  3. GXDLMSPushListener
GXDLMSPushListener
By alnardn , 17 January, 2024
Hello!
Can i use push/listener example https://github.com/Gurux/Gurux.DLMS.Python/tree/master/Gurux.DLMS.Push… to receive initiative messages from meter? And if yes, port number at main.py startup is related to my computer or to meter port?
2 years 10 months ago
Hi, Push messages are…
Push messages are messages that the meter sends in periodically. Messages can include e.g. load profile data. With push messages, you don't establish the connection for the meter. The client just receives the messages from the meter.
Port is your computer port where meter sends the messages.
You can check the port if you establish the connection with GXDLMSDirector to the meter and check Push Setup object.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSPushSetup
