  3. At Authorization Level "HighGmac" An Error "ServiceUnsupported" Occurs When Reading Any Object
At authorization level "HighGmac" an error "ServiceUnsupported" occurs when reading any object
By JavierDiaz , 21 August, 2025
Authorization in mode "HighGmac" - successfully:
14:49:41 Send SNRM request.
TX: 7E A0 08 02 21 21 93 05 D1 7E
14:49:41
RX: 7E A0 1F 21 02 21 73 56 F4 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
14:49:41 Send AARQ request.
TX: 7E A0 2C 02 21 21 10 17 2A E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 42 1E 59 FF FF 78 56 7E
14:49:41
RX: 7E A0 3B 21 02 21 30 48 C9 E6 E7 00 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 04 00 00 07 71 7E 7E
14:49:41
RX: 7E A0 16 21 02 21 52 B9 95 E6 E7 00 C4 01 C1 00 06 00 00 00 5B 2B F4 7E
14:49:41 Disconnect request
TX: 7E A0 08 02 21 21 53 09 17 7E
14:49:41
TX: 7E A0 08 02 21 61 93 63 97 7E
14:49:41
RX: 7E A0 1F 61 02 21 73 E1 E2 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 6C 02 21 61 10 53 AD E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 45 4D 52 30 30 30 30 31 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 68 4A 56 3B 74 2D 44 44 72 39 70 48 3E 59 64 5E BE 23 04 21 21 1F 10 00 00 00 5C 01 00 00 00 06 5F 1F 04 00 42 1E 59 FF FF 1E CC 05 FD 14 AB 6E 16 EF 04 17 DB 9F A2 7E
14:49:41
RX: 7E A0 78 61 02 21 30 11 03 E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 4D 52 00 0C 2F 0A 33 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 33 62 42 66 65 6E 57 52 7C 75 7A 79 6D 6D 74 65 BE 23 04 21 28 1F 10 00 00 00 4E 08 00 06 5F 1F 04 00 40 18 19 04 00 00 07 60 20 A0 B8 01 AE 30 12 A0 3A 8C 80 C2 7C 7E
14:49:41 Authenticating.
TX: 7E A0 40 02 21 61 32 E2 B8 E6 E6 00 CB 31 10 00 00 00 5D C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 11 10 00 00 00 5D 00 10 04 3B 8E 58 9C A0 77 97 4D 3C 8A ED 1A 1E A5 D1 FB D3 D7 F2 5B 80 18 AF 7E
14:49:41
RX: 7E A0 39 61 02 21 52 63 89 E6 E7 00 CF 2A 10 00 00 00 50 C7 01 C1 00 01 00 09 11 10 00 00 00 4F 4A 24 49 60 E9 07 AC 6A E4 84 F5 7D C9 CF 80 91 2E B8 DF 94 2D E0 1D 63 74 ED 7E
Read object Clock - error:
14:40:06 Read object type Clock index: 2
TX: 7E A0 36 02 21 61 54 B9 90 E6 E6 00 DB 08 45 4D 52 30 30 30 30 31 1E 10 00 00 00 57 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 8C E9 84 9F 57 26 1F 07 9F E4 CE 57 08 8D 7E
14:40:06
RX: 7E A0 2D 61 02 21 74 07 54 E6 E7 00 DB 08 45 4D 52 00 0C 2F 0A 33 15 10 00 00 00 4A 0E 05 03 02 4E 23 6B 89 57 87 15 57 EA 26 C5 45 81 5E 7E
Please tell me what is not set up correctly?
1 year ago
Hi, Everything looks correct…
Everything looks correct. You can establish the connection to the meter.
Remove the DeltaValueEncoding from the proposed conformance. That is causing problems with some of the older meters.
