  3. Issue Reading Generic Profile of E650 Meter Using Python and GXDLMSDirector
By jabayter , 22 November, 2024
Known problems
I’m experiencing issues when trying to read the generic profile of my E650 meter using Python and GXDLMSDirector (I’ve attached the logs below). From GXDLMSDirector, I receive a Read-Write denied error, and from Python, I get the following result:
Authentication: 1
ClientAddress: 0x20
ServerAddress: 0x4b0c
Access Error : Unknown error.
TX: 17:49:23 7E A0 47 00 02 2C 19 41 10 24 A6 E6 E6 00 05 01 04 62 78 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 0B 14 03 00 00 00 00 FB 8C 00 09 0C 07 E8 0B 15 04 00 00 00 00 FB 8C 00 01 00 63 E4 7E
RX: 17:49:23 7E A0 0A 41 00 02 2C 19 1F DD 24 7E
I’m using the same Data Collector authentication as configured in Map110. The issue seems to specifically lie with the generic profile.
Any guidance or suggestions would be greatly appreciated.
Thank you!
1 year 11 months ago
Hi, Some meters expect that…
Some meters expect that the date-time is in a specific format. Now I can't access the E650, but if you add hex trace from Map110, I can get the correct settings to you.
Only profile generic read message is enough.
jabayter
Hi Mikko, thank you for your…
Hi Mikko, thank you for your answer.
I get the following result from Map110:
1982565141ms - DLMS Open
1982565141ms - DLMS set State: OPENING
1982565141ms - DLMS Init ShortName CommandHandler
1982565469ms - DLMS set State: AUTHENTICATION
1982565469ms - DLMS S-> COSEM AARQ (with ACSE Requirements)
1982565469ms - DLMS dlms SendReceive
1982565469ms - DLMS S-> 603980020780A1090607608574050801028A0207808B0760857405080201AC0A80084141374339393346BE0F040D01000000065F04001C13200000
1982565594ms - DLMS R<- 6128A109060760857405080102A203020100A305A103020100BE0F040D0800065F04001802200960FA00
1982565594ms - DLMS check ACSE-Response Values
1982565594ms - DLMS set State: OPEN
1982565594ms - DLMS set State: SENDRECEIVE
1982565594ms - DLMS dlms SendReceive
1982565594ms - DLMS S-> 050202FD0802FF08
1982565719ms - DLMS R<- 0C020009104C475A33323237313832380000000000000A03423332
1982565719ms - DLMS set State: OPEN
1982565782ms - DLMS set State: SENDRECEIVE
1982565782ms - DLMS dlms SendReceive
1982565782ms - DLMS S-> 0501023848
1982565875ms - DLMS R<- 0C01000A25422E4D343043505453434D444F2E303030392E4C543073207647736172487370706E61676C
1982565875ms - DLMS set State: OPEN
1982566016ms - DLMS set State: SENDRECEIVE
1982566016ms - DLMS dlms SendReceive
1982566016ms - DLMS S-> 050102C1C8
1982566094ms - DLMS R<- 0C01000913FFFF0000FF0000FF0000FF0000FF0000FF0000
1982566094ms - DLMS set State: OPEN
1982566344ms - DLMS set State: SENDRECEIVE
1982566344ms - DLMS dlms SendReceive
1982566344ms - DLMS S-> 05030262800262A0022BC0
1982566625ms - DLMS R<- 0C0300010C020412000809060000010000FF0F0212000002041200030906000060F00CFF0F12120000020412000309060101011D01FF0F02120000020412000309060101021D01FF0F02120000020412000309060101031D01FF0F02120000020412000309060101041D01FF0F02120000020412000309060101200700FF0F0B120000020412000309060101340700FF0F0B120000020412000309060101480700FF0F0B1200000204120003090601011F0700FF0F0B120000020412000309060101330700FF0F0B120000020412000309060101470700FF0F0B120000000600006A180009060000010000FF
1982566625ms - DLMS set State: OPEN
1982600985ms - DLMS set State: SENDRECEIVE
1982600985ms - DLMS dlms SendReceive
1982600985ms - DLMS S-> 052D0294500299A8029A40029AD8029B70029C08029CA0029D38029DD0029E68029F000294E8029F9802A03002A0C802A16002A1F802A29002A32802A3C002A45802A4F002958002A58802A62002A6B802A75002A7E802A88002A91802A9B002AA4802AAE002961802AB7802AC1002ACA802AD4002ADD802AE7002AF0802AFA002B03802B0D00296B0
1982601985ms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
1982601985ms - DLMS dlms SendReceive
1982601985ms - DLMS S-> 052D02B16802B20002B29802B33002B3C802B46002B4F802B59002B62802B6C002974802B75802B7F002B8880297E0029878029910020BB00211980212400212E80213900214380214E00215880216300216D8021780020C580218280218D0021978021A20021AC8021B70021C18021FA00220480220F0020D000221980222400222E8020DA8020E50
1982603047ms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
1982603047ms - DLMS dlms SendReceive
1982603047ms - DLMS S-> 052D020EF8020FA00210480210F0021CE00226D80227800228280228D0022978022A20022AC8022CB0022D58022E00021D98022EA8022F50022FF80230A00231480231F0023298023340021E40021EF80223900224380224E00225880226300204480209E00265700265080263780261E8024BA00253880253F00254580254C00255280255900255F8
1982604125ms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
1982604125ms - DLMS dlms SendReceive
1982604125ms - DLMS S-> 052D0256600256C8025730024C080257980258000258680258D0025938024C70024CD8024D40024DA80252500252B80253200203E0020978025D78025FE8025F18025DE0025E48025EB0026050025F8002C1C002C0F80266A80268800266400268180265D80267B0023778025B58025AF0025BC00205C0020558028B9002FE000288500284A8028510
1982605188ms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
1982605188ms - DLMS dlms SendReceive
1982605188ms - DLMS S-> 05170285780285E00286480286B00287180287800287E80289F0028B28028A58028AC00288B8028920028988028F80028FE80248A00202700201F0026270026288026290026330
1982605719ms - DLMS R<- 0C1700090600007F00000000090600007F00000000090600007F00000000090600007F00000000090600007F00000000090600007F0000000009060000600800FF0009060000600701FF0009060000600700FF0009060000600702FF0009060000600703FF0009060100000100FF010301030009060000600400FF0009060000600500FF000906000060F00CFF00090601010D0000FF00090601010D0500FF0009060100630100FF000600000384001601001114
1982605719ms - DLMS set State: OPEN
1982605860ms - DLMS set State: SENDRECEIVE
1982605860ms - DLMS dlms SendReceive
1982605860ms - DLMS S-> 050A0294600294F80295900296280296C0029758020BC0020C68020D10020E60
1982606047ms - DLMS R<- 0C0A0002020FFE16230002020FFE16230002020FFE16230002020FFE16210002020FFE16210002020FFE16210002020FFF161E0002020FFF16200002020FFF161E0002020FFF1620
1982606047ms - DLMS set State: OPEN
1982606188ms - DLMS set State: SENDRECEIVE
1982606188ms - DLMS dlms SendReceive
1982606188ms - DLMS S-> 0501046278010204020412000809060000010000FF0F02120000090C07E80B1504000100008000FF090C07E80B1605000000008000FF0100
1982613079ms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
1982613079ms - DLMS set State: OPEN
1982613250ms - DLMS Close
1982613250ms - DLMS set State: CLOSING
1982613313ms - DLMS set State: CLOSED
1982613313ms - DLMS Reset
Let me know if you need more data (Maybe the HDLC trace)
Best regards,
Javier
jabayter
Hello, I have an update…
I have an update regarding the issue.
My goal is to automate this task by reading the GenericProfile directly from Python, but I haven’t been able to achieve this yet.
I managed to successfully read the GenericProfile using GXDLMSDirector. Below are the steps I followed after connecting to the meter:
1. Navigate to the subpage 1.0.99.1.0.255 Ch. 0 Load Profile with recording period 1 #1.
2. In the Reading tab, select the "Button Read From" radio button and enter the date range.
3. Right-click on the ProfileGeneric folder and select the "Read" option.
4. After that, the read values for all subobjects are displayed in the same tab. From here, I realized that I need to extract Attribute 2 of the Load Profile 1.0.99.1.0.255 Ch. 0.
Additionally, I’m including the hex trace from GXDLMSDirector:
Read object type ProfileGeneric index: 4
TX: 7E A0 14 00 02 2C 19 41 FA D1 34 E6 E6 00 05 01 02 60 F8 BA 8D 7E
RX: 7E A0 17 41 00 02 2C 19 DE DE 68 E6 E7 00 0C 01 00 06 00 00 00 00 EA 83 7E
Read object type ProfileGeneric index: 5
TX: 7E A0 14 00 02 2C 19 41 1C E9 B6 E6 E6 00 05 01 02 61 00 A5 EF 7E
RX: 7E A0 14 41 00 02 2C 19 F0 CC 08 E6 E7 00 0C 01 00 16 01 E9 38 7E
Read object type ProfileGeneric index: 6
TX: 7E A0 14 00 02 2C 19 41 3E F9 B4 E6 E6 00 05 01 02 61 08 ED 63 7E
RX: 7E A0 24 41 00 02 2C 19 12 9A 1A E6 E7 00 0C 01 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 57 AB 7E
Reading profile generic data
TX: 7E A0 47 00 02 2C 19 41 50 20 E4 E6 E6 00 05 01 04 60 E8 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 0B 17 FF 00 00 00 FF 80 00 00 09 0C 07 E8 0B 18 FF 00 00 00 FF 80 00 00 01 00 D1 0D 7E
RX: 7E A0 14 41 00 02 2C 19 34 E4 88 E6 E7 00 0C 01 00 01 00 F9 F1 7E
Read object type ProfileGeneric index: 7
TX: 7E A0 14 00 02 2C 19 41 72 91 3C E6 E6 00 05 01 02 61 10 24 FF 7E
RX: 7E A0 17 41 00 02 2C 19 56 9E 60 E6 E7 00 0C 01 00 06 00 00 00 64 C8 A6 7E
Read object type ProfileGeneric index: 8
TX: 7E A0 14 00 02 2C 19 41 94 A9 BE E6 E6 00 05 01 02 61 18 6C 73 7E
RX: 7E A0 17 41 00 02 2C 19 78 E2 A8 E6 E7 00 0C 01 00 06 00 00 00 64 C8 A6 7E
TX: 7E A0 14 00 02 2C 19 41 B6 B9 BC E6 E6 00 05 01 02 62 88 8D CD 7E
RX: 7E A0 17 41 00 02 2C 19 9A FE 6C E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
TX: 7E A0 14 00 02 2C 19 41 D8 C1 36 E6 E6 00 05 01 02 62 90 44 51 7E
RX: 7E A0 14 41 00 02 2C 19 BC A4 80 E6 E7 00 0C 01 00 16 01 E9 38 7E
TX: 7E A0 14 00 02 2C 19 41 FA D1 34 E6 E6 00 05 01 02 62 98 0C DD 7E
RX: 7E A0 24 41 00 02 2C 19 DE FA 16 E6 E7 00 0C 01 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 57 AB 7E
TX: 7E A0 47 00 02 2C 19 41 1C 48 6C E6 E6 00 05 01 04 62 78 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 0B 16 FF 00 01 00 FF 80 00 00 09 0C 07 E8 0B 17 FF 00 00 00 FF 80 00 00 01 00 E5 F8 7E
RX: 7E A8 80 41 00 02 2C 19 F0 D2 79 E6 E7 00 0C 01 00 01 61 02 0C 09 0C 07 E8 0B 16 05 00 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 45 05 00 00 1A 5C 05 00 00 1A 0E 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 00 1E 00 FF 80 00 00 06 01 80 00 04 EA 28 7E
TX: 7E A0 0A 00 02 2C 19 41 31 E6 7F 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 36 05 00 00 1A 4F 05 00 00 1A 01 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 00 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 CB D8 7E
TX: 7E A0 0A 00 02 2C 19 41 51 E0 1C 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 40 05 00 00 1A 5C 05 00 00 1A 0B 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 01 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 42 05 00 00 1A 5E 05 00 00 1A 10 EE 26 7E
TX: 7E A0 0A 00 02 2C 19 41 71 E2 3D 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 01 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 43 05 00 00 1A 60 05 00 00 1A 12 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 84 D1 7E
TX: 7E A0 0A 00 02 2C 19 41 91 EC DA 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 01 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 4A 05 00 00 1A 68 05 00 00 1A 1A 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 01 2D 00 FF 80 00 00 06 01 80 00 04 11 72 7E
TX: 7E A0 0A 00 02 2C 19 41 B1 EE FB 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 51 05 00 00 1A 6F 05 00 00 1A 22 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 02 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 A0 5F 7E
TX: 7E A0 0A 00 02 2C 19 41 D1 E8 98 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 5C 05 00 00 1A 79 05 00 00 1A 2B 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 02 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 65 05 00 00 1A 81 05 00 00 1A 35 41 82 7E
TX: 7E A0 0A 00 02 2C 19 41 F1 EA B9 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 02 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 6C 05 00 00 1A 88 05 00 00 1A 3C 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 C2 92 7E
TX: 7E A0 0A 00 02 2C 19 41 11 E4 5E 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 02 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5D 05 00 00 1A 79 05 00 00 1A 2D 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 03 00 00 FF 80 00 00 06 01 80 00 04 71 43 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 66 05 00 00 1A 83 05 00 00 1A 38 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 03 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 63 8A 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 6C 05 00 00 1A 8B 05 00 00 1A 3F 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 03 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 6B 05 00 00 1A 8C 05 00 00 1A 41 52 D1 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 03 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 72 05 00 00 1A 93 05 00 00 1A 48 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 F1 55 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 04 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 75 05 00 00 1A 95 05 00 00 1A 49 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 04 0F 00 FF 80 00 00 06 01 80 00 04 63 DA 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 78 05 00 00 1A 97 05 00 00 1A 4C 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 04 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 5A 86 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 7E 05 00 00 1A A0 05 00 00 1A 55 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 04 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 0A 14 00 00 00 00 00 00 00 00 05 00 00 1A 89 05 00 00 1A AA 05 00 00 1A 5E 90 9A 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 05 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 8C 05 00 00 1A AB 05 00 00 1A 5E 05 00 00 00 02 05 00 00 00 02 05 00 00 00 02 4D 7D 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 05 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 0A 14 00 00 00 00 00 00 00 00 05 00 00 1A 91 05 00 00 1A AE 05 00 00 1A 62 05 00 00 00 02 05 00 00 00 02 05 00 00 00 02 02 0C 09 0C 07 E8 0B 16 05 05 1E 00 FF 80 00 00 06 01 80 00 04 A3 82 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 90 05 00 00 1A B0 05 00 00 1A 63 05 00 00 00 02 05 00 00 00 02 05 00 00 00 02 02 0C 09 0C 07 E8 0B 16 05 05 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 0A 31 BB 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 93 05 00 00 1A B2 05 00 00 1A 66 05 00 00 00 02 05 00 00 00 02 05 00 00 00 02 02 0C 09 0C 07 E8 0B 16 05 06 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 0A 14 00 00 00 00 00 00 00 00 05 00 00 1A A0 05 00 00 1A BC 05 00 00 1A 72 A1 AD 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 03 05 00 00 00 02 05 00 00 00 02 02 0C 09 0C 07 E8 0B 16 05 06 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 0A 14 00 00 00 00 00 00 00 00 05 00 00 1A 8E 05 00 00 1A AC 05 00 00 1A 64 05 00 00 00 02 05 00 00 00 02 05 00 00 00 02 55 29 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 06 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 81 05 00 00 1A A1 05 00 00 1A 5A 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 06 2D 00 FF 80 00 00 06 01 80 00 04 FE 72 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 82 05 00 00 1A A0 05 00 00 1A 5B 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 07 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 0A 8B 7A 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 7D 05 00 00 1A 9A 05 00 00 1A 57 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 07 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 82 05 00 00 1A 9E 05 00 00 1A 5B 42 AE 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 07 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 7C 05 00 00 1A 97 05 00 00 1A 55 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 75 67 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 07 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 09 14 00 00 00 00 00 00 00 00 05 00 00 1A 72 05 00 00 1A 8D 05 00 00 1A 4B 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 08 00 00 FF 80 00 00 06 01 80 00 04 09 DE 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 68 05 00 00 1A 83 05 00 00 1A 44 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 08 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 63 A0 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 5B 05 00 00 1A 73 05 00 00 1A 36 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 08 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 4F 05 00 00 1A 66 05 00 00 1A 2B 0B A2 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 08 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 47 05 00 00 1A 5D 05 00 00 1A 24 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 E9 7C 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 09 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 59 05 00 00 1A 6F 05 00 00 1A 36 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 09 0F 00 FF 80 00 00 06 01 80 00 04 D3 94 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 48 05 00 00 1A 5D 05 00 00 1A 26 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 09 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 41 82 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 40 05 00 00 1A 53 05 00 00 1A 1E 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 09 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 41 05 00 00 1A 58 05 00 00 1A 21 CE 83 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0A 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 34 05 00 00 1A 47 05 00 00 1A 14 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 96 42 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 0A 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 2D 05 00 00 1A 3B 05 00 00 1A 09 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0A 1E 00 FF 80 00 00 06 01 80 00 04 7D 8E 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 30 05 00 00 1A 45 05 00 00 1A 0D 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0A 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 3D 90 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 35 05 00 00 1A 47 05 00 00 1A 10 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0B 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 2B 05 00 00 1A 40 05 00 00 1A 08 4E D7 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0B 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 16 05 00 00 1A 27 05 00 00 19 EF 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 CD DE 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 0B 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 1F 05 00 00 1A 2D 05 00 00 19 F5 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0B 2D 00 FF 80 00 00 06 01 80 00 04 B6 8B 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 06 14 00 00 00 00 00 00 00 00 05 00 00 1A 26 05 00 00 1A 37 05 00 00 19 FB 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0C 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 CA 9F 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 2C 05 00 00 1A 42 05 00 00 1A 04 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0C 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 36 05 00 00 1A 4F 05 00 00 1A 0E 8F 81 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0C 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 3F 05 00 00 1A 5A 05 00 00 1A 16 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 BF 28 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 0C 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 48 05 00 00 1A 61 05 00 00 1A 1F 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0D 00 00 FF 80 00 00 06 01 80 00 04 7A CD 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 46 05 00 00 1A 60 05 00 00 1A 1C 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0D 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 23 DA 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 41 05 00 00 1A 58 05 00 00 1A 16 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0D 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 41 05 00 00 1A 54 05 00 00 1A 15 1E 29 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0D 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 39 05 00 00 1A 4F 05 00 00 1A 0E 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 50 50 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 0E 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 29 05 00 00 1A 42 05 00 00 19 FF 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0E 0F 00 FF 80 00 00 06 01 80 00 04 D9 CB 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 06 14 00 00 00 00 00 00 00 00 05 00 00 1A 20 05 00 00 1A 3A 05 00 00 19 F9 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0E 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 57 40 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 22 05 00 00 1A 3E 05 00 00 19 FC 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0E 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 25 05 00 00 1A 43 05 00 00 1A 00 63 EE 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0F 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 24 05 00 00 1A 41 05 00 00 19 FE 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 A0 26 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 0F 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 23 05 00 00 1A 41 05 00 00 1A 01 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0F 1E 00 FF 80 00 00 06 01 80 00 04 8E F9 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 31 05 00 00 1A 4F 05 00 00 1A 10 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 0F 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 5C 76 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 39 05 00 00 1A 55 05 00 00 1A 19 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 10 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 3C 05 00 00 1A 59 05 00 00 1A 1C 4E 0A 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 10 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 42 05 00 00 1A 5E 05 00 00 1A 20 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 E2 23 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 10 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 46 05 00 00 1A 60 05 00 00 1A 23 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 10 2D 00 FF 80 00 00 06 01 80 00 04 85 36 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 4D 05 00 00 1A 64 05 00 00 1A 29 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 11 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 63 C2 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 5A 05 00 00 1A 70 05 00 00 1A 34 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 11 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5A 05 00 00 1A 70 05 00 00 1A 31 9A 77 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 11 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 56 05 00 00 1A 6C 05 00 00 1A 2A 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 DD 10 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 11 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 4B 05 00 00 1A 5C 05 00 00 1A 1D 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 12 00 00 FF 80 00 00 06 01 80 00 04 EB 77 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 51 05 00 00 1A 63 05 00 00 1A 22 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 12 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 82 CB 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 5C 05 00 00 1A 6D 05 00 00 1A 29 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 12 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5D 05 00 00 1A 6A 05 00 00 1A 27 61 0C 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 12 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5C 05 00 00 1A 68 05 00 00 1A 26 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 9C 6E 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 13 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5D 05 00 00 1A 6A 05 00 00 1A 25 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 13 0F 00 FF 80 00 00 06 01 80 00 04 0F 38 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5F 05 00 00 1A 6B 05 00 00 1A 26 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 13 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 7F 14 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 5F 05 00 00 1A 6C 05 00 00 1A 27 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 13 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5D 05 00 00 1A 6C 05 00 00 1A 26 8C E9 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 14 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5A 05 00 00 1A 6A 05 00 00 1A 24 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 23 AB 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 14 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5C 05 00 00 1A 6C 05 00 00 1A 25 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 14 1E 00 FF 80 00 00 06 01 80 00 04 70 DC 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 5E 05 00 00 1A 6E 05 00 00 1A 26 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 14 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 D7 72 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 5D 05 00 00 1A 6E 05 00 00 1A 26 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 15 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 57 05 00 00 1A 67 05 00 00 1A 1F 3C 85 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 15 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 4D 05 00 00 1A 5E 05 00 00 1A 16 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 65 A4 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 16 05 15 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 48 05 00 00 1A 59 05 00 00 1A 10 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 15 2D 00 FF 80 00 00 06 01 80 00 04 4D 97 7E
RX: 7E A8 7E 41 00 02 2C 19 FA F8 C7 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 45 05 00 00 1A 56 05 00 00 1A 0E 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 16 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 0F 7A 7E
RX: 7E A8 7B 41 00 02 2C 19 FC 6D 52 14 00 00 00 00 00 00 00 00 05 00 00 1A 42 05 00 00 1A 52 05 00 00 1A 0B 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 16 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 44 05 00 00 1A 56 05 00 00 1A 0D BF 17 7E
RX: 7E A8 72 41 00 02 2C 19 FE 46 30 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 16 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 42 05 00 00 1A 55 05 00 00 1A 0C 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 22 1C 7E
RX: 7E A8 78 41 00 02 2C 19 F0 6F 30 02 0C 09 0C 07 E8 0B 16 05 16 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 42 05 00 00 1A 56 05 00 00 1A 0E 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 17 00 00 FF 80 00 00 06 01 80 00 04 61 2D 7E
RX: 7E A8 7E 41 00 02 2C 19 F2 B0 4B 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 42 05 00 00 1A 58 05 00 00 1A 10 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 17 0F 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 7B 8C 7E
RX: 7E A8 7B 41 00 02 2C 19 F4 25 DE 14 00 00 00 00 00 00 00 00 05 00 00 1A 43 05 00 00 1A 5A 05 00 00 1A 12 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 17 1E 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 07 14 00 00 00 00 00 00 00 00 05 00 00 1A 48 05 00 00 1A 61 05 00 00 1A 17 F7 07 7E
RX: 7E A8 72 41 00 02 2C 19 F6 0E BC 05 00 00 00 02 05 00 00 00 01 05 00 00 00 01 02 0C 09 0C 07 E8 0B 16 05 17 2D 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 03 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 4E 05 00 00 1A 67 05 00 00 1A 1D 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 ED 89 7E
RX: 7E A8 78 41 00 02 2C 19 F8 27 BC 02 0C 09 0C 07 E8 0B 17 06 00 00 00 FF 80 00 00 06 01 80 00 04 14 00 00 00 00 00 00 00 02 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 08 14 00 00 00 00 00 00 00 00 05 00 00 1A 51 05 00 00 1A 6C 05 00 00 1A 23 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 02 0C 09 0C 07 E8 0B 17 06 00 00 00 FF 80 00 00 06 01 08 00 04 1B 47 7E
RX: 7E A0 4E 41 00 02 2C 19 FA 0E 3C 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 05 00 00 1A 51 05 00 00 1A 6C 05 00 00 1A 23 05 00 00 00 02 05 00 00 00 02 05 00 00 00 01 33 AA 7E
TX: 7E A0 14 00 02 2C 19 41 DE F7 53 E6 E6 00 05 01 02 62 A0 C7 60 7E
RX: 7E A0 17 41 00 02 2C 19 1C C0 8D E6 E7 00 0C 01 00 06 00 00 6A 18 06 87 7E
TX: 7E A0 14 00 02 2C 19 41 F0 8B 9B E6 E6 00 05 01 02 62 A8 8F EC 7E
RX: 7E A0 17 41 00 02 2C 19 3E D0 8F E6 E7 00 0C 01 00 06 00 00 6A 18 06 87 7E
TX: 7E A0 14 00 02 2C 19 41 12 97 5F E6 E6 00 05 01 02 64 18 D4 0D 7E
RX: 7E A0 17 41 00 02 2C 19 50 A8 05 E6 E7 00 0C 01 00 06 00 00 00 00 EA 83 7E
TX: 7E A0 14 00 02 2C 19 41 34 A3 1B E6 E6 00 05 01 02 64 20 1F B0 7E
RX: 7E A0 14 41 00 02 2C 19 72 D6 AF E6 E7 00 0C 01 00 16 01 E9 38 7E
TX: 7E A0 14 00 02 2C 19 41 56 B7 5B E6 E6 00 05 01 02 64 28 57 3C 7E
RX: 7E A0 24 41 00 02 2C 19 94 A4 FB E6 E7 00 0C 01 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 57 AB 7E
TX: 7E A0 47 00 02 2C 19 41 78 6A 49 E6 E6 00 05 01 04 64 08 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 0B 17 FF 00 00 00 FF 80 00 00 09 0C 07 E8 0B 18 FF 00 00 00 FF 80 00 00 01 00 60 83 7E
RX: 7E A0 14 41 00 02 2C 19 B6 FE 2F E6 E7 00 0C 01 00 01 00 F9 F1 7E
TX: 7E A0 14 00 02 2C 19 41 9A D7 57 E6 E6 00 05 01 02 64 30 9E A0 7E
RX: 7E A0 17 41 00 02 2C 19 D8 E8 0D E6 E7 00 0C 01 00 06 00 00 00 0F 1D 7B 7E
TX: 7E A0 14 00 02 2C 19 41 BC E3 13 E6 E6 00 05 01 02 64 38 D6 2C 7E
RX: 7E A0 17 41 00 02 2C 19 FA F8 0F E6 E7 00 0C 01 00 06 00 00 00 0F 1D 7B 7E
Any help or guidance on how to proceed would be greatly appreciated.
Thank you!
Hi, E650 can't handle status…
E650 can't handle status and deviation and you need to ignore them. You can do it like this:
GXDateTime start = new GXDateTime(start Time);
start.Skip |= DateTimeSkips.Status | DateTimeSkips.Deviation
You must do the same for the end time.
