  3. Not Able To Read PUSH Association Via GURUX Tool
Not able to read PUSH association via GURUX tool
By Vikas_Balichakra , 11 April, 2025
<p>As per IS 15959-P2 (cluase 4 and 7.1 Table-2) PUSH doesn't required any authentication password. It has the lowest key. But when i am selecting Indian standard and association PUSH in gurux it is mandatorily asking password and hence meter is failing. Attached the screen shot both standard and tool configuration. I am using 9.0.2504.0301 version.</p>
1 year 5 months ago
Hi, IS 15959-P2 defines that…
IS 15959-P2 defines that you need to use pre-established connection if you want to modify or read push messages. This is defined in "Table 2 Detailed Association Properties for the Smart Meter".
Vikas_Balichakra
1 year 5 months ago
Thanks for the reply. I am…
I am not reading any push messages.
I wanted to download the PUSH association. Like how we download other associations(PC,MR,US).
In Gurux tool if i select manufacturer as Indian Standard and Authentication as PUSH then it mandatorily asking password. But as per the IS PUSH doesn't need any password to download the association.
1 year 5 months ago
Hi, This is changed. Restart…
This is changed. Restart GXDLMSDirector and select "New Manufacturer Settings Available" from the top menu.
GXDLMSDirector doesn't ask for the password after that.
