  2. DLMS IEC62053-26 Protocol How To Retrieve Previous Month's Data? (obis Code)
DLMS IEC62053-26 protocol how to retrieve previous month's data? (obis code)
Profile picture for user Zaya
By Zaya , 3 November, 2023
I have been trying to get previous month's data of my three phase smart meter and I do not understand 1.8.1*X obis code. Please help me how to get the X value.
Thank you.
2 years 9 months ago
Hi, I believe that it's…
I believe that it's easiest if you download GXDLMSDirector and play with that. It will help to understand DLMS devices and what you can do with them.
Zaya
Hello Thank you for your…
Hello
Thank you for your reply, I did try GXDLMSDirector and the meter I am using is not in the manufacturer list and I added the manufacturer but I still get "no connection could be made because the target machine actively refused it" error. Also I am trying to connect using third party device which is RS485 interface. Is it possible?
Any advice on this?
Thank you.
2 years 8 months ago
Hi, Yes, that is possible. …
Yes, that is possible. "no connection could be made because the target machine actively refused it" error means that your IP address or port number is wrong and TCP/IP connection can't be established. Check those first.
Zaya
The meter I am using is…
The meter I am using is Shenzhen Inhemeter i310(DTZ1513) and I am using serial port to connect and still does not work I am not sure it's settings or not. Can you check this meter?
Hi, We don't have DTZ1513…
We don't have DTZ1513 meter. I believe that one of your settings is different than the meter expects. You need to check the correct settings from the meter documentation or contact the meter vendor.
Zaya
Thank you for your advice…
Thank you for your advice sir. Is there any chance to talk to you via email or social media that I can ask you a few more things?
Hi, I'm sorry, but we can…
I'm sorry, but we can help only our clients by email.
