  3. Requirement To Insert a New Token Each Time
Requirement to insert a new token each time
Profile picture for user or
By or , 20 March, 2024
Gurux.DLMS.AMI
Hi, every time I do a redeployment that includes the Agent, Server and dlms api services. I need new tokens even if I have a valid token from last time. What can I do to use the same valid token even if I redeployed for these services.
2 years 7 months ago
Hi, Do you clear the…
Do you clear the database? If you do, the token is lost.
Agent token is saved to the settings.json file.
If you get a new agent you need to copy settings.json file from the old location to the new location.
