  3. Conformance Test
conformance test
By shagufta , 14 May, 2024
HELLO SIR!! can you please provide me a solution my all conformance test is getting failed I tried more then 3 meters i'am getting same result please have a look at logs and provide me a solution to pass ma conformance test for meter
/*****LOGS*****/
11.49.11 Send SNRM request.
11.49.11
11.49.11 Send AARQ request.
11.49.11
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 1C EA 7E
11.49.11 HDLC test #1. Disconnect request
11.49.11
11.49.11 HDLC test #1. SNRM request
11.49.11
11.49.11
SNRM request succeeded. MaxInfoLengthTransmit: 128 MaxInfoLengthReceive: 128 WindowSizeTransmit: 1 WindowSizeReceive: 1
11.49.11 HDLC test #1. Receiver Ready
TX: 7E A0 07 03 21 11 15 A6 7E
11.49.16 Data send failed. Try to resend 1/3 7E A0 07 21 03 11 15 00 7E
11.49.21 Data send failed. Try to resend 2/3 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E
11.49.26 Data send failed. Try to resend 3/3 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E
11.49.31 Failed to receive reply from the device in given time. 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E
11.49.31
RX: 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 11 15 00 7E
11.49.31
Receiver Ready failed.
11.49.31 HDLC test #1. Disconnect request
11.49.31
11.49.31
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc1">Test #1 failed.</a>
11.49.31 HDLC test #2. SNRM request
11.49.31
11.49.31
11.49.31 HDLC test #2. Illegal frame.
11.49.36
11.49.41
11.49.46
11.49.46
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
11.49.46 Disconnect request
11.49.46
2 years 5 months ago
Hi, Your meter is not reply…
Your meter is not reply for Receiver Ready message.
