  2. Metcom MCS301 Profile Generics
By craig-gxe , 4 February, 2025
So I am connecting to a Metcom meter with no problem using an IR probe. Everything seemed fine but I think there is something wrong with the Profile Generics. When trying to read it I get an error:
Duration: 71
15:42:01 Read object type ProfileGeneric index: 5
7E A0 1A 02 FF 03 9E BF 27 E6 E6 00 C0 01 C1 00 07 00 01 18 03 00 FF 05 00 9A 24 7E
15:42:01 03:42:01.096 Sent 7E A0 1A 02 FF 03 9E BF 27 E6 E6 00 C0 01 C1 00 07 00 01 18 03 00 FF 05 00 9A 24 7E
15:42:01 03:42:01.136 Received 7E A0 15 03 00 02
15:42:01 03:42:01.151 Received 02 7C 85 18 C6 C5 E6 E7 00 C4 01
15:42:01 03:42:01.168 Received 11
15:42:01
7E A0 15 03 00 02 7C 85 18 C6 C5 E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
Duration: 71
15:42:01 Read object type ProfileGeneric index: 6
7E A0 1A 02 FF 03 B0 C3 EF E6 E6 00 C0 01 C1 00 07 00 01 18 03 00 FF 06 00 F2 0E 7E
15:42:01 03:42:01.176 Sent 7E A0 1A 02 FF 03 B0 C3 EF E6 E6 00 C0 01 C1 00 07 00 01 18 03 00 FF 06 00 F2 0E 7E
15:42:01 03:42:01.216 Received 7E A0 25 03 00 02 7C 85
15:42:01 03:42:01.232 Received 85 3A 9C 11 E6 E7 00 C4 01
15:42:01 03:42:01.248 Received 09 06 00 00 00 00 00 00 0F 00 12 00 00 7C 19
15:42:01
7E A0 25 03 00 02 7C 85 3A 9C 11 E6 E7 00 C4 01 C1 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 7C 19 7E
Duration: 72
System.Exception: Capture objects not read.
at GXDLMSDirector.GXDLMSCommunicator.Read(Object sender, GXDLMSObject obj, Boolean forceRead)
at GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
it also seems like on the initial connection and fetching of the association views and fields, it does not fetch all the profile generic items. In the documentation it shows profile codes for instantaneous values,
0-0:21.0.6.255
0-0:21.0.5.255
0-0:21.0.7.255
I want to access these objects but gurux does not seem to even fetch them to begin with so I cannot read them.
1 year 5 months ago
Hi, You have not read the…
You have not read the Capture objects. Select the profile generic object and then select "File" and "Refresh". It will update the capture objects.
