I select "Certificates tab from the "Security setup" object. Then press "Key pair". The error is “access error Device reports a inconsistent Class or object ”.
The server log ie below:
Server address: 1
Associations:
[0.0.40.0.0.255]
0.0.40.0.0.255 Ch. 0 Association #1
0
Client address: 1
Conformance:
[SET, GET, ACTION]
MaxReceivePduSize: 832 MaxSendPduSize: 65535
Security suite: SUITE_1
Security policy: [AUTHENTICATED, ENCRYPTED]
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
TCP/IP connection established.
TX: 7E A0 1E 03 03 73 40 CC 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
RX: 7E A0 6B 03 03 10 CF A9 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 4D 4D 4D 00 00 00 00 00 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 4A 76 0A 21 41 5E 47 1D 55 71 66 3A 29 2E 30 3F BE 23 04 21 21 1F 31 00 00 00 00 C8 78 0A 70 91 93 CB 02 83 8A A3 D2 6E DF FE 3A 36 70 61 60 9B AB 92 91 E3 DA E3 8A 7E
TX: 7E A0 77 03 03 30 58 DC E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4D 4D 4D 00 00 00 00 01 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 5C 30 11 4A 64 67 48 07 69 4F 5E 1C 05 5C 22 3F BE 23 04 21 28 1F 31 00 00 00 00 C9 50 5D D6 FC 61 08 89 B3 04 90 03 C8 79 58 F0 EA 7D 35 98 9D BF 77 3A 27 CA C0 FD 7E
RX: 7E A0 3F 03 03 32 25 0C E6 E6 00 CB 31 31 00 00 00 01 BD BB 1B A6 AC 9E 2D 5B 2B C7 20 A7 1F 14 20 57 AD 3B 9C 2E 1E 85 CF 03 DD A6 AA A8 0F 1D 73 EB 6C FA 67 B0 93 B4 BE 9B 66 A3 B8 C9 70 E3 7E
onPreAction 0.0.40.0.0.255:1
TX: 7E A0 38 03 03 52 02 38 E6 E7 00 CF 2A 31 00 00 00 01 5F 44 6A 0E 50 56 63 D9 CE 51 9D D8 99 87 4B 8A 46 02 3B 10 9B 94 24 31 3B 88 C8 15 03 EE AE 72 91 C8 5B 38 1B 68 27 7E
RX: 7E A0 2E 03 03 54 0F D5 E6 E6 00 CB 20 31 00 00 00 02 C8 4E 5E 20 B5 76 72 53 F3 33 19 2E 79 5C 4B 2B 68 01 02 64 FD 05 43 4C 9C B1 60 FC 88 7E
TX: 7E A0 23 03 03 74 82 7F E6 E7 00 CF 15 31 00 00 00 02 1F D9 31 37 20 52 20 AD 59 A6 54 AA 4E 09 6A C1 DA 86 7E
I have successfully generate…
I have successfully generate a new private key for the meter,generate a new certificate request and Import certificate. I can see the certificates in XML. But Security Setup object' certificates is empty. What is wrong with it?
Hi, Are you using the real…
Are you using the real meter or simulator? I believe that there is no SecuritySetup 0.0.43.0.0.255 available on this association view.
I using the simulator.And…
I using the simulator.And the SecuritySetup 0.0.43.0.0.255 is on this association view.
below is the SecuritySetup :
<GXDLMSSecuritySetup>
<LN>0.0.43.0.0.255</LN>
<Version>1</Version>
<Access>111111</Access>
<MethodAccess>11111111</MethodAccess>
<SecurityPolicy>3</SecurityPolicy>
<SecuritySuite>1</SecuritySuite>
<ClientSystemTitle>4D 4D 4D 00 00 00 00 00</ClientSystemTitle>
<ServerSystemTitle>4D 4D 4D 00 00 00 00 01</ServerSystemTitle>
<SigningKey>MIGHAgEAMBMGByqGSM49AgEGCCqGSM49AwEHBG0wawIBAQQgsTh8QmJtdujar+U7LP6HGgr7RwI9U0xacVLtnQi/9AyhRANCAASoUH//YYrJsvsrqrCrXgiwnGcZ4F2Cr6ikHHxqBb7riMR6PEGdEIVhfh4/dpau05RGVUpQxKsVnLmauvsNDLTf</SigningKey>
<KeyAgreement>MIGHAgEAMBMGByqGSM49AgEGCCqGSM49AwEHBG0wawIBAQQgh3CxySQZuEQdVuwt55YBR8CHHhpUgwkz407ZEHsDTT2hRANCAAQpnB/xWwNLGc18NqiGaZljGblDaPQceVFFAiKspgnu5FnamiUazMzLPdkygKOlXAuvR5m4Bx2+IYcvC8xeK5lX</KeyAgreement>
<TLS>MIGHAgEAMBMGByqGSM49AgEGCCqGSM49AwEHBG0wawIBAQQgh3CxySQZuEQdVuwt55YBR8CHHhpUgwkz407ZEHsDTT2hRANCAAQpnB/xWwNLGc18NqiGaZljGblDaPQceVFFAiKspgnu5FnamiUazMzLPdkygKOlXAuvR5m4Bx2+IYcvC8xeK5lX</TLS>
<ServerCertificates>
<Cert>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</Cert>
<Cert>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</Cert>
<Cert>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</Cert>
<Cert>MIIBizCCASigAwIBAgIDD2q+MAoGCCqGSM49BAMCME4xFDASBgNVBAMMC1Jvb3QgQ0EgMjU2MRcwFQYDVQQKDA5HdXJ1eCBTZWN1cml0eTEQMA4GA1UEBwwHVGFtcGVyZTELMAkGA1UEBhMCRkkwHhcNMjQwMzAxMTA1OTA4WhcNMjUwMzAxMTA1OTA4WjAbMRkwFwYDVQQDDBA0RDRENEQwMDAwMDAwMDAwMFkwEwYHKoZIzj0CAQYIKoZIzj0DAQcDQgAE7fmEcaWBc3jKZR1W8v3ob4TASLdlyDfeTNX8YH1wMx3Drm7rY1x9RP8azF9NdUZH3ki0N2FPJojfWZwqpgLLfaMoMCYwDAYDVR0jBAUwA4IBADAJBgNVHRMEAjAAMAsGA1UdDwQEAwIDCDAKBggqhkjOPQQDAgNRADBOBggqhkjOPQQDAgIg099Y4FiMOEUkK2nOBkNSrCWrrMf/0DiQUQ6Bq8BNFmkCIP2nH6EFA5f/MV9PwSwyZ6q8GZfNRUmaRjxc+usTFVLR</Cert>
</ServerCertificates>
<Guek>00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F</Guek>
<Gak>D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF</Gak>
<Kek>31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31</Kek>
</GXDLMSSecuritySetup>
Hi, Have you read the real…
Have you read the real meter or have you added security setup manually? Are you using Java or C# simulator?
Sorry, I don't have real…
Sorry, I don't have real meter and i added security setup manually. All the certificates and key is done by Director. I use java simulator.
Hi, I tested this and it…
I tested this and it worked as expected. Check that the Security Setup Suite value is Suite1 or Suite2 and not Suite0.
I have set both of the…
I have set both of the server and client suite1,but it doesn’t work.
Thanks a lot.I refresh the…
Thanks a lot.I refresh the director,and then the problem is solved.
