so far.
I can read some objects trough public association, but I need to read management association.
I can read the configuration of meter via maanufacturer tool and I can see the management access is HLSGMAC and client address etc. But I can not manege the gurux settings.
Could you please help.
I can share the communication log of manufacturer tool by e mail.
Many thanks
1 year ago
Hi, Change the…
Change the authentication level and client address. Then select the "Secured connections" tab, set the system title, and correct keys. If your meter is using a ciphered connection, change Security from "None" to "AuthenticationEncryption".
hasimalpkaya
1 year ago
Hi Mikko Thanks for the…
Hi Mikko
Thanks for the reply
I have changed authentication level and client address and still no success.
I have below keys,
<assoc name="managed">
<keys>
<key name="authentication" hexvalue="F48070DB862385FA66F527EC7A557916" />
<key name="broadcast" hexvalue="F1DEAF2FE47D0D8684FCA3162B9B8E25" />
<key name="unicast" hexvalue="089A4A6B3851F82115B31173AD675DDA" />
<key name="master" hexvalue="82D9DC4BC25315699D5FFA49FED1B363" />
</keys>
<password type="HLS_GMAC" hexvalue="74654A584D363271" />
and I filled secured tab according to above info.
If you like I can share coomunication log of manufacturer tool.
([email address removed])
Iam missing smth but what :).
You can see the my settings below.
https://imgur.com/a/eNd0DqM
Best Regards
Hasim
1 year ago
Hi Hasim, Remove pre…
Hi Hasim,
Remove pre-established system title. I believe that your meter is not supporting pre-established connections.
If it still fails, add the first three messages from the communication tool so I can check the correct settings for you.
hasimalpkaya
1 year ago
Hi Mikko, If I remove pre…
If I remove pre-established system title, the gurux give "object reference not set to an instance of an object" warning.
Please see below the lines from log of manufacturer tool
[2025/09/11 15:05:26.720] [INFO] - [TCP.INIT]
[2025/09/11 15:05:26.720] [INFO] - Parameters initialized - receiveTimeout: 60000, sendTimeout: 60000
[2025/09/11 15:05:26.720] [INFO] - [/TCP.INIT]
[2025/09/11 15:05:26.821] [INFO] - [TCP.OPEN]
[2025/09/11 15:05:26.822] [INFO] - Communication port is opened.
[2025/09/11 15:05:26.822] [INFO] - [/TCP.OPEN]
[2025/09/11 15:05:26.823] [INFO] - [COSEM.SEND]
[2025/09/11 15:05:26.823] [INFO] - Connecting... CosemProtocol[client=PUBLIC;context=LN]
[2025/09/11 15:05:26.824] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<AssociationRequest>
<ApplicationContextName>LN</ApplicationContextName>
<InitiateRequest>
<ProposedDlmsVersionNumber>6</ProposedDlmsVersionNumber>
<ProposedConformance>Attribute0SupportedWithSet PriorityMgmtSupported Attribute0SupportedWithGet BlockTransferWithGetOrRead BlockTransferWithSetOrWrite BlockTransferWithAction MultipleReferences InformationReport DataNotification Access ParametrizedAccess Get Set SelectiveAccess EventNotification Action</ProposedConformance>
<ClientMaxReceivePduSize>65535</ClientMaxReceivePduSize>
</InitiateRequest>
</AssociationRequest>
[2025/09/11 15:05:26.824] [INFO] - send_frame_type=aarq
[2025/09/11 15:05:26.824] [INFO] - send_frame=601DA109060760857405080101BE10040E01000000065F1F040000FFFFFFFF
[2025/09/11 15:05:26.825] [INFO] - [/COSEM.SEND]
[2025/09/11 15:05:26.825] [INFO] - [WRAPPER.SEND]
[2025/09/11 15:05:26.825] [INFO] - ver=1 server=16 client=1 data_len=31 data=601DA109060760857405080101BE10040E01000000065F1F040000FFFFFFFF
[2025/09/11 15:05:26.826] [INFO] - [/WRAPPER.SEND]
[2025/09/11 15:05:26.827] [INFO] - [TCP.SEND]
[2025/09/11 15:05:26.827] [INFO] - 000100100001001F601DA109060760857405080101BE10040E01000000065F1F040000FFFFFFFF
[2025/09/11 15:05:26.828] [INFO] - [/TCP.SEND]
[2025/09/11 15:05:27.185] [INFO] - [TCP.RECEIVED]
[2025/09/11 15:05:27.186] [INFO] - 000100010010002B
[2025/09/11 15:05:27.187] [INFO] - [/TCP.RECEIVED]
[2025/09/11 15:05:27.188] [INFO] - [TCP.RECEIVED]
[2025/09/11 15:05:27.188] [INFO] - 6129A109060760857405080101A203020100A305A103020100BE10040E0800065F1F040000121401800007
[2025/09/11 15:05:27.188] [INFO] - [/TCP.RECEIVED]
[2025/09/11 15:05:27.189] [INFO] - [WRAPPER.RECEIVED]
[2025/09/11 15:05:27.189] [INFO] - ver=1 server=1 client=16 data_len=43 data=6129A109060760857405080101A203020100A305A103020100BE10040E0800065F1F040000121401800007
[2025/09/11 15:05:27.189] [INFO] - [/WRAPPER.RECEIVED]
[2025/09/11 15:05:27.189] [INFO] - [COSEM.RECEIVED]
[2025/09/11 15:05:27.189] [INFO] - received_frame=6129A109060760857405080101A203020100A305A103020100BE10040E0800065F1F040000121401800007
[2025/09/11 15:05:27.190] [INFO] - received_frame_type=aare
[2025/09/11 15:05:27.190] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<AssociationResponse>
<AssociationResult>0</AssociationResult>
<ResultSourceDiagnostic>
<ACSEServiceUser>NO_DIAGNOSTICS_PROVIDED</ACSEServiceUser>
</ResultSourceDiagnostic>
<InitiateResponse>
<NegotiatedDlmsVersionNumber>6</NegotiatedDlmsVersionNumber>
<NegotiatedConformance>BlockTransferWithGetOrRead MultipleReferences Get SelectiveAccess</NegotiatedConformance>
<ServerMaxReceivePduSize>384</ServerMaxReceivePduSize>
<VaaName>7</VaaName>
</InitiateResponse>
</AssociationResponse>
[2025/09/11 15:05:27.190] [INFO] - Connected
[2025/09/11 15:05:27.191] [INFO] - [/COSEM.RECEIVED]
[2025/09/11 15:05:27.191] [INFO] - [COSEM.SEND]
[2025/09/11 15:05:27.191] [INFO] - DoTransactionGetRequest class=1;obis=0.0.42.0.0.255;attribute=2
[2025/09/11 15:05:27.191] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetRequest>
<GetRequestNormal>
<InvokeIdAndPriority>193</InvokeIdAndPriority>
<AttributeDescriptor>
<ClassId>1</ClassId>
<!--0.0.42.0.0.255-->
<InstanceId>00002A0000FF</InstanceId>
<AttributeId>2</AttributeId>
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
[2025/09/11 15:05:27.191] [INFO] - send_frame_type=getRequest_NORMAL
[2025/09/11 15:05:27.192] [INFO] - send_frame=C001C1000100002A0000FF0200
[2025/09/11 15:05:27.192] [INFO] - [/COSEM.SEND]
[2025/09/11 15:05:27.192] [INFO] - [WRAPPER.SEND]
[2025/09/11 15:05:27.192] [INFO] - ver=1 server=16 client=1 data_len=13 data=C001C1000100002A0000FF0200
[2025/09/11 15:05:27.192] [INFO] - [/WRAPPER.SEND]
[2025/09/11 15:05:27.193] [INFO] - [TCP.SEND]
[2025/09/11 15:05:27.193] [INFO] - 000100100001000DC001C1000100002A0000FF0200
[2025/09/11 15:05:27.193] [INFO] - [/TCP.SEND]
[2025/09/11 15:05:27.359] [INFO] - [TCP.RECEIVED]
[2025/09/11 15:05:27.359] [INFO] - 0001000100100016
[2025/09/11 15:05:27.360] [INFO] - [/TCP.RECEIVED]
[2025/09/11 15:05:27.360] [INFO] - [TCP.RECEIVED]
[2025/09/11 15:05:27.360] [INFO] - C401C10009104150414F545553313535303034333934
[2025/09/11 15:05:27.360] [INFO] - [WRAPPER.RECEIVED]
[2025/09/11 15:05:27.360] [INFO] - ver=1 server=1 client=16 data_len=22 data=C401C10009104150414F545553313535303034333934
[2025/09/11 15:05:27.361] [INFO] - [/WRAPPER.RECEIVED]
[2025/09/11 15:05:27.361] [INFO] - [COSEM.RECEIVED]
[2025/09/11 15:05:27.361] [INFO] - received_frame=C401C10009104150414F545553313535303034333934
[2025/09/11 15:05:27.361] [INFO] - received_frame_type=getResponse_NORMAL
[2025/09/11 15:05:27.362] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetResponse>
<GetResponseNormal>
<Result>
<DataAccessResult>Success</DataAccessResult>
<Data>09104150414F545553313535303034333934</Data>
</Result>
</GetResponseNormal>
</GetResponse>
[2025/09/11 15:05:27.362] [INFO] - received_frame_status=DATA_ACCESS_RESULT_SUCCESS (0x00)
[2025/09/11 15:05:27.362] [INFO] - [/COSEM.RECEIVED]
[2025/09/11 15:05:27.362] [INFO] - [COSEM.SEND]
[2025/09/11 15:05:27.363] [INFO] - DoTransactionGetRequest class=1;obis=0.0.96.81.11.255;attribute=2
[2025/09/11 15:05:27.363] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetRequest>
<GetRequestNormal>
<!--0.0.96.81.11.255-->
<InstanceId>000060510BFF</InstanceId>
</GetRequestNormal>
</GetRequest>
[2025/09/11 15:05:27.363] [INFO] - send_frame_type=getRequest_NORMAL
[2025/09/11 15:05:27.363] [INFO] - send_frame=C001C10001000060510BFF0200
[2025/09/11 15:05:27.363] [INFO] - [/COSEM.SEND]
[2025/09/11 15:05:27.364] [INFO] - [WRAPPER.SEND]
[2025/09/11 15:05:27.364] [INFO] - ver=1 server=16 client=1 data_len=13 data=C001C10001000060510BFF0200
[2025/09/11 15:05:27.364] [INFO] - [/WRAPPER.SEND]
[2025/09/11 15:05:27.364] [INFO] - [TCP.SEND]
[2025/09/11 15:05:27.365] [INFO] - 000100100001000DC001C10001000060510BFF0200
[2025/09/11 15:05:27.365] [INFO] - [/TCP.SEND]
[2025/09/11 15:05:27.549] [INFO] - [TCP.RECEIVED]
[2025/09/11 15:05:27.551] [INFO] - 0001000100100005
[2025/09/11 15:05:27.551] [INFO] - [/TCP.RECEIVED]
[2025/09/11 15:05:27.552] [INFO] - [TCP.RECEIVED]
[2025/09/11 15:05:27.553] [INFO] - C401C10104
[2025/09/11 15:05:27.553] [INFO] - [/TCP.RECEIVED]
BR
Hasim
1 year ago
Hi Hasim, Your application…
Hi Hasim,
Your application is using public authentication and not the GMAC to read the data.
You can try to add an object manually if it's missing from the association view. Select "Edit" and "Add object". Then select Data from the dropdown and set Logican Name to 0.0.96.81.11.255.
hasimalpkaya
1 year ago
Hi Mikko, Please see…
Please see additional log below.
I think meter starts with public associations and countinue with management.
I can read some limited data with public, not all data.
Could you please check below lines if possible?
[2025/09/12 10:59:54.041] [INFO] - [TCP.INIT]
[2025/09/12 10:59:54.042] [INFO] - Parameters initialized - receiveTimeout: 60000, sendTimeout: 60000
[2025/09/12 10:59:54.042] [INFO] - [/TCP.INIT]
[2025/09/12 10:59:54.403] [INFO] - [TCP.OPEN]
[2025/09/12 10:59:54.404] [INFO] - Communication port is opened.
[2025/09/12 10:59:54.405] [INFO] - [/TCP.OPEN]
[2025/09/12 10:59:54.405] [INFO] - [COSEM.SEND]
[2025/09/12 10:59:54.406] [INFO] - Connecting... CosemProtocol[client=MANAGED;context=LN_CIPHERING]
[2025/09/12 10:59:54.407] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<ApplicationContextName>LN_CIPHERING</ApplicationContextName>
<CallingAPTitle>444E563031323335</CallingAPTitle>
<CallingAEInvocationId>48416C706B617961</CallingAEInvocationId>
<SenderACSERequirements>1</SenderACSERequirements>
<MechanismName>HIGH_LEVEL_SECURITY_GMAC</MechanismName>
<CallingAuthenticationValue>BC6F9A6A7D572C09A1D4F022BAE466CCB9E6303F582FAE3E34B57FCA0E0E37090B64708BFD067F3FDB994B8287DE686DA338D725A9DD37298A245A41B3488A09</CallingAuthenticationValue>
<GloInitiateRequest>
<SecurityControl>48</SecurityControl>
<InvocationCounter>7</InvocationCounter>
<CipheredData>58B6E775822B214A86315369161BE022865A8024DB56AF6D760E</CipheredData>
</GloInitiateRequest>
[2025/09/12 10:59:54.407] [INFO] - send_frame_type=aarq
[2025/09/12 10:59:54.407] [INFO] - send_frame=608199A109060760857405080103A60A0408444E563031323335A90A040848416C706B6179618A0207808B0760857405080205AC428040BC6F9A6A7D572C09A1D4F022BAE466CCB9E6303F582FAE3E34B57FCA0E0E37090B64708BFD067F3FDB994B8287DE686DA338D725A9DD37298A245A41B3488A09BE230421211F300000000758B6E775822B214A86315369161BE022865A8024DB56AF6D760E
[2025/09/12 10:59:54.408] [INFO] - [/COSEM.SEND]
[2025/09/12 10:59:54.408] [INFO] - [WRAPPER.SEND]
[2025/09/12 10:59:54.409] [INFO] - ver=1 server=1 client=1 data_len=156 data=608199A109060760857405080103A60A0408444E563031323335A90A040848416C706B6179618A0207808B0760857405080205AC428040BC6F9A6A7D572C09A1D4F022BAE466CCB9E6303F582FAE3E34B57FCA0E0E37090B64708BFD067F3FDB994B8287DE686DA338D725A9DD37298A245A41B3488A09BE230421211F300000000758B6E775822B214A86315369161BE022865A8024DB56AF6D760E
[2025/09/12 10:59:54.409] [INFO] - [/WRAPPER.SEND]
[2025/09/12 10:59:54.410] [INFO] - [TCP.SEND]
[2025/09/12 10:59:54.410] [INFO] - 000100010001009C608199A109060760857405080103A60A0408444E563031323335A90A040848416C706B6179618A0207808B0760857405080205AC428040BC6F9A6A7D572C09A1D4F022BAE466CCB9E6303F582FAE3E34B57FCA0E0E37090B64708BFD067F3FDB994B8287DE686DA338D725A9DD37298A245A41B3488A09BE230421211F300000000758B6E775822B214A86315369161BE022865A8024DB56AF6D760E
[2025/09/12 10:59:54.411] [INFO] - [/TCP.SEND]
[2025/09/12 10:59:54.734] [INFO] - [TCP.RECEIVED]
[2025/09/12 10:59:54.735] [INFO] - 000100010001009C
[2025/09/12 10:59:54.735] [INFO] - [/TCP.RECEIVED]
[2025/09/12 10:59:54.736] [INFO] - [TCP.RECEIVED]
[2025/09/12 10:59:54.736] [INFO] - 618199A109060760857405080103A203020100A305A10302010EA40A0408415041EC14031B7A88020780890760857405080205AA428040F7958F36715DB6B01C9FE25EA5FC986B0F9D8BA77929FE5F2F80CE2C10D696FF65524D1BB66F57000112D66FC6E02AC10396F958684855828451CBF8EB3892D7BE230421281F30000002C97A80945EC07344DEB33BF249275B996853A5E14CADB2DF2AB729
[2025/09/12 10:59:54.737] [INFO] - [/TCP.RECEIVED]
[2025/09/12 10:59:54.737] [INFO] - [WRAPPER.RECEIVED]
[2025/09/12 10:59:54.738] [INFO] - ver=1 server=1 client=1 data_len=156 data=618199A109060760857405080103A203020100A305A10302010EA40A0408415041EC14031B7A88020780890760857405080205AA428040F7958F36715DB6B01C9FE25EA5FC986B0F9D8BA77929FE5F2F80CE2C10D696FF65524D1BB66F57000112D66FC6E02AC10396F958684855828451CBF8EB3892D7BE230421281F30000002C97A80945EC07344DEB33BF249275B996853A5E14CADB2DF2AB729
[2025/09/12 10:59:54.738] [INFO] - [/WRAPPER.RECEIVED]
[2025/09/12 10:59:54.739] [INFO] - [COSEM.RECEIVED]
[2025/09/12 10:59:54.739] [INFO] - received_frame=618199A109060760857405080103A203020100A305A10302010EA40A0408415041EC14031B7A88020780890760857405080205AA428040F7958F36715DB6B01C9FE25EA5FC986B0F9D8BA77929FE5F2F80CE2C10D696FF65524D1BB66F57000112D66FC6E02AC10396F958684855828451CBF8EB3892D7BE230421281F30000002C97A80945EC07344DEB33BF249275B996853A5E14CADB2DF2AB729
[2025/09/12 10:59:54.740] [INFO] - received_frame_type=aare
[2025/09/12 10:59:54.740] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<ACSEServiceUser>AUTHENTICATION_REQUIRED</ACSEServiceUser>
<RespondingAPTitle>415041EC14031B7A</RespondingAPTitle>
<ResponderACSERequirement>1</ResponderACSERequirement>
<RespondingAuthenticationValue>F7958F36715DB6B01C9FE25EA5FC986B0F9D8BA77929FE5F2F80CE2C10D696FF65524D1BB66F57000112D66FC6E02AC10396F958684855828451CBF8EB3892D7</RespondingAuthenticationValue>
<GloInitiateResponse>
<InvocationCounter>713</InvocationCounter>
<CipheredData>7A80945EC07344DEB33BF249275B996853A5E14CADB2DF2AB729</CipheredData>
</GloInitiateResponse>
[2025/09/12 10:59:54.741] [INFO] - ciph_invocation_counter=0x2C9
[2025/09/12 10:59:54.741] [INFO] - [/COSEM.RECEIVED]
[2025/09/12 10:59:54.742] [INFO] - [COSEM.SEND]
[2025/09/12 10:59:54.742] [INFO] - DoTransactionActionRequest class=15;obis=0-0:40.0.0.255;method=1;optionalData=09111000000008399E5A0FD1A77487B45A4FA1
[2025/09/12 10:59:54.742] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<ActionRequest>
<ActionRequestNormal>
<MethodDescriptor>
<ClassId>15</ClassId>
<!--0.0.40.0.0.255-->
<InstanceId>0000280000FF</InstanceId>
<MethodId>1</MethodId>
</MethodDescriptor>
<MethodInvocationParameters>09111000000008399E5A0FD1A77487B45A4FA1</MethodInvocationParameters>
</ActionRequestNormal>
</ActionRequest>
[2025/09/12 10:59:54.743] [INFO] - send_frame_type=actionRequest_NORMAL
[2025/09/12 10:59:54.743] [INFO] - send_frame=C301C1000F0000280000FF010109111000000008399E5A0FD1A77487B45A4FA1
[2025/09/12 10:59:54.744] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<glo_ActionRequest>
<InvocationCounter>8</InvocationCounter>
<CipheredData>5386A5F89CE03155EAB9F892CA7E966ADB3D303108804480A054306AE763FB051A95DBCCC531A2A47D53249B</CipheredData>
</glo_ActionRequest>
[2025/09/12 10:59:54.744] [INFO] - ciph_frame_counter=0x8
[2025/09/12 10:59:54.744] [INFO] - send_frame_type=glo_actionRequest
[2025/09/12 10:59:54.745] [INFO] - send_frame=CB3130000000085386A5F89CE03155EAB9F892CA7E966ADB3D303108804480A054306AE763FB051A95DBCCC531A2A47D53249B
[2025/09/12 10:59:54.745] [INFO] - [/COSEM.SEND]
[2025/09/12 10:59:54.746] [INFO] - [WRAPPER.SEND]
[2025/09/12 10:59:54.746] [INFO] - ver=1 server=1 client=1 data_len=51 data=CB3130000000085386A5F89CE03155EAB9F892CA7E966ADB3D303108804480A054306AE763FB051A95DBCCC531A2A47D53249B
[2025/09/12 10:59:54.747] [INFO] - [/WRAPPER.SEND]
[2025/09/12 10:59:54.747] [INFO] - [TCP.SEND]
[2025/09/12 10:59:54.748] [INFO] - 0001000100010033CB3130000000085386A5F89CE03155EAB9F892CA7E966ADB3D303108804480A054306AE763FB051A95DBCCC531A2A47D53249B
[2025/09/12 10:59:54.748] [INFO] - [/TCP.SEND]
[2025/09/12 10:59:54.957] [INFO] - [TCP.RECEIVED]
[2025/09/12 10:59:54.960] [INFO] - 000100010001002C
[2025/09/12 10:59:54.961] [INFO] - [/TCP.RECEIVED]
[2025/09/12 10:59:54.961] [INFO] - [TCP.RECEIVED]
[2025/09/12 10:59:54.961] [INFO] - CF2A30000002CA1AE45F2361E6D8C345251F42E4FED3F9C6F66AADAA0A35ED74EEA64F1CA79A2C622304A8CC
[2025/09/12 10:59:54.962] [INFO] - [WRAPPER.RECEIVED]
[2025/09/12 10:59:54.962] [INFO] - ver=1 server=1 client=1 data_len=44 data=CF2A30000002CA1AE45F2361E6D8C345251F42E4FED3F9C6F66AADAA0A35ED74EEA64F1CA79A2C622304A8CC
[2025/09/12 10:59:54.962] [INFO] - [/WRAPPER.RECEIVED]
[2025/09/12 10:59:54.962] [INFO] - [COSEM.RECEIVED]
[2025/09/12 10:59:54.962] [INFO] - received_frame=CF2A30000002CA1AE45F2361E6D8C345251F42E4FED3F9C6F66AADAA0A35ED74EEA64F1CA79A2C622304A8CC
[2025/09/12 10:59:54.963] [INFO] - received_frame_type=glo_actionResponse
[2025/09/12 10:59:54.963] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<glo_ActionResponse>
<InvocationCounter>714</InvocationCounter>
<CipheredData>1AE45F2361E6D8C345251F42E4FED3F9C6F66AADAA0A35ED74EEA64F1CA79A2C622304A8CC</CipheredData>
</glo_ActionResponse>
[2025/09/12 10:59:54.963] [INFO] - ciph_invocation_counter=0x2CA
[2025/09/12 10:59:54.963] [INFO] - received_frame=C701C1000100091110000002CAA59A9ECD583786D90B090B32
[2025/09/12 10:59:54.964] [INFO] - received_frame_type=actionResponse_NORMAL
[2025/09/12 10:59:54.964] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<ActionResponse>
<ActionResponseNormal>
<Result>Success</Result>
<ReturnParameters>
<Data>091110000002CAA59A9ECD583786D90B090B32</Data>
</ReturnParameters>
</ActionResponseNormal>
</ActionResponse>
[2025/09/12 10:59:54.964] [INFO] - received_frame_status=DATA_ACCESS_RESULT_SUCCESS (0x00)
[2025/09/12 10:59:54.965] [INFO] - received_frame_status=DATA_ACCESS_RESULT_SUCCESS (0x00)
[2025/09/12 10:59:54.965] [INFO] - Connected
[2025/09/12 10:59:55.258] [INFO] - [/COSEM.RECEIVED]
[2025/09/12 10:59:55.259] [INFO] - [COSEM.SEND]
[2025/09/12 10:59:55.259] [INFO] - DoTransactionGetRequestWithList
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=2
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=3
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=4
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=5
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=6
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=7
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=8
[2025/09/12 10:59:55.259] [INFO] - class=8;obis=0.0.1.0.0.255;attribute=9
[2025/09/12 10:59:55.259] [INFO] - class=3;obis=1.0.1.8.0.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.8.1.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.8.2.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.8.3.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.8.4.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.8.5.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.8.6.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.29.0.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.29.1.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.29.2.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.29.3.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.29.4.255;attribute=2
[2025/09/12 10:59:55.260] [INFO] - class=3;obis=1.0.1.29.5.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.1.29.6.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.8.0.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.8.1.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.8.2.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.8.3.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.8.4.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.8.5.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.8.6.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.29.0.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.29.1.255;attribute=2
[2025/09/12 10:59:55.261] [INFO] - class=3;obis=1.0.2.29.2.255;attribute=2
[2025/09/12 10:59:55.262] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetRequest>
<GetRequestWithList>
<AttributeDescriptorList>
<AttributeDescriptorWithSelection>
<ClassId>8</ClassId>
<!--0.0.1.0.0.255-->
<InstanceId>0000010000FF</InstanceId>
</AttributeDescriptorWithSelection>
<AttributeId>3</AttributeId>
<AttributeId>4</AttributeId>
<AttributeId>5</AttributeId>
<AttributeId>6</AttributeId>
<AttributeId>7</AttributeId>
<AttributeId>8</AttributeId>
<AttributeId>9</AttributeId>
<ClassId>3</ClassId>
<!--1.0.1.8.0.255-->
<InstanceId>0100010800FF</InstanceId>
<!--1.0.1.8.1.255-->
<InstanceId>0100010801FF</InstanceId>
<!--1.0.1.8.2.255-->
<InstanceId>0100010802FF</InstanceId>
<!--1.0.1.8.3.255-->
<InstanceId>0100010803FF</InstanceId>
<!--1.0.1.8.4.255-->
<InstanceId>0100010804FF</InstanceId>
<!--1.0.1.8.5.255-->
<InstanceId>0100010805FF</InstanceId>
<!--1.0.1.8.6.255-->
<InstanceId>0100010806FF</InstanceId>
<!--1.0.1.29.0.255-->
<InstanceId>0100011D00FF</InstanceId>
<!--1.0.1.29.1.255-->
<InstanceId>0100011D01FF</InstanceId>
<!--1.0.1.29.2.255-->
<InstanceId>0100011D02FF</InstanceId>
<!--1.0.1.29.3.255-->
<InstanceId>0100011D03FF</InstanceId>
<!--1.0.1.29.4.255-->
<InstanceId>0100011D04FF</InstanceId>
<!--1.0.1.29.5.255-->
<InstanceId>0100011D05FF</InstanceId>
<!--1.0.1.29.6.255-->
<InstanceId>0100011D06FF</InstanceId>
<!--1.0.2.8.0.255-->
<InstanceId>0100020800FF</InstanceId>
<!--1.0.2.8.1.255-->
<InstanceId>0100020801FF</InstanceId>
<!--1.0.2.8.2.255-->
<InstanceId>0100020802FF</InstanceId>
<!--1.0.2.8.3.255-->
<InstanceId>0100020803FF</InstanceId>
<!--1.0.2.8.4.255-->
<InstanceId>0100020804FF</InstanceId>
<!--1.0.2.8.5.255-->
<InstanceId>0100020805FF</InstanceId>
<!--1.0.2.8.6.255-->
<InstanceId>0100020806FF</InstanceId>
<!--1.0.2.29.0.255-->
<InstanceId>0100021D00FF</InstanceId>
<!--1.0.2.29.1.255-->
<InstanceId>0100021D01FF</InstanceId>
<!--1.0.2.29.2.255-->
<InstanceId>0100021D02FF</InstanceId>
</AttributeDescriptorList>
</GetRequestWithList>
</GetRequest>
[2025/09/12 10:59:55.262] [INFO] - send_frame_type=getRequest_WITH_LIST
[2025/09/12 10:59:55.262] [INFO] - send_frame=C003C12000080000010000FF020000080000010000FF030000080000010000FF040000080000010000FF050000080000010000FF060000080000010000FF070000080000010000FF080000080000010000FF090000030100010800FF020000030100010801FF020000030100010802FF020000030100010803FF020000030100010804FF020000030100010805FF020000030100010806FF020000030100011D00FF020000030100011D01FF020000030100011D02FF020000030100011D03FF020000030100011D04FF020000030100011D05FF020000030100011D06FF020000030100020800FF020000030100020801FF020000030100020802FF020000030100020803FF020000030100020804FF020000030100020805FF020000030100020806FF020000030100021D00FF020000030100021D01FF020000030100021D02FF0200
<glo_GetRequest>
<InvocationCounter>9</InvocationCounter>
<CipheredData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ipheredData>
</glo_GetRequest>
[2025/09/12 10:59:55.262] [INFO] - ciph_frame_counter=0x9
[2025/09/12 10:59:55.262] [INFO] - send_frame_type=glo_getRequest
[2025/09/12 10:59:55.262] [INFO] - send_frame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
[2025/09/12 10:59:55.263] [INFO] - [/COSEM.SEND]
[2025/09/12 10:59:55.263] [INFO] - [WRAPPER.SEND]
[2025/09/12 10:59:55.263] [INFO] - ver=1 server=1 client=1 data_len=345 data=C8820155300000000916D8DE45B20F8B745A6AE9DCE2F260C859D0CDEEA5AF572E2176F8FDAC998FFE5059594334621994ECF45FA165D08101F2BA32FDFCDDC5BEE5E7E1C96E4F5E9609CFB48CAE04B0EAFE11AC25C18AF6EF87B2C4C580AE3D5D92277ACAD616020D9AB461C7AFBD27B03E13D7A84443D34922CE6DDAA9E20AF53CD2EF9975775F369AB6F0E050DD172D3DFDAFEA30605870971A1DC64DAEE650D27F489DA1510338A23E09A64E05B036CC802D879E18F6F7AA858C02607DC58B1ACE5F0C8BC6C31A3327C8EDF4E877C17487E8A72E28EC31862EAB378DB6116C7A54C52B8443EB4B191E90D267F0723D634D6409DCEACD2F0A8B884AA69CD5336FA175477652BBD6231B1EEFCFA657462456ECEFF7600E3F771AE91476B2E00457D865B100C3D7594692D25D555418DEFA01B4E4B947910C1243A365B47259F65F078C609F329C5AA2429764F6EF1ABEFAE4C28D6F8F3BFF
[2025/09/12 10:59:55.263] [INFO] - [/WRAPPER.SEND]
[2025/09/12 10:59:55.263] [INFO] - [TCP.SEND]
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
[2025/09/12 10:59:55.264] [INFO] - [/TCP.SEND]
[2025/09/12 10:59:55.853] [INFO] - [TCP.RECEIVED]
[2025/09/12 10:59:55.854] [INFO] - 000100010001011E
[2025/09/12 10:59:55.855] [INFO] - [/TCP.RECEIVED]
[2025/09/12 10:59:55.855] [INFO] - [TCP.RECEIVED]
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
[2025/09/12 10:59:55.856] [INFO] - [/TCP.RECEIVED]
[2025/09/12 10:59:55.856] [INFO] - [WRAPPER.RECEIVED]
[2025/09/12 10:59:55.856] [INFO] - ver=1 server=1 client=1 data_len=286 data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
[2025/09/12 10:59:55.857] [INFO] - [/WRAPPER.RECEIVED]
[2025/09/12 10:59:55.857] [INFO] - [COSEM.RECEIVED]
[2025/09/12 10:59:55.857] [INFO] - received_frame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
[2025/09/12 10:59:55.857] [INFO] - received_frame_type=glo_getResponse
[2025/09/12 10:59:55.858] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<glo_GetResponse>
<InvocationCounter>715</InvocationCounter>
<CipheredData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ipheredData>
</glo_GetResponse>
[2025/09/12 10:59:55.858] [INFO] - ciph_invocation_counter=0x2CB
[2025/09/12 10:59:55.859] [INFO] - received_frame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
[2025/09/12 10:59:55.859] [INFO] - received_frame_type=getResponse_WITH_LIST
[2025/09/12 10:59:55.859] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetResponse>
<GetResponseWithList>
<Result>
<Data>090C07E9090C05093B33FF00B400</Data>
</Result>
<Result>
<Data>1000B4</Data>
</Result>
<Result>
<Data>1100</Data>
</Result>
<Result>
<Data>090CFFFF03FE0702000000800000</Data>
</Result>
<Result>
<Data>090CFFFF0AFE0703000000800000</Data>
</Result>
<Result>
<Data>0F3C</Data>
</Result>
<Result>
<Data>0300</Data>
</Result>
<Result>
<Data>1601</Data>
</Result>
<Result>
<Data>150000000000000337</Data>
</Result>
<Result>
</Result>
<Result>
<Data>150000000000000000</Data>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
<Data>0600000000</Data>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
<Data>150000000000000150</Data>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
</GetResponseWithList>
</GetResponse>
[2025/09/12 10:59:55.863] [INFO] - [/COSEM.RECEIVED]
[2025/09/12 10:59:55.864] [INFO] - [COSEM.SEND]
[2025/09/12 10:59:55.864] [INFO] - DoTransactionGetRequestWithList
[2025/09/12 10:59:55.864] [INFO] - class=3;obis=1.0.2.29.3.255;attribute=2
[2025/09/12 10:59:55.864] [INFO] - class=3;obis=1.0.2.29.4.255;attribute=2
[2025/09/12 10:59:55.864] [INFO] - class=3;obis=1.0.2.29.5.255;attribute=2
[2025/09/12 10:59:55.864] [INFO] - class=3;obis=1.0.2.29.6.255;attribute=2
[2025/09/12 10:59:55.864] [INFO] - class=3;obis=1.0.3.8.0.255;attribute=2
[2025/09/12 10:59:55.865] [INFO] - class=3;obis=1.0.3.8.1.255;attribute=2
[2025/09/12 10:59:55.865] [INFO] - class=3;obis=1.0.3.8.2.255;attribute=2
[2025/09/12 10:59:55.865] [INFO] - class=3;obis=1.0.3.8.3.255;attribute=2
[2025/09/12 10:59:55.865] [INFO] - class=3;obis=1.0.3.8.4.255;attribute=2
[2025/09/12 10:59:55.865] [INFO] - class=3;obis=1.0.3.8.5.255;attribute=2
[2025/09/12 10:59:55.865] [INFO] - class=3;obis=1.0.3.8.6.255;attribute=2
[2025/09/12 10:59:55.865] [INFO] - class=3;obis=1.0.3.29.0.255;attribute=2
[2025/09/12 10:59:55.866] [INFO] - class=3;obis=1.0.3.29.1.255;attribute=2
[2025/09/12 10:59:55.866] [INFO] - class=3;obis=1.0.3.29.2.255;attribute=2
[2025/09/12 10:59:55.866] [INFO] - class=3;obis=1.0.3.29.3.255;attribute=2
[2025/09/12 10:59:55.866] [INFO] - class=3;obis=1.0.3.29.4.255;attribute=2
[2025/09/12 10:59:55.866] [INFO] - class=3;obis=1.0.3.29.5.255;attribute=2
[2025/09/12 10:59:55.866] [INFO] - class=3;obis=1.0.3.29.6.255;attribute=2
[2025/09/12 10:59:55.867] [INFO] - class=3;obis=1.0.4.8.0.255;attribute=2
[2025/09/12 10:59:55.867] [INFO] - class=3;obis=1.0.4.8.1.255;attribute=2
[2025/09/12 10:59:55.867] [INFO] - class=3;obis=1.0.4.8.2.255;attribute=2
[2025/09/12 10:59:55.867] [INFO] - class=3;obis=1.0.4.8.3.255;attribute=2
[2025/09/12 10:59:55.867] [INFO] - class=3;obis=1.0.4.8.4.255;attribute=2
[2025/09/12 10:59:55.867] [INFO] - class=3;obis=1.0.4.8.5.255;attribute=2
[2025/09/12 10:59:55.867] [INFO] - class=3;obis=1.0.4.8.6.255;attribute=2
[2025/09/12 10:59:55.868] [INFO] - class=3;obis=1.0.4.29.0.255;attribute=2
[2025/09/12 10:59:55.868] [INFO] - class=3;obis=1.0.4.29.1.255;attribute=2
[2025/09/12 10:59:55.868] [INFO] - class=3;obis=1.0.4.29.2.255;attribute=2
[2025/09/12 10:59:55.868] [INFO] - class=3;obis=1.0.4.29.3.255;attribute=2
[2025/09/12 10:59:55.868] [INFO] - class=3;obis=1.0.4.29.4.255;attribute=2
[2025/09/12 10:59:55.868] [INFO] - class=3;obis=1.0.4.29.5.255;attribute=2
[2025/09/12 10:59:55.868] [INFO] - class=3;obis=1.0.4.29.6.255;attribute=2
[2025/09/12 10:59:55.869] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetRequest>
<!--1.0.2.29.3.255-->
<InstanceId>0100021D03FF</InstanceId>
<!--1.0.2.29.4.255-->
<InstanceId>0100021D04FF</InstanceId>
<!--1.0.2.29.5.255-->
<InstanceId>0100021D05FF</InstanceId>
<!--1.0.2.29.6.255-->
<InstanceId>0100021D06FF</InstanceId>
<!--1.0.3.8.0.255-->
<InstanceId>0100030800FF</InstanceId>
<!--1.0.3.8.1.255-->
<InstanceId>0100030801FF</InstanceId>
<!--1.0.3.8.2.255-->
<InstanceId>0100030802FF</InstanceId>
<!--1.0.3.8.3.255-->
<InstanceId>0100030803FF</InstanceId>
<!--1.0.3.8.4.255-->
<InstanceId>0100030804FF</InstanceId>
<!--1.0.3.8.5.255-->
<InstanceId>0100030805FF</InstanceId>
<!--1.0.3.8.6.255-->
<InstanceId>0100030806FF</InstanceId>
<!--1.0.3.29.0.255-->
<InstanceId>0100031D00FF</InstanceId>
<!--1.0.3.29.1.255-->
<InstanceId>0100031D01FF</InstanceId>
<!--1.0.3.29.2.255-->
<InstanceId>0100031D02FF</InstanceId>
<!--1.0.3.29.3.255-->
<InstanceId>0100031D03FF</InstanceId>
<!--1.0.3.29.4.255-->
<InstanceId>0100031D04FF</InstanceId>
<!--1.0.3.29.5.255-->
<InstanceId>0100031D05FF</InstanceId>
<!--1.0.3.29.6.255-->
<InstanceId>0100031D06FF</InstanceId>
<!--1.0.4.8.0.255-->
<InstanceId>0100040800FF</InstanceId>
<!--1.0.4.8.1.255-->
<InstanceId>0100040801FF</InstanceId>
<!--1.0.4.8.2.255-->
<InstanceId>0100040802FF</InstanceId>
<!--1.0.4.8.3.255-->
<InstanceId>0100040803FF</InstanceId>
<!--1.0.4.8.4.255-->
<InstanceId>0100040804FF</InstanceId>
<!--1.0.4.8.5.255-->
<InstanceId>0100040805FF</InstanceId>
<!--1.0.4.8.6.255-->
<InstanceId>0100040806FF</InstanceId>
<!--1.0.4.29.0.255-->
<InstanceId>0100041D00FF</InstanceId>
<!--1.0.4.29.1.255-->
<InstanceId>0100041D01FF</InstanceId>
<!--1.0.4.29.2.255-->
<InstanceId>0100041D02FF</InstanceId>
<!--1.0.4.29.3.255-->
<InstanceId>0100041D03FF</InstanceId>
<!--1.0.4.29.4.255-->
<InstanceId>0100041D04FF</InstanceId>
<!--1.0.4.29.5.255-->
<InstanceId>0100041D05FF</InstanceId>
<!--1.0.4.29.6.255-->
<InstanceId>0100041D06FF</InstanceId>
</GetRequest>
[2025/09/12 10:59:55.869] [INFO] - send_frame_type=getRequest_WITH_LIST
[2025/09/12 10:59:55.869] [INFO] - send_frame=C003C12000030100021D03FF020000030100021D04FF020000030100021D05FF020000030100021D06FF020000030100030800FF020000030100030801FF020000030100030802FF020000030100030803FF020000030100030804FF020000030100030805FF020000030100030806FF020000030100031D00FF020000030100031D01FF020000030100031D02FF020000030100031D03FF020000030100031D04FF020000030100031D05FF020000030100031D06FF020000030100040800FF020000030100040801FF020000030100040802FF020000030100040803FF020000030100040804FF020000030100040805FF020000030100040806FF020000030100041D00FF020000030100041D01FF020000030100041D02FF020000030100041D03FF020000030100041D04FF020000030100041D05FF020000030100041D06FF0200
<glo_GetRequest>
<InvocationCounter>10</InvocationCounter>
<CipheredData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ipheredData>
</glo_GetRequest>
[2025/09/12 10:59:55.869] [INFO] - ciph_frame_counter=0xA
[2025/09/12 10:59:55.870] [INFO] - send_frame_type=glo_getRequest
[2025/09/12 10:59:55.870] [INFO] - send_frame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
[2025/09/12 10:59:55.870] [INFO] - [/COSEM.SEND]
[2025/09/12 10:59:55.870] [INFO] - [WRAPPER.SEND]
[2025/09/12 10:59:55.870] [INFO] - ver=1 server=1 client=1 data_len=345 data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
[2025/09/12 10:59:55.870] [INFO] - [/WRAPPER.SEND]
[2025/09/12 10:59:55.871] [INFO] - [TCP.SEND]
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
[2025/09/12 10:59:55.871] [INFO] - [/TCP.SEND]
[2025/09/12 10:59:56.385] [INFO] - [TCP.RECEIVED]
[2025/09/12 10:59:56.386] [INFO] - 0001000100010111
[2025/09/12 10:59:56.386] [INFO] - [/TCP.RECEIVED]
[2025/09/12 10:59:56.387] [INFO] - [TCP.RECEIVED]
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
[2025/09/12 10:59:56.388] [INFO] - [/TCP.RECEIVED]
[2025/09/12 10:59:56.388] [INFO] - [WRAPPER.RECEIVED]
[2025/09/12 10:59:56.389] [INFO] - ver=1 server=1 client=1 data_len=273 data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
[2025/09/12 10:59:56.389] [INFO] - [/WRAPPER.RECEIVED]
[2025/09/12 10:59:56.391] [INFO] - [COSEM.RECEIVED]
[2025/09/12 10:59:56.392] [INFO] - received_frame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
[2025/09/12 10:59:56.392] [INFO] - received_frame_type=glo_getResponse
[2025/09/12 10:59:56.393] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<glo_GetResponse>
<InvocationCounter>716</InvocationCounter>
<CipheredData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ipheredData>
</glo_GetResponse>
[2025/09/12 10:59:56.393] [INFO] - ciph_invocation_counter=0x2CC
[2025/09/12 10:59:56.394] [INFO] - received_frame=C403C1200006000000000006000000000006000000000006000000000015000000000000005700150000000000000057001500000000000000000015000000000000000000150000000000000000001500000000000000000015000000000000000000060000000000060000000000060000000000060000000000060000000000060000000000060000000000150000000000000001001500000000000000010015000000000000000000150000000000000000001500000000000000000015000000000000000000150000000000000000000600000000000600000000000600000000000600000000000600000000000600000000000600000000
[2025/09/12 10:59:56.394] [INFO] - received_frame_type=getResponse_WITH_LIST
[2025/09/12 10:59:56.395] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetResponse>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
<Data>150000000000000057</Data>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
<Data>150000000000000001</Data>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
<Result>
</Result>
</GetResponse>
[2025/09/12 10:59:56.407] [INFO] - [/COSEM.RECEIVED]
[2025/09/12 10:59:56.407] [INFO] - [COSEM.SEND]
[2025/09/12 10:59:56.407] [INFO] - DoTransactionGetRequestWithList
[2025/09/12 10:59:56.407] [INFO] - class=3;obis=1.0.5.8.0.255;attribute=2
[2025/09/12 10:59:56.408] [INFO] - class=3;obis=1.0.5.8.1.255;attribute=2
[2025/09/12 10:59:56.408] [INFO] - class=3;obis=1.0.5.8.2.255;attribute=2
[2025/09/12 10:59:56.408] [INFO] - class=3;obis=1.0.5.8.3.255;attribute=2
[2025/09/12 10:59:56.408] [INFO] - class=3;obis=1.0.5.8.4.255;attribute=2
[2025/09/12 10:59:56.409] [INFO] - class=3;obis=1.0.5.8.5.255;attribute=2
[2025/09/12 10:59:56.409] [INFO] - class=3;obis=1.0.5.8.6.255;attribute=2
[2025/09/12 10:59:56.409] [INFO] - class=3;obis=1.0.5.29.0.255;attribute=2
[2025/09/12 10:59:56.409] [INFO] - class=3;obis=1.0.5.29.1.255;attribute=2
[2025/09/12 10:59:56.409] [INFO] - class=3;obis=1.0.5.29.2.255;attribute=2
[2025/09/12 10:59:56.410] [INFO] - class=3;obis=1.0.5.29.3.255;attribute=2
[2025/09/12 10:59:56.410] [INFO] - class=3;obis=1.0.5.29.4.255;attribute=2
[2025/09/12 10:59:56.410] [INFO] - class=3;obis=1.0.5.29.5.255;attribute=2
[2025/09/12 10:59:56.410] [INFO] - class=3;obis=1.0.5.29.6.255;attribute=2
[2025/09/12 10:59:56.410] [INFO] - class=3;obis=1.0.6.8.0.255;attribute=2
[2025/09/12 10:59:56.411] [INFO] - class=3;obis=1.0.6.8.1.255;attribute=2
[2025/09/12 10:59:56.411] [INFO] - class=3;obis=1.0.6.8.2.255;attribute=2
[2025/09/12 10:59:56.411] [INFO] - class=3;obis=1.0.6.8.3.255;attribute=2
[2025/09/12 10:59:56.411] [INFO] - class=3;obis=1.0.6.8.4.255;attribute=2
[2025/09/12 10:59:56.411] [INFO] - class=3;obis=1.0.6.8.5.255;attribute=2
[2025/09/12 10:59:56.411] [INFO] - class=3;obis=1.0.6.8.6.255;attribute=2
[2025/09/12 10:59:56.412] [INFO] - class=3;obis=1.0.6.29.0.255;attribute=2
[2025/09/12 10:59:56.412] [INFO] - class=3;obis=1.0.6.29.1.255;attribute=2
[2025/09/12 10:59:56.412] [INFO] - class=3;obis=1.0.6.29.2.255;attribute=2
[2025/09/12 10:59:56.412] [INFO] - class=3;obis=1.0.6.29.3.255;attribute=2
[2025/09/12 10:59:56.413] [INFO] - class=3;obis=1.0.6.29.4.255;attribute=2
[2025/09/12 10:59:56.413] [INFO] - class=3;obis=1.0.6.29.5.255;attribute=2
[2025/09/12 10:59:56.413] [INFO] - class=3;obis=1.0.6.29.6.255;attribute=2
[2025/09/12 10:59:56.413] [INFO] - class=3;obis=1.0.7.8.0.255;attribute=2
[2025/09/12 10:59:56.414] [INFO] - class=3;obis=1.0.7.8.1.255;attribute=2
[2025/09/12 10:59:56.414] [INFO] - class=3;obis=1.0.7.8.2.255;attribute=2
[2025/09/12 10:59:56.414] [INFO] - class=3;obis=1.0.7.8.3.255;attribute=2
[2025/09/12 10:59:56.416] [INFO] - <?xml version="1.0" encoding="utf-16"?>
<GetRequest>
BR
Hasim
1 year ago
Hi, The client address is 1…
The client address is 1 and server address is 1, but there is an error on AARQ.
The DLMS standards define that Calling-Ae-Invocation-Id (0xA9) is INTEGER.
AP-invocation-identifier ::= INTEGER
Your client application sends octet-string. You need to ask the meter manufacturer to fix this.
A9
0A
04
08 48 41 6C 70 6B 61 79 61
I handled this manually and was able to decrypt the PDU. See below.
<CallingAPTitle Value="444E563031323335" />
<MechanismName Value="HighGMAC" />
<CallingAuthentication Value="BC6F9A6A7D572C09A1D4F022BAE466CCB9E6303F582FAE3E34B57FCA0E0E37090B64708BFD067F3FDB994B8287DE686DA338D725A9DD37298A245A41B3488A09" />
<!-- Decrypted data:
Invocation Counter: 7
<InitiateRequest>
<ConformanceBit Name="Attribute0SupportedWithSet" />
<ConformanceBit Name="PriorityMgmtSupported" />
<ConformanceBit Name="Attribute0SupportedWithGet" />
<ConformanceBit Name="InformationReport" />
<ConformanceBit Name="DataNotification" />
<ConformanceBit Name="ParameterizedAccess" />
<ConformanceBit Name="Get" />
<ConformanceBit Name="Set" />
<ConformanceBit Name="EventNotification" />
</InitiateRequest>
<glo_InitiateRequest Value="300000000758B6E775822B214A86315369161BE022865A8024DB56AF6D760E" />
