  2. Issues With Reading Kelin Electric Meter Using Gurux Python Code
Issues with reading Kelin Electric Meter using Gurux Python code
By Ali.khan , 22 January, 2025
Gurux.DLMS.AMI
I have been using the Gurux DLMS python code with Kelin Electric Smart Meter. The meter gives me values using the DLMS director but when I use the Python code it gives me gibberish or invalid Data.
Has anyone else faced this problem? How should I be able to get the correct data using the Python code.
1 year 5 months ago
Hi, Use the command line…
Use the command line arguments when you select your meter in GXDLMSDirector.
Can you describe what data is wrong?
