  2. Use of Local Area Networks On Twisted Pair With Carrier Signalling
Use of local area networks on twisted pair with carrier signalling
By 94r4d0x , 23 November, 2023
hi
I need to connect my meter with IEC 62056-31 protocol
Part 31:
carrier signalling
it possible ?
2 years 7 months ago
Hi, IEC 62056-31 defines the…
IEC 62056-31 defines the physical connection. Do you know if your meter supports IEC 62056-21 or DLMS? If there is DLMS label on the cover of your meter you can read it with DLMS.
94r4d0x
my meter support only 62056…
my meter support only 62056-31 with DLMS or Without support both
and Local bus data exchange – Hardware support only Bus or Magnetic plug
Hi, If your meter supports…
If your meter supports DLMS you can read it with Gurux open source libraries.
IEC 62056-31 or IEC 62056-3-1:2013 nowadays, defines only the communication bus and its settings.
You need to connect your meter to the PC and ask what client and server address you need to use from the meter manufacturer. Each meter has its own server address so meters can be connected to the same bus.
94r4d0x
ok thanks but how to connect…
ok thanks but how to connect it with my PC (the link between pc an meter)
what Interface physical
Bus is twisted pair with carrier signalling
how to connect meter with pc what Interface usb or rs232 or what physical port
this point I confused
thx
Hi, You need the converter…
You need the converter for the twisted pair. I don't know what meter you are using, but e.g. Moxa has products to suit your needs.
  • CGXDLMSProfileGeneric::SetValue for attribute 3. Possible memory leak
  • Clou
  • DLMS Server how to set server logical address, and attach object to different association
