  3. Error When Trying To Read Meter With GXDLMSDirector.
Error when trying to read meter with GXDLMSDirector.
By vaibhav , 30 May, 2023
I got some errors when I was trying to read the DLMS meter with "GXDLMSDirector".
Please suggest solutions.
3 years 3 months ago
Hi, Please, don't add…
Please, don't add pictures. They are hard to read.
One of your settings is wrong and the meter doesn't reply.
What meter do you try to read (model and manufacturer) and what communication channel you are using (TCP/IP, serial)?
vaibhav
model: L&T Electrical &…
Following Information on the meter
model: L&T Electrical & Automation (Three Phase HTCT Multi-Port Meter)
manufacturer: ER300P
communication Channel: optical Prop to Serial Port USB.
Please suggest.
Hi, First, make sure that…
First, make sure that the cable of the optical probe is downward.
If I remember right the ER300P is not using Mode E, so select HDLC to interface type.
Check from the meter documentation what is the used baud rate and you should be able to connect.
vaibhav
Following is the …
Following is the configuration info:
Manufacturer: Larsen &Toubro Ltd
Interface: HDLC
Authentication: Low
Client Address: 11
Password: Int1
Wait Time: 00:00:05
Resend Count: 3
Address Type: Default
Logical Server: 0
Physical Server: 1
Media: Serial
settings
Serial Port: COM7
Use Maximum Baud Rate 300
Please suggest the proper solution. and let me know where to check the baud rate.
Hi, You can change the baud…
You can change the baud rate from the advanced button. Don't check the "Use maximum baud rate".
You can try with a baud rate of 9600, but you need to check it from the meter documentation or ask the meter vendor.
