  3. Import Certificate Failed
import certificate failed
By hxiii , 20 November, 2024
When director import certificate to meter with GBT, it seems that the bit which indicates ‘last block’ not be set. Please help check it.Thanks!
log:
14:38:46
7E A0 4C 02 21 81 FE 2B 2A E6 E6 00 E0 01 00 01 00 00 38 DF 00 08 43 54 54 30 30 30 30 30 08 56 61 6E 67 6F 33 32 31 00 00 82 01 B5 CB 82 01 B1 31 00 00 00 06 24 CF 0B 22 1C 3B 33 CF 9C 0A 7C 4C E0 75 A8 FF E6 17 5D 33 CD F3 6D DB 7E
14:38:46
7E A0 14 81 02 21 1E 64 A9 E6 E7 00 E0 81 00 16 00 16 00 30 81 7E
14:38:46
7E A0 8D 02 21 81 10 68 64 E6 E6 00 E0 01 00 02 00 01 79 F9 C9 D4 6A 98 E5 D1 3B 86 29 EF 53 8C AE ED 99 6A AC E3 27 18 C0 73 C6 D3 4E C9 8F 63 2B 20 DB 0E 01 6F 60 1E 8E AF 2E 42 A7 56 1A B7 D2 7A 87 39 98 7E 69 50 9D 87 C9 21 29 E4 93 FA 23 CA C5 71 3F 45 95 87 21 AC 74 66 08 A3 5C 6E 0A 1B D4 6C 8A 80 3A EB A9 CF 2A 5A 44 63 00 6E B9 3C E9 D7 05 1E 74 59 4E 85 0C 85 01 DF C9 CA 4A 7F 87 3C 1D 1A 01 10 57 59 EE A9 5D 08 7E
14:38:47
7E A0 14 81 02 21 30 18 61 E6 E7 00 E0 81 00 17 00 17 00 53 84 7E
14:38:47
7E A0 8D 02 21 81 32 78 66 E6 E6 00 E0 01 00 03 00 03 79 F5 CC 15 F6 69 28 6A AB 79 93 CA 2B 1F 36 40 37 22 00 4F D0 2D 67 22 CA 51 02 43 21 C8 A0 9A AD 71 C7 AE 77 9D BD 2D 84 49 48 E7 31 AE 8D 88 D2 6E 0F 3B EC A4 94 5F 0D 57 4F 88 69 8F C9 81 51 5F 07 41 C3 EF 46 C0 A3 ED AD 4F CB 89 EB 12 84 FB 71 08 4A 34 9B 91 63 41 7E 8D 9F C2 2F A8 CC DE A7 D2 B8 42 DE 8C 56 76 D0 CD 7A F7 CF 95 A9 2E D0 08 07 DE 3A CA 9D 63 B9 E6 7E
14:38:47
7E A0 14 81 02 21 52 0C 21 E6 E7 00 E0 81 00 18 00 18 00 62 B5 7E
14:38:47
7E A0 8D 02 21 81 54 48 60 E6 E6 00 E0 01 00 04 00 05 79 B4 C5 42 DF 9E DA 52 16 B6 FC 76 F2 16 88 99 33 9B 20 24 56 B8 EE 01 97 38 54 5F 8B E2 2F 8B 48 59 65 AA FC D7 E3 2C 45 5B C2 CA 4D 6D 19 3F 44 D7 7E 33 82 1B 0D F2 3E 90 F8 93 2B 38 E9 DD 80 89 3C AB 7A 16 78 02 51 63 99 24 95 C3 D2 52 9B 72 35 6A D0 1C 18 7C 44 89 4E B9 0F 89 22 92 F6 1F 1E 68 31 F2 15 11 8B B2 AA FC DB F7 6C A3 04 58 D4 14 20 FC 90 F1 11 DD 82 79 7E
14:38:47
7E A0 14 81 02 21 74 38 65 E6 E7 00 E0 81 00 19 00 19 00 01 B0 7E
14:38:47
7E A0 80 02 21 81 76 2C 1E E6 E6 00 E0 01 00 05 00 07 6C 63 6D 48 6D CA 80 BC 23 93 5F 26 67 CE 70 68 F5 01 66 44 89 39 0D E6 2C 00 76 68 F0 CF 34 1E D2 2D FC 8D 66 3F 07 23 4F 64 02 D1 40 99 47 D8 71 BA AE FA 9A 91 45 BF 62 C6 58 A9 42 03 A9 7C F9 1A 4A 4F DF 89 30 52 89 FA D6 AE 5B BC FE 9D 5E 4A C3 BB 93 A9 74 F9 52 A2 0A 49 37 42 8B 94 6D 1E CE C0 8D B8 FA E4 4A 76 1A 0B 99 EC DD 7E
14:38:47
7E A0 14 81 02 21 96 24 A1 E6 E7 00 E0 81 00 1A 00 1A 00 A4 BF 7E
2 years ago
Hi, The last block is set to…
The last block is set to True for the last packet. Can you share the block cipher key so I can check this from the bytes?
hxiii
2 years ago
The block cipher key is…
The block cipher key is 1111111111111111. And the authentication key is 2222222222222222. Thanks for your help!
2 years ago
Hi, Your certificate is not…
Your certificate is not complete. There should be 498 bytes, but there are only 433 bytes. Have you tried updating your certificate with GXDLMSDirector or just selected this group? Have you made any changes to GXDLMSDirector?
hxiii
1 year 10 months ago
Hi, I try to import P-256…
I tried to import P-256 certificate using director and was successful. But failed with P-384 certificate. Abnormal phenomenon remains the same as before. The version of director is 9.0.241231. The certificates generated by director. Please help to check it. Thanks!
Hi, DLMS meters supports…
DLMS meters supports only P-256 or P-384 certificates, not both.
Select Security Setuo object and read Suite attribute. If it's #1 you must use P-256 and P-384 for Suite #2
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSSecuritySetup
hxiii
Hi, I choose another sap…
I choose another sap which support suite2. However, it still failed like before.
GUEK: 11111111111111111111111111111111
GAK:22222222222222222222222222222222
Logs as below:
13:38:26
TX: 7E A0 AB 02 21 C1 54 27 7D E6 E6 00 E0 01 00 01 00 00 81 96 DF 00 08 43 54 54 30 30 30 30 31 08 56 61 6E 67 6F 33 32 31 00 00 82 01 F2 CB 82 01 EE 32 00 00 00 02 D7 D4 C3 6E DB 30 84 35 45 08 E7 D8 FE CC 5E 70 56 A9 D8 E1 F8 0A 1D 35 E6 F6 55 2F 87 D0 21 2E CB 1B F3 C9 40 A9 89 95 61 32 5A 85 1B F3 FC F4 26 95 DB 93 8D B8 54 17 9A FE A7 7E 3C 51 19 74 2C 28 0D 72 E0 A4 FE D1 77 7A 07 4E DC B3 A0 DD D0 CB 12 6C E8 64 6C B3 93 CB 0F A8 52 10 15 44 28 80 7B 9F 57 4E F3 45 30 96 31 3E 05 FB 18 E2 A0 00 55 FB F1 95 7E
13:38:27
RX: 7E A0 14 C1 02 21 74 8F 73 E6 E7 00 E0 81 00 01 00 01 00 29 CD 7E
13:38:27
TX: 7E A1 0E 02 21 C1 76 8C B7 E6 E6 00 E0 01 00 02 00 01 81 F9 17 BE 0A 74 12 5E 97 FD 3D 6D 2E E4 4E 61 87 22 3C 50 DE 77 9C 4C 53 3F CA 90 BC 75 E8 42 CA 64 50 BB 94 B9 99 61 0C 23 15 62 FD 97 24 96 75 1B 71 72 8F FC 80 59 CA FA DA F4 B5 7A EA 1C 78 CA 46 4B 4A 86 35 E6 F8 86 1A BF ED 6E C8 90 82 F3 6D E0 45 BB 2C 49 EB 39 B2 03 3C CB 34 C9 6F AF 84 25 A8 81 B3 29 AB A2 29 D3 D2 15 3F 6C 72 3B 10 AF 9D 83 1A B9 4B 6C 13 C0 FD 4D 99 75 29 0C DF F0 6D 8F 27 8D 75 A1 87 4E 27 82 4E 5C C7 72 9B 6B 7C 62 4E A7 B1 10 3F 39 7B 01 23 86 C2 57 44 A3 9A C5 73 95 7B AF 13 74 DD E4 F5 BC F7 81 54 B9 E5 8B C3 32 98 66 8B 8E 8F 05 51 9B BF D3 DA 7D 6F 52 3A 42 38 83 61 C8 2C C3 EE CD EA 6E E8 ED A3 E3 06 F6 CD 23 68 61 C8 CE DD F7 A2 F1 59 03 66 68 EE C9 51 05 7A C6 D3 BA B4 D5 B9 EF D5 8F 51 C1 6B C2 9B F8 5C 66 42 7E
13:38:27
RX: 7E A0 14 C1 02 21 96 93 B7 E6 E7 00 E0 81 00 02 00 02 00 8C C2 7E
13:38:27
TX: 7E A0 F2 02 21 C1 98 41 55 E6 E6 00 E0 01 00 03 00 03 81 DD A4 BC 4C 4C 38 D7 AE 95 3A 05 F4 74 9A 60 57 1D A3 FE 5F 7A A9 62 A3 6F 77 7F 32 64 19 8C F3 80 90 57 CC C2 62 A1 FD E2 22 89 05 08 76 5C 64 E1 E8 20 7E A8 0F 5F C3 EA 52 9D D8 EF 4E 8F 67 A9 56 7E E1 99 A4 42 CE 96 0A C2 BA 3E A9 39 C5 EE F7 A7 49 2B DB EC 06 D1 04 54 D9 90 CA A5 36 84 61 DF A9 33 DC 00 D6 B8 2A C9 82 8C A1 B9 78 A8 E2 3B 0C 0D DE 5D 75 FC 76 0E 41 E6 60 12 73 66 58 EB 28 63 FD C3 A7 EE 01 2F D5 FE CD A2 FA 23 96 DD 60 BA 04 F2 79 EF FF 5A FB 5E A7 53 9C 54 9A 4F 12 CE 40 1B 56 AD D0 48 EB B2 68 9E 85 24 63 EE DD 5E 79 F2 27 27 23 47 96 BA CA 00 4B 33 21 18 94 15 2E E6 7F 97 2A 5A F7 AC D6 E3 C7 63 B1 FB 16 FC 99 80 90 3A 19 EE E5 83 59 84 BA 7E
13:38:28
RX: 7E A0 14 C1 02 21 B8 EF 7F E6 E7 00 E0 81 00 03 00 03 00 EF C7 7E
Hi, I need the client's…
I need the client's system title to decrypt the data.
hxiii
Hi, Client system title is …
Client system title is “CTT00001”, and server system title is “Vango321”. Thanks!
Hi, You are sending your…
You are sending your data with general signing and not with GMAC. You are using Security Suite 2. Because I don't have your public key, I can't decrypt the sent data and validate it.
Have you updated P-384 private key and certificate to the meter?
hxiii
Hi, The data was sent by…
The data was sent by director using both of general-signing and GMAC. You can find the sh of “32 00 00 00 02” follows “additional field”. The only use of the public-private key pairs is for signing.
The meter has P-384 private key and certificate. I just want to import another one to meter.
In addition, I can use this configuration for communication, such as writing and reading.
Hi, I can't decrypt the data…
I can't decrypt the data with the GUEK you shared. This means that your data is encrypted with different key.
hxiii
Hi, Because the director…
Because the director uses GBT to send data, you need to concatenate the data sent three times. I have confirmed with the DLMS translator that the data can be decrypted.
Hi, My bad. I was using…
My bad. I was using security suite 1 instead of 2.
At first glance, the data looks correct, and the general signing tag is there.
You have generated the certificate with GXDLMSDirector so I can check this.
hxiii
Hi, Thanks for your help…
Thanks for your help. Looking forward to hearing from you.
