  3. Holley DTSD545S 3-phase Smart Meter Using Lora Mesh IOT-L2S-B2M and RS-485
Holley DTSD545S 3-phase smart meter using Lora mesh IOT-L2S-B2M and RS-485
By Usuhuu , 3 June, 2025
I am trying to get data from Holley DTSD545S 3-phase smart meter using Lora mesh wireless transmitter. To get data I used RS-485 and Gurux GXDLMSDirector. Unfortunately, I can't get data and don't know how it works. Should i use other software to get data? Do you have any advice?
1 year 3 months ago
Hi, I believe that your…
I believe that your meter is using WRAPPER when you communicate with Lora. Try to change the interface to WRAPPER. The correct settings should be described in the meter documentation.
Usuhuu
1 year 3 months ago
Hi, Thanks for your response…
Thanks for your response. I changed the interface to Wrapper but "Failed to receive reply from the device in given time " error appeared. When I am change the interface to HDLC it will connect but can't get data. It is loading as "connecting object" so long.
https://www.dropbox.com/scl/fi/j93xh1iqwu6t903wyjwp3/Screenshot-2025-06…
