hi, in recent update of gurux , It can't Parse Persian date Correctly . in previous versions ,it was working greatly.
it has error on C# version and GxDlmsDirector.
Packet examples :
TX: 7E A0 1C 00 02 76 71 03 54 A8 19 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 60 1A 7E
13:49:30
RX: 7E A0 21 03 00 02 76 71 74 82 BD E6 E7 00 C4 01 C1 00 09 0C 05 7A 02 1F 07 0D 31 17 00 FF 2E 00 62 F2 7E
now it gives Error :
Year, Month and day parameters describe an un-representable DateTime.
at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
at System.DateTime..ctor(Int32 year, Int32 month, Int32 day, Int32 hour, Int32 minute, Int32 second, Int32 millisecond)
at Gurux.DLMS.Internal.GXCommon.GetDateTime(GXDLMSSettings settings, GXByteBuffer buff, GXDataInfo info)
at Gurux.DLMS.Internal.GXCommon.GetData(GXDLMSSettings settings, GXByteBuffer data, GXDataInfo info)
at Gurux.DLMS.GXDLMSClient.ChangeType(GXByteBuffer value, DataType type, Boolean useUtc)
I think the problem raises…
I think the problem raises for month with 31 days . for example in above packets, in Persian 2nd month have 31 days and raises error. but other dates works greatly.
do you have any Idea, what we can do or is there anything that you can change in code ?
I you can add Calendar to…
If you can add Calendar to GXDLMSSettings class and use below constructor of DateTime :
public DateTime(int year, int month, int day, int hour, int minute, int second, Calendar calendar)
that has calendar in in Conversion, I think all the problems will be solved
Hi, No changes have been…
No changes have been made to the date and time for a long time. Application is using the default calendar when the date-time is read from the meter.
The date is Yekshanbeh: 31. Ordibehesht 1402. Is that correct?
What is your time zone?
Yes, it.'s correct date…
Yes, it.'s correct date.
Timezome is : +3:30 Tehran
Is there any way to change calendar (set) for this?
Hi, Calendar settings are…
Calendar settings are defined in Windows and correct settings are given as a parameter. You can try to change settings from the Windows regional settings.
Are you using Windows 10 or 11? The same environment is installed and I believe that this can be fixed if it can be repeated.
No we are using windows…
No we are using windows server 2012, and I need to set gurux calendar from code. Setting current thread culture also don't slove the problem.
Any ideas will be appreciated.
hi, Is it possible for you…
hi,
Is it possible for you to use DateTime overloads with calendar input in GxCommon ?
I mean use :
new DateTime(year, month, day, hours, minutes, seconds, milliseconds,Thread.CurrentThread.CurrentCulture.Calendar)
instead of :
new DateTime(year, month, day, hours, minutes, seconds, milliseconds)
or :
new DateTime(year, month, day, hours, minutes, seconds, milliseconds, Thread.CurrentThread.CurrentCulture.Calendar, DateTimeKind.Local)
instead of :
new DateTime(year, month, day, hours, minutes, seconds, milliseconds, DateTimeKind.Local)
Hi, This doesn't help when…
This doesn't help when you are reading data from the meter because it's not possible to set the calendar for the GXDLMSClient.
If you run dotnet --version what is the output?
there is no need to set…
there is no need to set calendar for the GXDLMSClient. we can use custume Culture class that has calendar as needed, and set for thread culture. but because you use this overloads of "new DateTime" that does not have Calendar in there inputs,then .net does not use thread calendar for them.
dotnet --version
7.0.203
In changed the code as said…
In changed the code as I said above, and the code worked greatly
hi, I'm sorry, did you find…
hi,
I'm sorry, did you find any solution for this problem ? or have any idea ?
Hi, I would like to know if…
Hi, I would like to know if you plan on implementing the changes I suggested in GxCommon. I would appreciate it if you could let me know.
I believe that changing the method as I proposed will not have any side effects on your code, since there is no calendar setting in GXDLMSClient. Therefore, your code uses the system's default calendar. Changing the code as follows:
new DateTime(year, month, day, hours, minutes, seconds, milliseconds, Thread.CurrentThread.CurrentCulture.Calendar)
instead of:
in GxCommon should be fine. If you have any comments on this, I would appreciate your feedback.
If this change is applied to the source version, I would be able to use your later updates more easily. Thank you in advance!
Hi, Sorry to say, but it's…
Sorry to say, but it's not s simple. This needs a lot of testing before it can be released.
Different time zones and localizations might cause really nasty problems.
It seems to work and it should be on the next release, but I can't say anything for sure before the tests are over.
Thank you. I would…
Thank you.
I would appreciate it if you could let me know the result.
Hi, This can be added for…
This can be added for the next release. It's released during the next week.
Hi, thank you in advance.
Hi, This is improved for the…
This is improved for the GXDLMSDirector version 9.0.2306.0201.
Hi, sorry for the delayed…
Hi, sorry for the delayed response. I was updating my code to use the new version; but I encountered another problem; as mentioned in Microsoft documents:
"The Year property returns the year of the current instance in the Gregorian calendar. It does not return the year using the default calendar of the current culture. To retrieve the year using a particular calendar, you can call that calendar's GetYear method."
However, because you used the following code in the "SetDateTime" method within the "GxCommon" class:
if ((dt.Skip & DateTimeSkips.Year) == 0)
buff.SetUInt16((ushort)tm.Year);
The time setting does not work correctly because always send year in Gregorian calendar. To correct this problem, we should use the following methods in "SetDateTime" :
Thread.CurrentThread.CurrentCulture.Calendar.GetYear()
Thread.CurrentThread.CurrentCulture.Calendar.GetMonth()
Thread.CurrentThread.CurrentCulture.Calendar.GetDayOfMonth()
I would appreciate it if you could also update this method accordingly.
Hi, I'm afraid that this can…
I'm afraid that this can't be the solution. The year, month, or day might be something else than the current thread values when reading historical data.
I don't think it will cause…
I don't think it will cause problems because:
1. We always set the thread culture to the appropriate culture, so historical data will also be used with this culture and calendar.
2. I believe this method is used in writing objects to Meter.
3. calling Thread.CurrentThread.CurrentCulture.Calendar.GetYear(dt) and using dt.Year always return the same value for Gregorian calendar.
and finally if you have any other solution for this, I'll appreciate if you apply on code.
Hi, This is a problem…
This is a problem because when you read historical data (profile generic) from the meter SetDateTime is used to set the date and time from the meter bytes.
I don't have a design for this at the moment. I need to think about how to solve this.
Hello! Thank you for your…
Hello! Thank you for your message. I appreciate you taking the time to reach out. I am eagerly looking forward to hearing back from you and am available to assist you with any further inquiries or concerns. Please don't hesitate to let me know how I can be of help.
Hi, have you thought of any…
Hi, have you thought of any solutions?
Hi, I don't have a solution…
I don't have a solution for this yet. The main problem is that there is no way to tell if Gregorian or Persian calendar is used. It will take time to find a solution to this.
hi, I have question: why in …
why in "GetDateTime" method of "GxCommon" you don't use "Thread.CurrentThread.CurrentCulture.Calendar" if deviation is not defined ?
in some meters they don't use deviation and this cause incorrect date parsing. I mean in below code Else part:
//0x8000 == -32768
//deviation = -1 if skipped.
if (deviation != -1 && deviation != -32768 && year != 1 && (dt.Skip & DateTimeSkips.Year) == 0)
dt.Value = new DateTimeOffset(new DateTime(year, month, day, hours, minutes, seconds, milliseconds, Thread.CurrentThread.CurrentCulture.Calendar),
new TimeSpan(0, -deviation, 0));
else //Use current time if deviation is not defined.
dt.Skip |= DateTimeSkips.Deviation;
DateTime tmp = new DateTime(year, month, day, hours, minutes, seconds, milliseconds,DateTimeKind.Local);
dt.Value = new DateTimeOffset(tmp);
