  2. Use of Local Area Networks On Twisted Pair With Carrier Signalling
Use of local area networks on twisted pair with carrier signalling
By 94r4d0x, 23 November, 2023
hi
I need to connect my meter with IEC 62056-31 protocol
Part 31:
carrier signalling
it possible ?
1 year 5 months ago
Hi, IEC 62056-31 defines the…
IEC 62056-31 defines the physical connection. Do you know if your meter supports IEC 62056-21 or DLMS? If there is DLMS label on the cover of your meter you can read it with DLMS.
94r4d0x
1 year 5 months ago
my meter support only 62056…
my meter support only 62056-31 with DLMS or Without support both
and Local bus data exchange – Hardware support only Bus or Magnetic plug
1 year 5 months ago
Hi, If your meter supports…
If your meter supports DLMS you can read it with Gurux open source libraries.
IEC 62056-31 or IEC 62056-3-1:2013 nowadays, defines only the communication bus and its settings.
You need to connect your meter to the PC and ask what client and server address you need to use from the meter manufacturer. Each meter has its own server address so meters can be connected to the same bus.
94r4d0x
1 year 5 months ago
ok thanks but how to connect…
ok thanks but how to connect it with my PC (the link between pc an meter)
what Interface physical
Bus is twisted pair with carrier signalling
how to connect meter with pc what Interface usb or rs232 or what physical port
this point I confused
thx
1 year 5 months ago
Hi, You need the converter…
You need the converter for the twisted pair. I don't know what meter you are using, but e.g. Moxa has products to suit your needs.
  • Fri, 05/09/2025 - 13:03
    Gurux.DLMS.Python 1.0.181
  • Wed, 05/07/2025 - 16:09
    Gurux.DLMS.Android 2.0.14
  • Tue, 05/06/2025 - 09:34
    gurux.dlms.c 9.0.2505.0601
  • Tue, 05/06/2025 - 08:51
    GXDLMSDirector 9.0.2505.0601
  • Tue, 05/06/2025 - 08:26
    gurux.dlms.java 4.0.79
  • I LOST MY CRYPTO, HOW DO I RECOVER IT? Contact iFORCE HACKER RECOVERY
  • +27734583119 WORLD'S TOP BEST LOTTO SPELLS AUSTRALIA ITALT UK USA SCOTLAND NETHERLANDS CHICAGO POLAND MEXICO COLORADO NORWAY
  • CRYPTO SCAM RECOVERY - HIRE iBOLT CYBER HACKER COMPANY
  • +27734583119 TRUSTED IMPACTFUL BLACK MAGIC RING AND PURSE FOR WEALTH FAME SUCCESS FRANCE AUSTRALIA ITALY UK USA SCOTLAND QATAR WASHINGTON POLAND MIAMI NEW YORK INDONESIA ALABAMA ARIZONA
  • +27734583119 MOST CONSTRUCTIVE BLACK MAGIC DEATH SPELLS CASTER FRANCE CANADA AUSTRALIA ITALY UK USA QATAR WASHINGTON BOTSWANA CHICAGO PORTUGAL LEBANON BERLIN
