  2. Applying Scalers
Applying Scalers
By Yamini , 7 July, 2025
I want to Know while reading data from meter do we need to apply the scalers to the meter data separately or else gurux will automatically apply scalers to the meter data.
Please clarify this doubt.
Yamini
Ankush
1 year ago
You need to apply the…
You need to apply the scalers to the meter data separately.
Consider following example:
int addRegisterObject()
const unsigned char ln[6] = { 1, 1, 21, 25, 0, 255 };
cosem_init2((gxObject*)&activePowerL1.base, DLMS_OBJECT_TYPE_REGISTER, ln);
//10 ^ 3 = 1000
activePowerL1.scaler = 3;
activePowerL1.unit = 30;
return 0;
1 year ago
Hi, Scalers are used…
Scalers are used automatically if they are set to the register objects.
You can set the scalers or read them from the meter.
