By batulzii, 18 January, 2024 Forums Gurux.DLMS i plan to add more registers with obis/ln. but here is description unmatched. Image Hello, 1.8.0 -- Positive… Hello, 1.8.0 -- Positive active energy, total? ln -- 1.1.8.0.0.255 - correct? BR, Image Hi, 1.1.8.0.0.255 is Ch. 1… Hi, 1.1.8.0.0.255 is Ch. 1 Sum Li Reactive power QIV Billing period avg. You can find correct OBIS code with GuruxDLMSTranslator. https://www.gurux.fi/GuruxDLMSTranslator Select OBIS code tab. Clear the OBIS code and set e.g. "active energy" to the filter. Press search and you can see possible options. Select OBIS code that you want to use. BR, Mikko Hello Kurumi, There is no… Hello Kurumi, There is no such window. Mine is like attached. Separate OBIS code window, but it does not have search button BR Image Hi, I'm sorry. I mean… Hi, I'm sorry. I mean GuruxDLMSTranslator, not GXDLMSDirector. Try this link. https://www.gurux.fi/GuruxDLMSTranslator BR, Mikko Hello, But Description has… Hello, But Description has different meaning. 1.0.1.8.0255 should be active energy, DLMSdirectүж shows Sum Li Active Power ... BR, Hi, OBIS descriptions are… Hi, OBIS descriptions are coming from DLMS standards. 1.0.1.8.0.255 is Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) You need to select a different OBIS code for active energy. BR, Mikko
Hello Kurumi,
BR
