  3. Check The Session To See If It Is Closed
Check the session to see if it is closed
By JavierDiaz , 27 September, 2024
I`m reading register 1.0.1.8.0.255, but no response from device received.
[TraceRX] 7EA01A02DF6132071DE6E600C001C100030100010800FF020032687E
[TraceRX] 7EA0086102DF1171C07E
Please tell me what this means?
Can I determine that the session is closed and not read the next object?
Thank you
2 years 1 month ago
Hi, The meter asks the next…
The meter asks the next part of the client data and this is wrong because all the data is already sent. I believe that the meter has terminated the connection.
