By gaurang , 1 January, 2025 Forums Gurux.DLMS.AMI Hi, Is AMI4 Agent and AMI4 server/client support script execution on Remote DLMS Meters? Is they any example to customize it and achieve script execution functionality? Best Regards, Gaurang Hi Gaurang, There is no UI… Hi Gaurang, There is no UI for ScriptTable at the moment in Gurux DLMS AMI. It's possible to do with calling Swagger, but it's not easy. I'll add the ScriptTable support to the work list, but I can't tell when it can be released. BR, Mikko Thank you Mikko, I will try… Thank you Mikko, I will try with Swagger way. Best Regards, Gaurang
Hi Gaurang,
Thank you Mikko,
Best Regards,
Gaurang
