  3. L&T EM101+ Reading
L&T EM101+ reading
By mekam srilatha , 16 February, 2023
hi sir iam unable to read data in gurux dlms director for L&T EM101+ meter
settings are 9600 none 8 bit one stop bit
authentication Low, password: lnt1
16:47:18 Initializing serial connection.
16:47:19 Send SNRM request.
7E A0 07 03 23 93 BF 32 7E
16:47:19
7F BF 7E A0 1E 23 03 73 7B CF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
16:47:19 Parsing UA reply succeeded.
16:47:19 Send AARQ request.
7E A0 40 03 23 10 BA C5 E6 E6 00 60 32 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 06 80 04 6C 6E 74 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 74 95 7E
16:47:24 Data send failed. Try to resend 1/3
16:47:29 Data send failed. Try to resend 2/3
16:47:34 Failed to receive reply from the device in given time.
16:47:34 Disconnect request
16:47:34
7F FF FF FF FF FF F7 F7 FF BB FF FF FD FF FF FF 7F FF FF FF FF FF FD FF 7E A0 07 23 03 1F D3 5C 7E
Gurux.DLMS.GXDLMSException: Disconnect mode.
this is the log which iam getting
3 years 6 months ago
Hi, Your data is correct and…
Your data is correct and the meter replies for the first time. Select "Supported services" tab and un-check "Delta value Encoding".
mekam srilatha
In reply to Hi, Your data is correct and… by Kurumi
hi sir, i have un-checked …
hi sir,
i have un-checked "Delta value encoding", but no use.
this is the log.
14:55:10 Initializing serial connection.
14:55:11 Send SNRM request.
14:55:11
14:55:11 Parsing UA reply succeeded.
14:55:11 Send AARQ request.
14:55:16 Data send failed. Try to resend 1/3
14:55:21 Data send failed. Try to resend 2/3
14:55:26 Failed to receive reply from the device in given time.
14:55:26 Disconnect request
14:55:26
AF FF FF FD FF BF 5F 7F 7E A0 07 23 03 1F D3 5C 7E
