  2. Valid Values Are Between 0 and 999, Inclusive. Parameter Name: Millisecond and Gurux.DLMS.GXDLMSException: Access Error : Device Reports Read-Write Denied.
Valid values are between 0 and 999, inclusive. Parameter name: millisecond and Gurux.DLMS.GXDLMSException: Access Error : Device reports Read-Write denied.
By muhammad ahmed , 7 May, 2024
I am trying to connect Holley DLMS meter with low authentication when i connect it after some time it gave me the error i think i get these while reading profiles or somting
(Gurux.DLMS.GXDLMSException: Access Error : Device reports Read-Write denied.)
After this when i try to read the data after a while on read it gave me this error.
(system.argumentoutofrangeexception: valid values are between 0 and 999, inclusive. parameter name: millisecond)
Both error logs are below :
Error 1 logs on connection :
at GXDLMSDirector.MainForm.RefreshDevice(GXDLMSMeter dev, Boolean bRefresh)
at GXDLMSDirector.MainForm.Refresh(Object sender, GXAsyncWork work, Object[] parameters)
7:52:20 PM Send Keep Alive
7E A0 19 03 23 BA 9F E3 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 01 00 F9 79 7E
19:52:25 Data send failed. Try to resend 1/3
19:52:30 Data send failed. Try to resend 2/3
7:52:35 PM Failed to receive reply from the device in given time.
19:52:35 Disconnect request
Error 2 logs on reading :
7E AO 72 23 03 96 08 71 E6 E7 00 C4 01 C1 00 01 04 02 03 09 02 53 32 09 OC FF FF 03 01 FF I
Nalid values are between 0 and 999, inclusive.
at GXDLMSDirector.MainForm. ReadDevice GXDLMSMeter d)
at GXDLMSDirector.MainForm. Read(Object sender, GXAsynckork work, Object[] parameters)
1:51:11 AM Send Keep Alive
7E AO 19 03 23 98 8F E1 E6 E 00 CO 01 C1 00 OF 00 00 28 00 00 FF 01 00 F9 79 7E
01:51:16 Data send failed. Try to resend 1/3
01:51:21 Data send failed. Try to resend 2/3
1:51:26 AM Failed to receive reply from the device in given time.
2 years 2 months ago
Hi, Client has sent the keep…
Client has sent the keep alive message and the meter can't handle it. If I remember correctly some of the Holley meters can't handle keep alive because authentication view is not implemented. Can you read any values from the meter? For example the clock?
muhammad ahmed
This meter handle's keep…
This meter handle's keep-alive mode. When I read meter data using Holley's provided software, everything works perfectly. However, when I try to do the same using Gurux software to create HES (Home Energy System) for these meters, I'm unable to read the values.
Here are the steps I'm following:
Step 1:
I add a Holley meter device with a low authentication. Upon connecting, after receiving a long list of OBIS codes in the logs, I encountered the following error on "Get profile generic column.
Gurux.DLMS.GXDLMSException: Access Error: Device reports Read-Write denied."
ERROR LOGS :
7:31:39 PM Get profile generic columns...
7E A0 19 03 23 76 FF EF E6 E6 00 C0 01 C1 00 07 01 60 63 62 0B FF 03 00 63 48 7E
7:31:39 PM
7E A0 36 23 03 96 53 15 E6 E7 00 C4 01 C1 00 01 02 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 60 63 62 1E FF 0F 02 12 00 00 56 27 7E
7:31:39 PM Reading object 0.0.22.0.0.255, interface IecHdlcSetup
7E A0 19 03 23 98 8F E1 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 08 00 CD D0 7E
7:31:39 PM
7E A0 11 23 03 B8 5D 05 E6 E7 00 C4 01 C1 01 03 73 82 7E
Step 2:
After clicking ok to the "Access Error" and attempting to read again by clicking on the meter name and then clicking "read," I receive another error:
"System.ArgumentOutOfRangeException: Valid values are between 0 and 999, inclusive. Parameter name: millisecond."
Error Logs:
7E A0 17 23 03 74 A7 42 E6 E7 00 C4 01 C1 00 09 05 57 41 50 44 41 9B 60 7E
7:51:38 PM Read object type ActivityCalendar index: 3
7E A0 19 03 23 76 FF EF E6 E6 00 C0 01 C1 00 14 00 00 0D 00 00 FF 03 00 F7 8D 7E
7:51:39 PM
7E A0 72 23 03 96 08 71 E6 E7 00 C4 01 C1 00 01 04 02 03 09 02 53 32 09 0C FF FF 03 01 FF FF FF FF 80 00 00 00 09 02 57 32 02 03 09 02 53 33 09 0C FF FF 06 01 FF FF FF FF 80 00 00 00 09 02 57 33 02 03 09 02 53 34 09 0C FF FF 09 01 FF FF FF FF 80 00 00 00 09 02 57 34 02 03 09 02 53 31 09 0C FF FF 0C 01 FF FF FF FF 80 00 00 00 09 02 57 31 ED FA 7E
at GXDLMSDirector.MainForm.ReadDevice(GXDLMSMeter d)
at GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
I'm unable to retrieve any values such as clocks, etc., except for OBIS logs in the notes.
muhammad ahmed
this i how i am reading after the access denied error
muhammad ahmed
When i clone the meter i got…
When i clone the meter i got these attributes
