  2. Got OctetString - How To Convert Data To C String or Std::string?
Got OctetString - how to convert data to C string or std::string?
By latonita , 18 September, 2024
Hi.
I'm getting data from the meter, it is the manufacturer name.
7E.A0.22.41.03.74.F7.D0.E6.E7.00.C4.01.C1.00.09.10.45.6E.65.72.67.6F.6D.65.72.61.00.00.00.00.00.00.19.92.7E
So it has OctetString
<Data>
<OctetString Value="456E6572676F6D657261000000000000" />
</Data>
This is a hex view of a string "Energomera".
I used cl_updateValue(), then I did var_toString() and what I got is same hex string but separated by spaces.
So I had to do stupid thing and manually convert hex view to null terminated C string
I believe there is a proper way to get proper bytes out of this hex-octet-string.
How do I properly get this octet string converted to bytes?
Thank you.
1 year 10 months ago
HI, The easiest way to show…
HI,
The easiest way to show this as a string is cast it to the char*.
dlmsVARIANT* value = //Get Value.
//Add '\0'
bb_setInt8(value->byteArr, 0);
const char* str = value->byteArr->data;
//Remove '\0'
--value->byteArr->size
latonita
Thank you! This works…
Thank you! This works perfect. I didn't notice there is raw-bytes array available.
