  2. Decrypt Failed.Invalid Authentication Tag.
Decrypt failed.Invalid authentication tag.
By hxiii , 6 August, 2024
Hi, the newest director(9.0.2405.2801) keeps reporting error of “Decrypt failed.Invalid authentication tag.”when I use general-signing & gmac. I have checked the authentication tag,and it is correct.
In addition, I test with an older version of director,and it works well.The version maybe 8.2.xxxx.xxxx. Is there some difference between two version?
Looking forward to your earlier reply.
hxiii
2 years ago
It is the message, 11:14:56…
It is the message,
11:14:56 Read object type Data index: 2
7E A0 87 00 0C 00 07 81 54 E4 C5 E6 E6 00 DF 00 08 43 54 54 30 30 30 30 30 08 56 61 6E 67 6F 33 32 31 00 00 20 C8 1E 31 00 00 00 02 8B C6 D4 63 6F 50 34 D3 6C 3D C7 E3 F2 E8 7C D7 56 EB B0 4D 1F 69 61 49 1F 40 1B 92 15 25 C6 42 69 B3 FE 6B 2B DB 1D F7 F7 CB 0D E2 A2 44 CE B7 BE 5C 97 F6 9F 8E C0 A9 BE 2F 21 4C AC E3 51 B7 41 51 30 0D BF A5 52 99 2E C6 DF 52 F6 28 0A 0B 4A 54 E3 36 9D A6 93 FF 75 98 08 61 7E
11:14:58
7E A0 90 81 00 0C 00 07 74 A3 23 E6 E7 00 DF 00 08 56 61 6E 67 6F 33 32 31 08 43 54 54 30 30 30 30 30 00 00 29 CC 27 31 00 00 00 02 09 D1 DF 71 B1 3F 2C 29 6F D7 8F FE C7 55 4E 56 73 AC 0B 3F 4E C5 5F 0C 47 58 F8 AA AD 6C C5 B4 FC 87 40 96 B4 05 FB 58 47 AC 4D E6 6D A8 CC 6A DF 6F BC D2 DF D3 DC 98 66 96 F4 78 FA 1D 4E 51 A7 F8 88 FB 9C B9 7A 5E 32 95 07 3D C6 FF 5A 3B 32 BA E8 A7 DB 91 40 83 67 33 CF 8E 38 43 BF EE 65 9D 8D 77 46 7E
Gurux.DLMS.GXDLMSCipherException: Decrypt failed. Invalid authentication tag.
在 Gurux.DLMS.Secure.GXGMac.Decrypt(Byte[] data, Byte tag, GXDLMSTranslatorStructure xml)
and I have checked the authentication tag with translator, it is correct.
2 years ago
Hi, Version 8.x doesn't…
Version 8.x doesn't support General signing. General signing is using ECDSA private and public keys. It also doesn't verify the authentication tag.
There is something wrong in your authentication tag. If you share the authentication and block cipher keys, I can check if I find anything.
hxiii
2 years ago
Hi, authentication key is…
authentication key is 2222222222222223,and block cipher key is 1111111111111112.
hxiii
2 years ago
continuous
continuous
  • Elster a1800 clock reset to year 2000 with one tariff billing
