  2. Compiling GuruxDLMSDataCollector With Wirepas
Compiling GuruxDLMSDataCollector with wirepas
By Harshi_554 , 8 August, 2025
Gurux DLMS for ANSI C
How to compile GuruxDLMSDataCollector with wirepas ? Im getting compilation error when I tried make command inside wirepas folder.
10 months 1 week ago
Hi, Have you installed…
Have you installed Wirepas SDK? Can you describe what error you are receiving?
Harshi_554
I have installed wirepas…
I have installed wirepas gateway sdk. Im getting below error
GuruxDLMSDataCollector/wirepas/gurux_dc$ make
makefile:125: *** Too many open files. Stop.
10 months ago
Hi, You need to ask Wirepas…
You need to ask Wirepas what might cause this. This works without problems with our environment.
Harshi_554
10 months ago
Does this source code works…
Does this source code works with all Wirepas SDKs? I used 2.4GHz SDK.
10 months ago
Hi, Yes, it should work. BR,…
