  3. Gurux Python - Issue With Reading LoadProfiles (gurux Objects Instead of Normal Values)
Gurux python - issue with reading LoadProfiles (gurux objects instead of normal values)
By mick93 , 27 March, 2025
I am trying to read LoadProfile#2, so in GXSettings.py I've put objects as in:
self.readObjects = [("1.0.99.2.0.255", 3), ("1.0.99.2.0.255", 2)]
Then I executed main.py file. First data which appeared looked like that:
Index: 3 Value: (<gurux_dlms.objects.GXDLMSClock.GXDLMSClock object at 0x0000026B7BCE22D0>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7B1B7E10>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000026B7C2B7B10>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7B383C90>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x0000026B7C24AA90>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7BCE0A90>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x0000026B7C24B150>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7BE2E4D0>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x0000026B7C24BD50>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7BE286D0>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x0000026B7C250990>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7BE28710>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x0000026B7C251590>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7BE2AD10>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x0000026B7C252190>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000026B7BE28550>)
And some time later I had something like that (it's cut, because it's too long):
Index: 2 Value: [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BE2C490>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7C845650>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BE2C550>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BDC3090>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BE2B090>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7C8456D0>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BDF1D10>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BE23890>, 8, 0, 0, 0, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BE23E50>, 8, 0, 0, 0, 0, 0,
0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026B7BED7550>, 8, 0, 0, 0, 0, 0, 0]
How can I make it show "normal" values, instead of objects? I want timestamps+all columns from LoadProfile#2. Also, I'd like to add 2-3 possible options for reading Profiles: read everything from LoadProfile / read by entry / read by date range. Meter is MCS/Metcom. I'm still learning python by the way, so I will be grateful if you'll put some python snippets! I know there are funcs like readRowsByRange or readRowsByEntry, but I'm not sure how to use them.
mick93
1 year 8 months ago
UPDATE: I added test…
UPDATE:
I added test-function to GXDLMSReader:
def testRead(self):
pg = GXDLMSProfileGeneric("1.0.99.2.0.255")
self.read(pg, 3)
start = datetime.datetime.now()
end = start
start = start.replace(hour=0, minute=0, second=0, microsecond=0)
end = end.replace(minute=0, second=0, microsecond=0)
cells = self.readRowsByRange(pg, start, end)
for rows in cells:
row = ""
for cell in rows:
if row:
row += " | "
if isinstance(cell, bytearray):
row += GXByteBuffer.hex(cell)
else:
row += str(cell)
self.writeTrace(row, TraceLevel.INFO)
And in main.py I've added line "reader.testRead()" if "not read". The output looks like below:
Authentication: 1
ClientAddress: 0x1
Standard: 0
Reading LP2
03/27/25 02:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 03:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 04:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 05:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 06:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 07:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 08:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 09:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 10:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 11:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 12:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 13:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 14:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
03/27/25 15:00:00 | 0 | 0 | 0 | 0 | 0 | 0 | 0
Reading LP2 ( / it's just my print() )
File "C:\Users\x\Desktop\GURUX\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python\main.py", line 79, in main
raise Exception("Unknown logical name:" + k)
Exception: Unknown logical name:1.0.99.2.0.255
1) Why there's "Exception: Unknown logical name:1.0.99.2.0.255" if it did read something?
2) Also, how should I change "end" in my function testRead() if I want to choose when it should start and end?
3) Why did it print LP2 table two times (as you can see above)?
1 year 8 months ago
Hi, Check what you are doing…
Check what you are doing after testRead. I believe that the reason is found in line 79.
mick93
1 year 8 months ago
Hi Mikko, this function…
this function apparently works, maybe it was meter issue or connection issue, but next readouts were okay. Thanks for response anyway!
