  2. Communication Between Landis-Gyr-E450 and Arduino + USB Host Shield Using DLMS Protocol
Communication between Landis-Gyr-E450 and Arduino + USB Host Shield using DLMS protocol
Profile picture for user Baena_060
By Baena_060 , 7 May, 2023
Good morning,
I am starting with my project to try to connect a measurement device to my arduino that has a USB host Shield board attached through an optical cable, I have read that the DLMS protocol can communicate in these conditions as long as I modify and specify the type of port that I will use, I would like to know if this is true
3 years 2 months ago
Hello, This is true, but…
This is true, but there are some manufacturer spesific settings and the meter doesn't reply if one of the settings is different than the meter expects. The easiest way to start is if you download the GXDLMSDirector and establish the connection with that. The UI helps you get the better idea from DLMS meters and what kind of data you can collect from your meter.
Baena_060
I tried to download but i…
I tried to download but i have problems with SSL and TLS methods and i don't understand why
Hi, This is the first time…
This is the first time when I heard that some one has problems with downloading GXDLMSDirector. Did you try to download it here?
https://www.gurux.fi/Downloads/gxdlmsdirector46/GXDLMSDirector.applicat…
