  3. Compiling GuruxDLMSDataCollector With Wirepas
Compiling GuruxDLMSDataCollector with wirepas
By Harshi_554 , 8 August, 2025
Gurux DLMS for ANSI C
How to compile GuruxDLMSDataCollector with wirepas ? Im getting compilation error when I tried make command inside wirepas folder.
1 year 1 month ago
Hi, Have you installed…
Have you installed Wirepas SDK? Can you describe what error you are receiving?
Harshi_554
1 year 1 month ago
I have installed wirepas…
I have installed wirepas gateway sdk. Im getting below error
GuruxDLMSDataCollector/wirepas/gurux_dc$ make
makefile:125: *** Too many open files. Stop.
1 year 1 month ago
Hi, You need to ask Wirepas…
You need to ask Wirepas what might cause this. This works without problems with our environment.
Harshi_554
1 year 1 month ago
Does this source code works…
Does this source code works with all Wirepas SDKs? I used 2.4GHz SDK.
1 year 1 month ago
Hi, Yes, it should work. BR,…
