I am facing 2 problems using readRowsByRange in the DLMS python library.
Being a newbie in that kind of stuff, I reused Client.Example and modified it to reach what I wanted. I need to retrieve historical data from one or several selected registers.
1. First problem is when I make my call to readRowsByRange (I have not modified it in any way), I am getting the data I want, only each value is labeled with a datetime corresponding to the start value (defined in GXDLMSReader.py).
See linked image (I modified the g flag so that it sorts what corresponds to a profileGenerics or to an object and get the different historical data for each register).
Note that the correct time values are returned when using GXDLMSDirector.
2. Second problem is that I tried to select the columns I wanted in the output by giving the columns argument (a list of dictionaries {GXDLMSObject: GXDLMSCaptureObject} ) but I get the following error:
EXCEPTION
Error! Failed to read last day: 0.
I read that the functionality is not supported by all the meters ( https://www.gurux.fi/node/20394 ) so I was wondering if this is the kind of Exception you get if the meter is not supported or if I did something wrong.
For the moment I am filtering myself the columns I want based on logical names and by keeping the index of the columns I want to select the values returned and I am worried it increases execution time too much.
By the way if you know any other way to make the example code more efficient following my needs I would be pleased to hear your thoughts :D
Thanks in advance for your time!
Cyril
I forgot to mention: the…
I forgot to mention: the device manufacturer of the meters I am communicating with is Iskraemeco
Erratum: the measurements are all labelled with the same datetime corresponding to the time of the first measure, not the starting time (set by me).
It also seems I am not facing the same issue with every profileGeneric objects (see screenshot below).
Hi Cyril, You are right that…
Hi Cyril,
You are right that all the meters are not supporting reading only part of the columns. It might be better if you don't use that.
Your date time problem looks odd. Can you add the hex trace (add -t Verbose) so I can check what might cause this from the bytes?
Hi, And now I notest that…
And now I notest that your meter manufacturer. The reason for this is that you need to read Capture period. Now it's not read and date-time is not increased.
Hi Kurumi, Thank you for…
Hi Kurumi,
Thank you for your explanations!
I tried the reset and capture methods from GXDLMSProfileGeneric class (I also tried only using capture method) but it seems not to change anything. Here is the implementation of my modified method getProfileGenerics (see screenshot).
Am I missing a point?
Note that even when using…
Note that even when using the library example without modifying it, I have the same problem (see screenshot).
Finally, here is a verbose…
Finally, here is a verbose output.
Thank you in advance for your help!
gurux_dlms version: 1.0.145
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
SETUP: 0.0019969940185546875 seconds
SETTINGS: 0.0 seconds
ClientAddress: 0x64
SETUP READER: 0.0009992122650146484 seconds
Standard: Standard.DLMS
TX: 18:10:26 00 01 00 64 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF
RX: 18:10:28 00 01 00 01 00 64 00 2C 61 2A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 11 04 0F 08 01 00 06 5F 1F 04 00 00 1C 1D 04 00 00 07
SETUP CONNECTION: 3.376082420349121 seconds
TX: 18:10:28 00 01 00 64 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
RX: 18:10:29 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 00 00 82 03 F4 01 82 01 92 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 01 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 01 00 01 06 02 02 0F 01 03 01 02 02 0F 02 03 01 02 02 0F 03 03 01 02 02 0F 04 03 01 02 02 0F 05 03 01 02 02 0F 06 03 01 02 04 12 00 1B 11 00 09 06 00 00 02 00 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 1D 11 00 09 06 00 00 02 01 00 FF 02 02 01 06 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 01 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 64 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 65 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 66 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 01 FB FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 01 FC FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 01 FD FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 01 FE FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 32 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 32 81 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 32 82 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 0B 11 00 09 06 00 00 0B 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 01 02 02 0F 01 03 01 02 04 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 02 03 0F 0A 16 03 00 01 01 02 02 0F 01 03 01 02 04 12 00 06 11 00 09 06 00 00 0E 00 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 01 03 02 02 0F 01 03 01 02 02 0F 02 03 01 02 02 0F 03 03 01 02 04 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 02 03 0F 04 16 03 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 01 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02
TX: 18:10:29 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 00
RX: 18:10:31 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 01 00 82 03 F4 16 03 00 02 03 0F 03 16 01 00 02 03 0F 04 16 03 00 01 00 02 04 12 00 13 11 00 09 06 00 00 14 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 07 11 01 09 06 00 00 15 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 00 00 15 00 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 00 00 15 00 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 17 11 00 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 02 01 06 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 01 00 02 04 12 00 2A 11 00 09 06 00 00 19 01 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 02 03 0F 0A 16 03 00 01 00 02 04 12 00 2C 11 00 09 06 00 00 19 03 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 01 00 02 04 12 00 2D 11 00 09 06 00 00 19 04 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 01 00 02 04 12 00 0F 11 00 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 01 02 02 0F 02 03 01 02 02 0F 03 03 01 02 02 0F 04 03 01 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 07 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04
TX: 18:10:31 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 01
RX: 18:10:33 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 02 00 82 03 F4 12 00 01 11 00 09 06 00 00 60 01 08 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 09 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 03 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 03 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 07 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 08 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 09 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0D FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 0F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 10 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 11 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 12 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 13 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 60 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01
TX: 18:10:33 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 02
RX: 18:10:35 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 03 00 82 03 F4 00 02 04 12 00 01 11 00 09 06 00 00 80 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 06 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 06 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 0D FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 0E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 0F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 10 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 11 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 18 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 1A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 1B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 1F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 20 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 21 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 22 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 23 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 24 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 25 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 29 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 2A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 2B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 2C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16
TX: 18:10:35 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 03
RX: 18:10:37 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 04 00 82 03 F4 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 2D FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 2E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 2F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 32 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 07 33 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 03 11 00 09 06 00 00 80 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 0A FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 0B FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 0C FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 0D FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 14 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 15 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 16 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 17 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 1E FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 1F FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 20 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 08 21 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 00 80 08 32 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 0A 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02
TX: 18:10:37 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 04
RX: 18:10:38 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 05 00 82 03 F4 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 0A 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 0A 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 0A 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 14 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 0D FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 1E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 1E 1F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 28 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 28 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 28 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02
TX: 18:10:38 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 05
RX: 18:10:50 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 06 00 82 03 F4 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 28 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 28 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 32 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3C 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 03 11 00 09 06 00 00 80 3C 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 00 80 3C 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 80 3C 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 0A FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 0B FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 0C FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 14 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 15 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 16 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 17 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 18 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 00 80 3C 1E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3C 1F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3C 20 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 03 11 00 09 06 00 00 80 3C 28 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 29 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 2A FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3C 2B FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00
TX: 18:10:50 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 06
RX: 18:10:52 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 07 00 82 03 F4 03 11 00 09 06 00 00 80 3C 2C FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3D 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3D 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3D 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3D 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 00 80 3D 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3D 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3D 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3D 0D FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3D 0E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3D 0F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3E 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 3E 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 03 11 00 09 06 00 00 80 3E 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 00 00 80 3E 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 00 80 3E 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 80 3E 05 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 00 80 3E 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 64 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 64 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 64 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 64 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 64 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 64 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 64 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04
TX: 18:10:52 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 07
RX: 18:11:04 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 08 00 82 03 F4 12 00 01 11 00 09 06 00 00 80 65 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 07 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 08 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 0F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 10 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 11 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 12 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 1A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 1B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 65 1C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 66 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 66 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 67 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 67 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 80 67 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C4 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C4 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C4 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C4 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C4 03 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C4 3C 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C4 61 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 13 11 00 09 06 00 01 14 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02
TX: 18:11:04 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 08
RX: 18:11:07 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 09 00 82 03 F4 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 17 11 00 09 06 00 01 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 0A 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 04 11 00 09 06 00 01 80 32 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 01 80 32 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 01 80 32 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 01 80 32 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 01 80 32 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 18 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 1A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 1E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 1F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 20 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 21 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 01 80 32 28 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 0A 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 04 11 00 09 06 00 02 80 32 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 02 80 32 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 02 80 32 02 FF 02
TX: 18:11:07 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 09
RX: 18:11:08 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 0A 00 82 03 F4 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 02 80 32 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 02 80 32 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 18 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 1A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 1E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 1F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 20 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 21 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 02 80 32 28 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 04 11 00 09 06 00 03 80 32 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 03 80 32 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 03 80 32 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 03 80 32 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 03 80 32 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 18 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 1A FF 02 02 01 02 02 03 0F 01 16 01 00
TX: 18:11:08 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 0A
RX: 18:11:10 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 0B 00 82 03 F4 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 1E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 1F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 20 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 21 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 03 80 32 28 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 04 11 00 09 06 00 04 80 32 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 04 80 32 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 04 80 32 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 00 04 80 32 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 00 04 80 32 14 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 15 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 16 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 17 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 18 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 19 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 1A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 1E FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 1F FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 20 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 21 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 04 80 32 28 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 01 FF 02 02 01 02 02
TX: 18:11:10 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 0B
RX: 18:11:11 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 0C 00 82 03 F4 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 04 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 01 05 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 01 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 01 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 01 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 01 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 01 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 01 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 01 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 01 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 01 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02
TX: 18:11:11 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 0C
RX: 18:11:13 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 0D 00 82 03 F4 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 01 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 01 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 02 04 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 02 05 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 02 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 02 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 02 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 02 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 02 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 02 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 02 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 02 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 02 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 02 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 03 04 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 03 05 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 03 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 03 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 03 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F
TX: 18:11:13 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 0D
RX: 18:11:15 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 0E 00 82 03 F4 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 03 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 03 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 03 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 03 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 03 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 03 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 03 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 04 04 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 04 05 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 04 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 04 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 04 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 04 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 04 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 04 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 04 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 04 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 04 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 04 08 04 FF 02 02
TX: 18:11:15 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 0E
RX: 18:11:16 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 0F 00 82 03 F4 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 09 04 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 09 05 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 09 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 09 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 09 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 09 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 09 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 09 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 09 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 09 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 09 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 09 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 0A 04 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 0A 05 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 0A 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 0A 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 0A 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 0A 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01
TX: 18:11:16 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 0F
RX: 18:11:18 00 01 00 01 00 64 04 00 C4 02 C1 00 00 00 00 10 00 82 03 F4 00 01 01 02 02 0F 01 03 01 02 04 12 00 04 11 00 09 06 01 00 0A 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 1F 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 20 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 33 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 34 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 47 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 03 11 00 09 06 01 00 48 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 01 11 00 09 06 01 00 60 EF 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 EF 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 EF 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 F0 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 F1 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 F2 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 F2 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 F3 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 F3 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 F4 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 07 11 01 09 06 01 00 62 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06
TX: 18:11:18 00 01 00 64 00 01 00 07 C0 02 C1 00 00 00 10
RX: 18:11:20 00 01 00 01 00 64 02 01 C4 02 C1 01 00 00 00 11 00 82 01 F5 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 01 00 62 02 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 01 00 63 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 01 00 63 61 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 01 00 63 62 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 01 02 0F 01 0F 02 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01
ASSOCIATION VIEW: 52.808101177215576 seconds
OUTPUT: 52.808101177215576 seconds
1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
None
1.0.99.1.0.255 Ch. 0 Load profile with recording period 1 #1
Profile Generic 1.0.99.1.0.255Columns:
TX: 18:11:20 00 01 00 64 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 03 00
RX: 18:11:21 00 01 00 01 00 64 00 4E C4 01 C1 00 01 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 60 F0 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00
TITLES | TIME | 1.0.1.8.0.255 --- Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) --- Unit.NONE
-------- Reading 7 1.0.99.1.0.255 Ch. 0 Load profile with recording period 1 #1
TX: 18:11:21 00 01 00 64 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 07 00
RX: 18:11:21 00 01 00 01 00 64 00 09 C4 01 C1 00 06 00 00 49 B3
TX: 18:11:21 00 01 00 64 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 08 00
RX: 18:11:22 00 01 00 01 00 64 00 09 C4 01 C1 00 06 00 00 49 E0
Entries: 18867/18912
START 2023-07-20 15:00:00
END 2023-07-20 18:00:00
TX: 18:11:22 00 01 00 64 00 01 00 40 C0 01 C1 00 07 01 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E7 07 14 04 0F 00 00 00 FF 88 00 09 0C 07 E7 07 14 04 12 00 00 00 FF 88 00 01 00
RX: 18:11:23 00 01 00 01 00 64 00 D6 C4 01 C1 00 01 0D 02 04 09 0C 07 E7 07 14 04 0F 00 00 00 FF 88 80 11 00 06 02 F2 EC B0 06 00 00 00 7C 02 04 00 11 00 06 02 F2 EF 45 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F1 8E 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F3 5A 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F5 52 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F6 71 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F7 14 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F7 57 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F7 D2 06 00 00 00 7C 02 04 00 11 00 06 02 F2 F9 63 06 00 00 00 7C 02 04 00 11 00 06 02 F2 FA 49 06 00 00 00 7C 02 04 00 11 00 06 02 F2 FA E7 06 00 00 00 7C 02 04 00 11 00 06 02 F2 FB 5D 06 00 00 00 7C
MEASUREMENTS | 07/20/23 15:00:00 | 49474736
MEASUREMENTS | 07/20/23 15:00:00 | 49475397
MEASUREMENTS | 07/20/23 15:00:00 | 49475982
MEASUREMENTS | 07/20/23 15:00:00 | 49476442
MEASUREMENTS | 07/20/23 15:00:00 | 49476946
MEASUREMENTS | 07/20/23 15:00:00 | 49477233
MEASUREMENTS | 07/20/23 15:00:00 | 49477396
MEASUREMENTS | 07/20/23 15:00:00 | 49477463
MEASUREMENTS | 07/20/23 15:00:00 | 49477586
MEASUREMENTS | 07/20/23 15:00:00 | 49477987
MEASUREMENTS | 07/20/23 15:00:00 | 49478217
MEASUREMENTS | 07/20/23 15:00:00 | 49478375
MEASUREMENTS | 07/20/23 15:00:00 | 49478493
ACTUAL READING: 3.109863519668579 seconds
TX: 18:11:23 00 01 00 64 00 01 00 09 62 03 80 01 00 03 80 01 00
RX: 18:11:24 00 01 00 01 00 64 00 05 63 03 80 01 00
Hi, Please, add plain text…
Please, add plain text. Pictures are hard to read.
You need to send generated bytes for the meter. Now you have only generated them.
Something like this:
data = pg.reset(self.client)
self.readDataBlock(data, reply)
Hi Mikko, Thank you for your…
Thank you for your tip ! I think I am doing it right now (using capture() instead of reset() because reset logically seems to clear my history which is not what I want):
data = pg.capture(self.client)
reply = GXReplyData()
However, I am getting the following error:
Access Error : Device reports a unavailable object.
when executing readDataBlock (raised in readDLMSPacket2)
It would let me think that the profile generic object is somehow not recognized which is odd since reset on this same object seems to work as expected.
Below are the current implementation of the getProfileGenerics method and the Verbose output for it.
Again, thank you very much for your investment!
Best regards,
Cyril
def getProfileGenerics(self, selectedObjects=None, logicalNamesDisplay=None):
#pylint: disable=broad-except,too-many-nested-blocks
cells = []
profileGenerics = self.client.objects.getObjects(ObjectType.PROFILE_GENERIC) if not selectedObjects else selectedObjects
for it in profileGenerics:
self.writeTrace("-------- Reading " + str(it.objectType) + " " + str(it.name) + " " + it.description, TraceLevel.INFO)
entriesInUse = self.read(it, 7)
entries = self.read(it, 8)
self.writeTrace("Entries: " + str(entriesInUse) + "/" + str(entries), TraceLevel.INFO)
pg = it
if entriesInUse == 0 or not pg.captureObjects:
continue
counts = []
for count, (k, _) in enumerate(pg.captureObjects):
if k.logicalName not in logicalNamesDisplay and not isinstance(k, GXDLMSClock):
continue
counts.append(count)
try:
hours = 3
minutes = 0
if self.historicalPeriod:
hours, minutes = self.historicalPeriod.split(':')
hours = int(hours)
minutes = int(minutes)
end = datetime.datetime.now()
end = end.replace(minute=0, second=0, microsecond=0)
start = end - datetime.timedelta(hours=hours, minutes=minutes)
print("START", str(start))
print("END", str(end))
cells = self.readRowsByRange(it, start, end)
for rows in cells:
row = "MEASUREMENTS"
for count, cell in enumerate(rows):
if count not in counts:
continue
if row:
row += " | "
if isinstance(cell, bytearray):
row += GXByteBuffer.hex(cell)
else:
row += str(cell)
self.writeTrace(row, TraceLevel.INFO)
except Exception as ex:
print("EXCEPTION")
self.writeTrace("Error! Failed to read last day: " + str(ex), TraceLevel.ERROR)
TX: 17:15:44 00 01 00 64 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 07 00
RX: 17:15:45 00 01 00 01 00 64 00 09 C4 01 C1 00 06 00 00 00 0C
TX: 17:15:45 00 01 00 64 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 08 00
RX: 17:15:45 00 01 00 01 00 64 00 09 C4 01 C1 00 06 00 00 49 E0
Entries: 12/18912
TX: 17:15:45 00 01 00 64 00 01 00 0F C3 01 C1 00 07 01 00 63 01 00 FF 02 01 0F 00
RX: 17:15:46 00 01 00 01 00 64 00 04 C7 01 C1 0B
TX: 17:15:46 00 01 00 64 00 01 00 09 62 03 80 01 00 03 80 01 00
RX: 17:15:47 00 01 00 01 00 64 00 05 63 03 80 01 00
Hi Kurumi, CyrilGeo, We…
We faced more or less the same problem a few month ago.
Have you found a solution ?
Hi Kurumi, Any ideas to help…
Hi Kurumi,
Any ideas to help us to go further with your library -) ?
Thanks for your time
Alois
Hi Cyril, Device reports a…
Hi Cyril,
Device reports a unavailable object means that object is not available in your association. Check the logical name of the object.
Hi Alois, Please, create a…
Hi Alois,
Thank you for your answer.
Unfortunately I don't think that the problem for pg.capture is of this kind since I printed the logical name and type of my profile generics object just before calling pg.capture and here is what I got:
TYPE: ObjectType.PROFILE_GENERIC
Moreover, here is what I can read from my association view output file:
<GXDLMSProfileGeneric>
<LN>1.0.98.2.0.255</LN>
<Version>1</Version>
<Description>Ch. 0 Data of billing period Scheme 2 #1 Unspecified number of most recent billing periods</Description>
</GXDLMSProfileGeneric>
This lets me think that the problem is deeper, particularly when pg.reset is working perfectly fine on this same profile generics object.
Maybe the data returned by pg.capture is not correct and ReadDataBlocks is failing for this reason?
Note that my GXDLMSSecureClient has useLogicalNameReferencing=True. Should I set another parameter in that client so that the "method" function (called by pg.capture) is returning correct data?
After testing on GXDLMSDirector, I noticed that the same error occurs when clicking "Capture" in profile generics data.
Here is a reminder of what I am doing in my getProfileGenerics method:
Thank you for your time! Let me know if you need any other information.
Cyril
Hi Cyril, Capture just adds…
Hi Cyril,
Capture just adds a new row for the buffer and returns only the failure or success code.
Can you add GXDLMSDirector hex log so I can check the bytes? Trace from reset action is enough.
Hello Mikko, Here is…
Hello Mikko,
Here is GXDLMSDirector hex log for reset:
08:49:37 Method object 1.0.99.1.0.255, interface ProfileGeneric
TX: 00 01 00 64 00 01 00 0F C3 01 C1 00 07 01 00 63 01 00 FF 01 01 0F 00
08:49:39
RX: 00 01 00 01 00 64 00 04 C7 01 C1 00
08:51:31 Send Keep Alive
TX: 00 01 00 64 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 01 00
08:51:32
RX: 00 01 00 01 00 64 00 0C C4 01 C1 00 09 06 00 00 28 00 00 FF
08:53:21 Send Keep Alive
08:53:22
Here is GXDLMSDirector hex log for capture:
08:48:46 Method object 1.0.99.1.0.255, interface ProfileGeneric
TX: 00 01 00 64 00 01 00 0F C3 01 C1 00 07 01 00 63 01 00 FF 02 01 0F 00
08:48:47
RX: 00 01 00 01 00 64 00 04 C7 01 C1 0B
Best regards,
Cyril
